Side 3 av 12 FørsteFørste 12345 ... SisteSiste
Resultater 41 til 60 av 238
Abonnér på denne tråden
  1. #41
    Hifi Freak Sven_Palvig's Avatar
    Feb 2002
    Tagget i
    1 Innlegg
    "Immersive Sound Immersive Sound is often simply translated as ‘Surround Sound with Height’. Although technically correct, it should be noted that there is much more to it. Surround Sound formats are in practice only 2-dimensional, positioned in the horizontal plane around the listener and allowing sound to be produced from left to right and from front to back. Immersive Sound formats thus add the third dimension, allowing sound to be also produced from top to bottom.
    Auro-3D® was the first format capable of reproducing a 3D space, with a complete end-toend solution for all markets,. The added experience brought by the addition of this third dimension can be much closer to what is experienced in real life and is the result of the combination of a number of elements. The most obvious elements is that sounds we expect to come from above now also do so (e.g. bird in a tree, airplane flying over…). However, perhaps less intuitively understandable, but nevertheless more important, is that an Immersive Sound system can also capture and reproduce the many ‘3D reflections’ of those sounds, building a natural-sounding sound field as we experience it in real-life. The majority of real-life sound consists of 3D reflections that are crucial for our brain to analyse the sound field. Many agree that ‘timbre’ or ‘tone color’ is the dominant parameter in the reproduction of natural sound and that those reflections are a crucial contributor for this. The speaker layouts as defined in the Auro-3D® format, are capable of reproducing those 3D reflections, creating “a coherent, vertical stereo field around the listener”, which allows for more depth, transparency and definition of the source localizations.
    The method to reproduce the sounds in this 3-dimensional environment can be technically very different: channel-based, such as the original Auro-3D formats, object-based, such as Dolby Atmos, or DTS:X and the upcoming AuroMax format in Cinema, or even scenebased, using Ambisonics, one of the techniques used in MPEG-H (which also provides channel- and object-based audio delivery). It is clear that the final experience counts, not what technique was used to achieve this experience (contrary to what a lot of marketing would like you to believe).
    All methods are usable to reproduce the individual sound sources in the 3D environment. It is claimed that object-based systems are best positioned to fulfil this tasks, thanks to their independency of the final reproduction system. This might be true to some extent, but depending on the installed speaker system. However, when playing back the same sound scene on the same speaker system, very little difference will be observed between the different systems, if any at all. However, with a carefully chosen speaker layout, a channel-based system is more suited to capture and reproduce the crucial information that makes up the complete natural sound field, including information about the original recording environment (room), size and distance of the sources and many more elements. This is why all object-based audio systems also include a channel-based component, often referred to as the ‘bed’, carrying this crucial information, next to the objects which often only carry the direct sound of the elements (often as mono-objects). Dolby Atmos home has a 7.1 surround sound bed (2D) while Auro-3D® is the only Immersive Sound format on the market that can reproduce a true 3D space with channel-based (beds) audio only, providing a consistent experience on all Auro-3D playback systems everywhere. "
    Modifix håndbyggede: Trykkammer højttalere med trådophængte basser for front og center højttaler.
    Subwoofer med Monacor 18 " i 324 liter lukket kabinet. Surround højttalere med 7 tommer basser.
    Lytterum med Svanø Akustik Wings. NLE højttaler kabler i 5 kvt. sølv. 2 stk. monoblokke Holton NX 800. 132.000 uf. AudioQuest Thunder High - Current samt Vibex strømfordelere.
