Side 1 av 3 123 SisteSiste
Resultater 1 til 20 av 47
Tråd: strømfilter
Abonnér på denne tråden
  1. #1
    Hifi-entusiast
    Jan 2005
    Tagget i
    0 Innlegg
    strømfilter
    hei, har funnet følgende beskrivelse av et strømfilter som finnes å kjøpt der ute i strømland. side jeg ikke hadde kjent igjen en overspenning om den hadde hoppet opp å bitt meg i nesa så spør jeg, er det noe fornuft i dette??
    There're more and more mixed-wave interferences and noises in the
    power system. For example. thunder and the startup and shutdown of
    electric welder, motor, or saw will produce the mixed-wave interferences
    and noises in the power network, damaging the effect of Hi-Fi audio
    system severely. The Premier5000 Ac power filter helps eliminate the
    common-mode and differential-mode interferences and noise in the power
    network efficiently, and brings to the Hi-Fi system the penetrating
    tamber, high resolution, and perfect performance. The Premier5000 power
    filter is made of high-quality materials. It applies the best-class 10-pin
    universal socket, imported 3-pin,20A automatic overload disconnect
    protector, dual switch, and high quality power wire; it also uses the high-
    quality 4mm2 multi-core wire and 2.5mm2 single- core wire as internal lead
    wires, which id of low internal resistance to reduce the transmission loss of
    music signal current greatly, and eventually guarantee the highly-genuine
    representation of music signal. Equipped with the WIMA capacitor, the
    industry-grade MKP high-frequency anti- interference capacitor, and the
    imported low-frequency filtering, anti-interference capacitor, it can reduce the impact of high/low-frequency interference and
    noise of power network upon the audio system. The filtering circuit card is particularly and artificially processed to support high
    load, low loss, and high-quality representation of music signal. It applies the innovative 3-channel,independent filtering mode. One
    channel is the inductive powerless mode with the common-mode and differential-mode filtering circuits inside made if
    imported, high-quality magnet ring to eliminate the common-mode and differential-mode interference and noise in the AC power
    network efficiently. The other 2 channels are equipped with the non-inductive filtering circuit issued with State utility patent, which
    can improve the transmission of music signal substantially, standing out with fast transmission of music signal currency, clear high frequency, penetrating middle frequency, and extensive low frequency.
    Specifications
    *AC Power Supply : 220V+/- 10%.
    *Operating Power : Each channel>3000W,there channels altogether 9000W.
    *Overload Protection Disconnect Current : each channel 20A,three channels altogether 60A.
    *Insulation Voltage : >1500V,insulation resistance >100M. Surge Current 2500A,Peak Transient Noise Power Suppress 1500V.
    *Filter range : Remove spike ,high frequency interference and noise with 1KHz~10MHZ(AC 220V)in electrical network.
    *Operation Condition : The power filter should connect to 3-Holed Type Power Socket that has Ground(G), Neutral(N) and Live(L).
    http://www.hifisentralen.no/forum/index.php/topic,21870.0.html
  2. #2
    Bransjemedlem Audiomix's Avatar
    Jul 2004
    Tagget i
    5 Innlegg
    Album
    Torget
    37
    strømfilter
    Kort svar her også:
    Spesifikasjonene sier meg ingen ting om hvor godt et slikt "filter" undertrykker støy.
    Finn først om du har støy og om den plager deg. Først da er det fornuftig å se på filtre.
    De aller fleste filtre er ødeleggende for lyden.
    Hans - DIY'er
  3. #3
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra Audiomix
    Kort svar her også:
    Å finne eller måle støy på nettet er en forholdsvis komplisert affære, og man trenger ikke sååå mye støy at det plager en stakkars lytter før en prøver et filter.
    Mange av våre underfundige elektriske apparater står tilkoplet det samme nett og da er det ikke så rart at det kan forekomme støy i en eller annen form.
    Det finnes merkelig nok lite litteratur angående støymålinger på forbruksnettet. En kombinasjon av kraftige høyfrekvente signaler, "skjeve" belastninger( fase ), diodestøy og gnister gir uten tvil støy iform av langsspenninger og tverspenninger. Å benekte at dette kan gi forvrengning i våre musikkanlegg vil være litt naivt, men som tidligere nevnt her har det dessverre vist seg at mange filtere ødelegger mer en gavner.
