"2022 Golden Ear: DS Audio DS 003 Optical Phono Cartridge"
DS-003
DS-003 er den nye generasjonen av DS Audio pickuper som bygger på flere av teknologiene du finner i referansen Grand Master.
“The DS 003 shows emphatically how trickle-down technology benefits the customer, while maintain a pecking order. As close as it is to the mind-boggling Grand Master, enough differences ensure that the two can co-exist: the DS 003 is the more lively of the two, the Grand Master the more subtle. That said, if you can afford a Grand Master, buy it. If you cannot, the astonishing DS 003 will still blow your mind” - Ken Kessler Hi Fi News
"DS Audio DS 003 Optical Phono Cartridge
$2500 ($6000 with matching equalizer)
After setting new standards of fidelity in the ultra-high end with his POY-winning $15,000 Grand Master optical cartridge (and $45k, two-box Grand Master equalizer), DS Audio’s ingenious Tetsuaki “Aki” Aoyagi has turned his attention to the rest of us. The $2500 DS 003 ($6k with its matching DS 003 equalizer) is a “trickle-down” masterpiece. Using many of the technical innovations first found in the Grand Master (such as a dual-mono optical generator with independent LEDs and photo detectors for each channel and a beryllium “shading plate,” which reduces moving mass to 1/10th that of a typical moving-coil cartridge), the “third-generation” 003 sounds almost exactly like a slightly less finely detailed, slightly less spacious Grand Master....."
Les hele her:
www.theabsolutesound.com
DS-003
Les hele her:
2022 Golden Ear: DS Audio DS 003 Optical Phono Cartridge - The Absolute Sound
2022 Golden Ear: DS Audio DS 003 Optical Phono Cartridge - The DS 003 opens the door—and opens it wide—to a new world of noise-free, tape-like playback, with bass response and treble sweetness and bloom that you could previously only get with reel-to-reel. Another sure-fire nominee for a 2022...
Ta gjerne kontakt hvis du lurer på noe:
Telefon: +47 40 40 68 13
Epost: post@malaaudio.no
Mala Audio Analogsenteret
Askerveien 61 1384 Asker
Her finner du oss
Mandag: 10-18 | Tirsdag: 10-18 | Onsdag: 10-18 | Torsdag: 10-20 | Fredag: 10-18 | Lørdag: 10-16
Vår dedikerte sjåfør Hallvar leverer gjerne varene direkte til din dør.
Ta kontakt for avtale.
Meld deg på vårt nyhetsbrev her!
Her finner du oss
317.6 KB Visninger: 26
104.3 KB Visninger: 65.082