  2. #42
    Feb 2002
    Tagget i
    1 Innlegg
    "Reproduction of a 3D space 2.2.1 Human hearing Throughout evolution, human hearing has evolved with an emphasis on the horizontal plane at ear level. Using the two ears at either side of the head, various cues are used to detect the position of the sound sources (Inter-aural Level Differences (ILD), Inter-aural Time Differences (ITD) and Spectral Information). Ideally, a real sound source is placed at every conceivable position a sound can be originating from. Clearly not a feasible option. However, thanks to various psycho-acoustical effects, the human brain is able to interpret audio signals reproduced speakers in a way that allows sounds to appear coming from directions in between those speakers (the so-called ‘phantom’ sources, allowing us to hear a sound originating from a location where no loudspeaker is installed). This stereophonic effect works extremely well in the frontal horizontal plane (thanks to the ears at either side of the head), but much less so in the lateral plane (no ears on front or back of the head) and not at all in the vertical direction (because there is no ear on top of the head to capture the vertical time and level differences). This is why regular stereo already provides a nice sounding experience in front of the listener, while 5.1 surround does not seem to add the same results from the sides. "
  3. #43
    Feb 2002
    Tagget i
    1 Innlegg
    "Is sound coming from directly above key to an immersive sound experience? Since there were not too many predators attacking human beings from above, the sensitivity for sounds from above is far less than for those originating at ear level. Next to this, not many source sounds or reflections come from directly above. As such, it can be understood that it does not make sense to limit the sound system’s ability to only reproduce sounds coming from the top. That’s why the difference between Auro 9.1 and Auro 10.1 (adding Auro-3D’s third layer, the Top layer) is rarely making any difference in the immersive sound experience. "
  4. #44
    Feb 2002
    Tagget i
    1 Innlegg
    "Vertical Coherence Due to the lack of vertical precision in the human hearing system, it is not possible to experience ‘phantom sources’ between vertically spaced speakers in the same way as can be perceived in the horizontal plane. A typical stereo setup places the two speakers at 60º. Despite its limitation to only position sounds between the speakers, it is still capable of reproducing a feeling of “depth” from recordings using time differences. The experience of “depth” is a psycho-acoustic result of a “horizontal coherent stereo field”, which is also further extended in a Surround setup. However, this does not work in the same way in the vertical plane. Various tests have shown that the coherence in the vertical axis falls apart when the angle between 2 vertically placed speakers exceeds 30º to 35°. The two speakers become audible as two distinct sources, which is a very unnatural experience. Subconsciously, it feels like an effect instead of delivering a natural immersive experience. Most source sounds and their 3D reflections originate from around ear-level up to about 30° elevation. This is not only in nature but also in small and large rooms such as churches. The Ceiling or “Voice of God” channel is therefore less important than Auro-3D’s unique Height layer to achieve a natural immersive sound. Once 3D reflections are reproduced by the Ceiling channel (Top or Voice of God channel) only, it actually starts sounding very unnatural. The combination of Auro-3D’s Surround layer and its unique Height layer creates a “vertical stereo field” all around the listener, capable of reproducing a natural coherent sound field in the horizontal AND vertical axis. The resulting immersive sound field can then be achieved with native source material (ambiances, classical music etc) as well as when using the Height layer in a more creative way, spreading the sounds between Surround and Height layer. This not only provides more transparency, but also creates a higher emotional impact since real sound in 3D, with a coherent sound field in all directions as reproduced by Auro3D, allows our brain to focus on the content instead of on ‘interpreting’ the signals. Listening to Auro-3D thus becomes more relaxing than listening to Stereo or Surround. "
  5. #45
    Hifi Freak AndersR's Avatar
    May 2011
    Tagget i
    3 Innlegg
    Torget
    Jeg kan ikke forstå at det er mulig å støtte denne forherligelsen av hedenskap i form av "Auro-3D" som de kaller seg.
    Auro-3D selges inn til kundene med en primær feature som andre ikke kan tilby: ved å kjøpe lisensen lover de deg GUDS STEMME i din egen stue. Dette er ingenting annet en ren blasfemi. Jeg priser meg lykkelig over at min reciever ikke kom med dette systemet inkludert. For å få dette kreves det 150 euro som "lisenskostnad" til disse sjarlatanene for å "oppgradere" anlegget mitt. Da ringer jeg heller til en tv-predikant-svindler for å få han til å velsigne høyttalerkablene mine pr telefon. Det er hvertfall ikke noe verre enn å installere "Voice of God" i taket i stuen min.