    Støytrafoer har etter min mening en tendens til å begrense dynamikken i den forstand at gjenngivelsen blir slapp og kjedelig. Jeg hvet egenlig ikke hva dette kom av da jeg brukte trafoer opp mot 4 kW. Det samme gjelder de fleste av de som bruker småspoler i serie ( f.eks noen modeller av ISOTEK ). Nordost Thor ,som jeg har testet i mitt musikkanlegg benytteren helt annen teknikk, ( antagelig utfasing av støypulser ) som etter min mening forbedret lysgjenngivelsen ved at jeg fikk mindre "korn" og mindre "glear". Jeg har også prøvd mer "normale" filter bestående av seriespoler. Jon Risch sin løsning med utfasingsspole var helt misslykket, men Lukasz Fikus sitt filter som forøvrig ble beskrevet av Gbatokai her på forumet for noen år siden så interessant ut . Ikke egentlig noe nytt under solen her, men han benytter seg av en enorm jernpulvertoroid til seriespolen med dobbelspole som bedrer ballansen. Ellers et dette et helt enkelt filter LC filter for Common Mode spenninger og trippel Y kondensatorer for Differential mode spenninger i tillegg til varistorer for overspenningsvern. Etter noen justeringer og tegninger, koplet jeg til et filter som etter min mening gå tilnærmet samme resultat som Nordost Thor. Kostnaden var minimal i utgangspunktet med ved bruk av et kvaliteteschassis og -komponenter nærmer vi vel oss et par store lapper og det er vel verd forsøket ?
    hilsen up
    Utstyr : Proac D38 - Gryphon Callisto 2200 - Linn Unidisc SC - Harmonic technology PRO11 - Homegrown Audio SC-8 m/wbt
  4. #4
    Element
    Guest
    strømfilter
    up!
    Så du har større tro på Thor filteret til Nordost rett i veggen enn via en Ladac IsoTrafo 2000VA ?
  5. #5
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra Hajoken
    up!
    Nå kjenner jeg ikke til Ladac sine producter, men er dette en ren skilletrafo ( Isotrafo ) med ringkjerne er disse ikke på langt nær så effektive som en støytrafo ( f.eks. Noratel ) som består av lammelkjerne og kobberband melllom viklingene.
    Uten å ha prøvd dette, ville jeg bli svært overrasket om ikke Thor er bedre alene enn via en ISO-trafo. Men, bor man i nærheten av jernbane, industribygg eller andre kraftige støykilder er støytrafo nødvendig.
    Hilsen up
  6. #6
    Jul 2004
    Tagget i
    5 Innlegg
    Album
    Torget
    37
    strømfilter
    Effektive filtere mht å undertrykke støy inneholder spoler / induktorer.
    Jeg har sett filterløsninger som på papiret kan virke fornuftige, men jeg har til gode å se noen som er riktig laget. Jeg har heller ikke hørt noen som ikke har negativ effekt på lyden.
    Det finnes en del nyttig literatur om nettstøy. Først og fremst hos de som lager måleutstyr. FLUKE f.eks. Jeg la ut en link til en artikkel i elektor electronics for en stund siden. Nyttig lesing
    Hans - DIY'er
  7. #7
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Riktig laget, ja,- det var det da ?
    Her min løsning på et enkelt filter som kan være et godt alternativ til de dyre filtrene på markede:
    http://i67.photobucket.com/albums/h3...uls/FIKUSZ.jpg
    http://i67.photobucket.com/albums/h3...s/111_115A.jpg
    Hilsen up
  8. #8
    Hifi-interessert Poseidon's Avatar
    Jun 2007
    Tagget i
    0 Innlegg
    strømfilter
    Hei Up.
    Det var da en vakker innpakning du har på filteret du laget. Er disse kabinettene å få kjøpt eller har du fått det laget/laget det selv.
    Dersom det selges over disk så blir jeg veldig takknemmelig om du kunne gi info om hvor.
    Steve
    EC Nemo, EC AW 180, EC EMC 1 UP. EC 4.8, Michell GyroDec, Mørck DP 6, ASR Mini, ML Acsent i, 2 x ML Grotto i, Wireworld/XLO/Kimber
  9. #9
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra Poseidon
    Hei Up.