    Det at de som lager og selger dette konseptet kommer til å brenne i evigheten får være deres problem, men jeg har ikke tenkt til å brenne sammen med dem, eller gi de mer penger enn de allerede har stålet til seg ved å forsøke å selge Guds navn til godtroende kunder.
    Jeg kan virkelig ikke anbefale noen å investere i slik djevelskap som dette (med mindre de allerede er fortapte og ikke har noe ønske om å endre situasjonen), for konsekvensene kan bli hinsides enhver fatteevne. Jeg har ikke tenkt til å bruke penger på å ødelegge evigheten for meg selv og de rundt meg på dette viset. Det burde ingen andre heller.
    Heldigvis er det knapt nok noen titler som leveres med Auro-3D, så det virker som at det skandinaviske distribusjonsleddet har tatt ansvar for å ikke spre synden videre. De gir oss heller Atmos eller helt vanlig Master Audio uten høydekanaler, og jeg setter stor pris på barmhjertigheten hos disse aktørene. De kunne sikkert tjent masse penger ved å selge sjelene sine til Auro-3D folkene, men har allikevel integritet nok til å si at nok er nok, og at de ikke vil være med på denne ukristelige svindelkampanjen.
    Av samtlige filmer jeg har i hylla mi (og det begynner å bli en del av dem nå) er det heldigvis bare EN som gir muligheten for å utløse denne syndefloden. Jeg velger å holde tittelen for meg selv for å unngå å være medskyldig dersom noen skulle falle for fristelsen. Ingen av oss vet med sikkerhet hva konsekvensene vil bli før det er for sent. Jeg velger derfor å holde meg på den sikre siden og unngå formatet i sin helhet.
    B&W-basert stuekino er FERDIG! Byggetråd HER
  6. #46
    Feb 2002
    Tagget i
    1 Innlegg
    Jeg synes, at du overdriver det her. Det er bare sådan i sjov, og det mener jeg bestemt, at Gud synes er i orden. Marantz og Denon bruger ikke den betegnelse, men kalder det en tophøjttaler. Man behøver ikke en top højttaler. Et 9.1 Auro-3D fungere bare så godt. (5.1 + 4).
    Jeg er selv kristen. Husk man bliver frelst ved tro på Jesus, og ikke ved lovtrældom.
    Min Marantz processer AV8805 er udstyret med Auro-3D. Så det har ikke kostet ekstra.
  7. #47
    Hifi Freak Laban MK3's Avatar
    Mar 2016
    Plankebyen
    Tagget i
    2 Innlegg
    Til gode å henge opp senter høyde kanal enda, auro gjør en god jobb ellers så vil nok tro det blir prikken over i'en.
  8. #48
    Feb 2002
    Tagget i
    1 Innlegg
    Jeg synes, at det er interessante ting Auro-3D skriver. Man er velkommen til at kommentere det og gerne med egne erfaringer.
    " Number and positions of speakers When defining a speaker configuration for Immersive Sound, it is important to take all these elements into account. This is exactly what happened when defining the Auro-3D compatible systems, starting from Auro 8.0 Various tests and studies have shown that at least a cube, using quadraphonic Height layer on top of a quadraphonic ear-level layer, is needed to reproduce a convincing 3D space (cube) . The Top or Height layer needs to be positioned with approximately 30º elevation to achieve a consistent sound field and avoid that the different layers become too distinct, reducing the naturalness of the experience (see 2.2.2) As a result, all Auro-3D speaker setups include this important Height layer, capable of reproducing the vertical stereo field all around the listener. As part of the foundation of the format they are as such also defined as channels in all Auro-3D formats, allowing for easyto-produce and predictable, consistent results during the reproduction. In cinema, Dolby Atmos provides only 2 such channels, which are then positioned directly above the listening area. This has two effects: a) overhead channels cannot contain the allimportant reflections that define a truly, natural 3D sound field and b) the distance with the Surround layer becomes too big (ca 45º-60º elevation), eliminating the vertical stereo-effect. As a consequence, these channels become ‘detached’, greatly reducing their ability to reproduce natural sound, especially with ambiance-rich content such as sports events or music. In the Home version of Atmos, the Top channels are even limited to be used for rendering of objects (or object-clusters) only, reducing the possibilities for natural, life-like sound even further since a real Immersive Sound field can not be achieved with a 2D Surround bed combined with distinctly placed sounds in 3D. All Auro-3D speaker setups, from Auro 8.0 up to Auro 13.1 and AuroMax 26.1, contain at least the 4 Height speakers that are crucial to reproduce a natural-sounding immersive and true 3D sound field, delivering a consistent and compatible experience with all Auro-3D content. The additional speakers, including the third layer above the listener (the Top), are useful to maintain the optimum experience as the room grows. Dolby Atmos, however, starts with 5.1.2, using only 2 Top speakers placed above the listener, with limited added experience as it is not able to fully reproduce a real 3D space. The experience when playing back the same content over the various setups, from 5.1.2 to to 5.1.4, 7.1.2, 7.1.4, etc… can therefore vary dramatically and leaves content makers as such with a more ‘unpredictable’ result.. "
  9. #49
    Feb 2002
    Tagget i
    1 Innlegg
    Sitat Sitat fra Laban MK3 Se Innlegg
    Tak for dit indlæg.
    Jeg regner med, at du vil få endnu bedre lyd med en center High.
    Jeg har selv været meget modstander af en centerhøjttaler, og hørt på flere, hvor det var en fordel, at den ikke var på. Men jeg blev overbevidst, og fik bygget mig en med fremragende resultat. Jeg er blevet klar over, at flere højttalere aflaster hinanden og de gør det godt sammen. Hvis kvaliteten er god.
    De vigtigste inforationer i lyd kommer forfra, og her kan Dolby Atmos tilbyde 3 højttalere, men Auro-3D kan tilbyde 6.
    Auro-3D siger selv om center High, at den mest bruges til rum informationer. Og vist også dybdeperspektiv.
  10. #50
    Feb 2002
    Tagget i
    1 Innlegg
    "Screen channels With a good Immersive Sound system, it should also be possible to create better positioning in front of the listener, often linked to what is happening on the screen. Since most of the sound is coming from the screen channels and not from the Surround channels, delivering the best screen sound became one of Auro-3D’s priorities. The Front Height channels of the Auro-3D speaker layouts, also referred to as the Height Screen channels, allow sounds to be positioned over the whole area of the screen, including on the vertical axis, providing a better visual-auditory coherence. For installations with large screen, Auro3D setups using a Height Center speaker (e.g. Auro 11.1) are recommended, which then provide 6 screen channels, distributed over 2 layers covering the whole screen. Thanks to the marketing behind object-based audio, many people think that better positioning of sounds on the screen and in the room is the most important factor of an immersive experience. However, studies have shown that tone color or timbre is actually the dominant element in the perception of natural sound. This is the main advantage of using Auro-3D screen channel setup, which creates more depth and transparency and an overall much more natural sound for all kinds of applications (music, movies, games, sports events, etc.). In contrast, Dolby Atmos uses only a single layer of 3 channels behind the screen. For extremely large screens, 2 optional speakers can be added that are not part of the channelbased ‘beds’ but only used for object-based sounds. This single line of speakers not only reduces the better on-screen placement, but also creates a larger gap between the screen channels and the overhead speakers, reducing the coherence of the sound field to a large extent."