    Steve
    Kjøpte kabinettet hos ELFA, Greit nok, men det er ikke så bra som det kan se ut på bilde. Bunnplaten er altfor tynn så jeg måtte legge inne en plastplate
    i bunnen. Vanskelig å finne kabinetter i god kvalitet og ønsket størrelse, men jeg fant noe i Italia som jeg akter å bestille fra :
    http://www.audiokit.it/ITAENG/Cabine...I2000-Slim.htm
    up
  10. #10
    Hifi Freak
    Oct 2004
    Tagget i
    3 Innlegg
    strømfilter
    Sitat Sitat fra up
    Hilsen up
    Vakkert - dfet er noe med «estetikken» i solid core som jeg synes er perverst nerdete
    Det ser ut som du med fordel kan løfte sukkerbitene høyere opp av bunnplata, og dermed også de uisolerte kobberstumpene i mellom, av hensyn til sikkerhet. Apparatet ditt er vel jordet, men på dobbeltisolerte apparater anbefales en isolasjonsavstand på omlag 8-10 mm (trur eg det var). Jeg foretrekker også å bruke to sikringer på inngangen en til hver leder til nettspenningen.
    You can get away with anything if you give it a good tune
  11. #11
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra KJ
    Sitat Sitat fra up
    Hilsen up
    Ja, nå er alt montert på en pleksiglassplate som ligger 3-4 mm fra bunnen. Dette chassiset som kan kjøpes hos ELFA kan ikke anbefales fordi bundplaten er for altfor tynn.
    Fant fine kabinetter her : http://www.audiokit.it/ITAENG/Cabine...I2000-Slim.htm
    Bildet viser tydelig jordingspunktet og jordingsterminering. Jording er selvsagt avgjørende for at filteret i det hele tatt skal ha noe virkning. Vil bruke flere jordingstermineringer senere
    for eventuelt bruk til chassiset på høytalerenhetene.
    Om du vil bruke sikring på hver fase er jo opp til deg. Jeg for min del vil sløyfe sikringen på mitt neste filter. Jeg vil også bruke flere parallelle varistorer for lengre levetid.
    hilsen up
  12. #12
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Kanskje litt for risikabelt å sløyfe sikringer.
    Det kreves jo tross alt sikring siden apparatet koples videre til et annet apparat.
    Egentlig skal det også monteres temperatur-sikring på fasesiden av varistorene. Varistor kan på sikt kortslutte ( gi varme ).
    Men jeg tror ikke det benyttes så ofte i praksis.
    Mottok nettopp en interessant kurve på RFI målinger i koppernettet for telefon på Sørlandet. Som vi ser kan vi ha høye støyverdier over hele spekteret. Kommer tilbake med målinger på kraftnettet senere.
    up
  13. #13
    Hifi Freak el_mariachi's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    strømfilter
    Gjelder dette også appararater med lavt forbruk, cd-spiller, dac, pre osv?
    Former hellraiser & messageboard pyromaniac.............................
  14. #14
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra el_mariachi
    Filtrenes eventuelle påvirkning skulle være stort sett uavhengig av apparatets forbruksstrøm.
    up
  15. #15
    Hifi Freak
    Oct 2004
    Tagget i
    3 Innlegg
    strømfilter
    Sitat Sitat fra up
    up
    Strømforbruket vil kunne påvirke filterfunksjonen i filteret, ikke så mye mht. «common mode filteret» som for «differential mode filteret». Mht. «differential mode» og seriespoler (i mindre grad for strømkopenserte spoler som i filteret over) er det også viktig å være oppmerksom på at strømtrekket fra nettspenningen med konvensjonelle «lineære» strømforsyninger skjer i pulser i takt med spenningssvinget (AC), men med en vesentlig kortere «periodetid» enn en ren sinuskurve, jo større lyttebank i apparaturet relativt til stømforbruket, jo kortere blir periodetiden på strømtrekket fra nettet. Dette tror jeg er en viktig forklaring på at enkelte opplever ulike nettfiltere som «dynamikkdødare» mens andre opplever mer ro og mindre fnidder. På mange måter er det snakk om et valg mellom pest eller kolera - men både pest og kolera øker med strømforbruket. Strømtrekk i pulser vil medføre at appparaturet lager en del nettstøy på nettspenningen, avhengig av impedansen i strømnettet lokalt. Effektfaktoregulerte SMPSUer har ikke dette problemet i særlig grad, på den andre siden kan det være en liten vitenskap å håndtere, kontrollere og filtrere/skjerme RF støy fra disse.
  16. #16
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra KJ
    Sitat Sitat fra up
    up
    Støypulser mener jeg inneholder for liten energi til å påvirke nettspenningen direkte. Jeg mener også det er deformasjonen ( ny harmoniske ) av sinusspenningen som oftest er årsak til økt forvrengnig og derfor ikke avhengig av strømmen.
    Jeg er overbevist om at årsaken til dynamikkbegrensning kan være spenningstap i spoletråd. Rett og slett DC-motstand ( R ) ved kraftige signalpulser.
    up
  17. #17
    Hifi Freak
    Nov 2006
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra up
    Jeg er overbevist om at årsaken til dynamikkbegrensning ofte er bruk av bittesmå spoler med supertynn tråd og mange tørn som faktisk gir spenningstap i kraftige signalpulser.
    Har du tatt deg vann over hodet?
    Støy på nettet gir ikke forvrengning. Det forårsaker støy. Støyen er som regel demodulert, dvs at den i utgangspunktet har en mye høyere frekvens enn det signalet vi måler som støy i utstyret. Overharmoniske genererer ikke støy i utstyret.
    Det er vanligvis støy på frekvenser over 1MHz som lager problemer, og ved disse frekvensene er all støy stort sett common mode.
    Bittesmå spoler med supertynn tråd er det også vanskelig å finne i nettfiltre. Vet du mye om serieresistansen i vanlige nettfiltre. Jeg tror ikke det. Eksempel: Shaffner FN660-16, et filter med god demping har en total seriemotstand på 0.012 ohm. Det betyr at ved maks last på 16A (ved 230V) så droppes spenningen maksimalt 0.192 V, under 0.1%. Hør det den som kan.
    Hippies, prepare to be punished!
  18. #18
    Hifi Freak KW's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    strømfilter
    Hei!
    Bare en generell tanke om hvorvidt det kan være noe i denne uttalelsen fra en "skribent" på HiFi4 all (i dennes test av PPP.
    <Mange oplever at netstøjsfilter forringer dynamikken, men det skyldes rent faktisk den fjernede støj, som oprindeligt fik musikken til at virke kraftigere.>
    En tanke som slo meg når enkelte hevder at div. netstøyfiltere dreper dynamikken på tross av at filteret i noen tilfeller skulle ha langt høyere kapasitet enn nødvendig og dermed for sin egen del ikke burde (kunne) virke dynamikkdrepende.
    Mvh.KW
  19. #19
    Hifi Freak
    Oct 2004
    Tagget i
    3 Innlegg
    strømfilter
    Sitat Sitat fra KW
    Hei!
    Mvh.KW
    H vor lett er det ikke å forveksle dynamikk med kompresjon? Jeg har en liten misstanke om at når det rapporteres om økt dynamikk, særlig i form av «mikrodetaljer» og des like, så er det mange ganger reelt sett snakk om mindre dynamikk som gjør at nevnte «mikrodetaljer» blir lettere hørbart ...
  20. #20
    Feb 2002
    Tagget i
    0 Innlegg
    strømfilter
    Sitat Sitat fra Rhesus
    Sitat Sitat fra up
    Støy forårsaker støy hmm. Man skal ikke se bort fra at kraftig tilskudd av harmoniske kan gi opphav små derformasjoner av LF-signalet og dermed forvrengning.
    Underdimmensjonerte spoler finnes i de fleste filterkonstruskjoner ! Jeg har ikke målt verdiene på mikey mouse filterne Shaffner, men er overrasket av den lave motstandverdier du oppgir.
    Det er bare det at de er totalt ubrukelige i musikkanlegg ( prøvd første gang på 70-tallet ) og jeg har foreløpig ingen annen forklaring enn dette med spenningsfall.
    Kjernene er også bittesmå, og kan kanskje gå i metning ved kraftige transisenter ?
    Hvet ikke hvor du har alt dette fra men common mode støy har vi målt helt ned i langbølgeområde, dvs. langt under 1 Mhz. Se forøvrig målinger på telenettet lenger fremme, og differential mode støy fra f.eks kontaktgnist kan gi peaker langt over 1 Mhz.
    up
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