  11. #51
    Feb 2002
    Tagget i
    1 Innlegg
    "An efficient system From information theory it can be shown that more than 400,000 speakers would be required to faithfully reproduce a 3D sound field in an area with a diameter of about 2 meters, as is also opined by well-known researchers such as M. Gerzon and T. Holman (THX). The art thus becomes to create an illusion that is as natural as possible with the minimum amount of speakers, related to the size and shape of a room. The goal of the Auro-3D format is to always offer the best immersive sound experience with the minimum amount of speakers. Thanks to the stereophonic effect, it is fortunately possible to create convincing approximations with far less speakers. This works best in front of the listener, but less so to the sides and in the back. 5.1 Surround systems typically suffer from such ‘holes’ at the side, creating a feeling of separation between the sound in the front and the back of the listener. The introduction of the separated Side and Back speakers in 7.1 Surround was an attempt in solving this, but was not always successful, due to the practical implications of such a setup. With the introduction of the Height layer, this phenomenon is greatly reduced as the additional reflections coming from above already help the brain to better understand the positioning without the need of the additional speakers. As such, Auro 9.1 is based on the standard 5.1 Surround setup (acc. to ITU-R BS.775) and is considered the most practical and economical way to provide a true 3D sound reproduction without the typical artefacts mentioned above. HL HLS HR L R C HRS 110° 30° LS RS AURO 9.1 HEIGHT LAYER 5.1 SURROUND LAYER Figure 1 - Auro 9.1 Speaker Setup AURO 10.1 HEIGHT AND TOP LAYERHL T HLS HR
    L R
    C
    Navn:      Auro-3D 9.1.jpg
Visninger: 194
Størrelse: 16.2 Kb
    For larger rooms, the addition of the third Top layer, completes the full hemisphere. Auro 10.1 is therefore the most efficient setup with 3 layers, while still providing compatibility with 5.1 Surround.
    Auro 11.1 has become the preferred choice for Cinema Theaters. The use of large screens in combination with the 6th screen channel, the Height Center channel, then provides the most natural onscreen positioning and vertical spread. Home Cinema systems using this system then become the most practical system with full compatibility with movies produced in Auro 11.1.
    In those case where compatibility with 7.1 Surround is requested, Auro-3D provides a 2layer setup, Auro 11.1 (7.1+4), as well as a full 3-layer setup, Auro 13.1 (7.1+5+1)
    Figure 2 - Auro 11.1 (7.1+4) and Auro 13.1 (7.1+5+1) Speaker Setups
    While Dolby Atmos provides speaker setups based on 5.1 and 7.1 surround, the positioning of the overhead speakers varies greatly, only provides two layers (missing the crucial Height layer) and cannot reproduce a cohesive sound field due to the overhead placement only. "
    Navn:      Auro 3D 13.1.png
Visninger: 196
Størrelse: 226.8 Kb
    Siste redigert av Sven_Palvig; 05.08.2018 kl. 10:30.
  12. #52
    May 2011
    Tagget i
    3 Innlegg
    Torget
    Min bekymring var tydeligvis ikke overdreven.
    Du kan åpenbart ikke reddes. Fortapelsen er et faktum.
    Synd at det måtte ende slik.
  13. #53
    Feb 2002
    Tagget i
    1 Innlegg
    Sitat Sitat fra AndersR Se Innlegg
    Jeg er skam reddet.
    Du mener, at jeg går fortabt, fordi jeg synes at Auro-3D er godt og bedre end Dolby Atmos, fordi Auro har brugt betegnelsen for deres top højttalere for VOG, "Voice of God"?
    Jeg mener seriøst, positivt ment, , at du skulle studere din Bibel noget mere, hvis du mener, at det seriøst kan fjerne min Frelse, at jeg videre skriver beskrivelsen "Voice of God". Jeg valgte i øvrigt, at sakse det ud, i det sidste indlæg, med "Voice of God", for ikke at støde dig. Men jeg er glad for, at du læser med.
    Synder du virkelig ikke?
    Hvis det var min eneste synd, at skrive "Voice of God", var jeg en lykkelig mand!
    Romerbrevet 10:9-10
    Bibelen (1992):
    For hvis du med din mund bekender, at Jesus er Herre, og i dit hjerte tror, at Gud har oprejst Ham fra de døde, skal du frelses. For med hjertet tror man til retfærdighed, med munden bekender man til frelse (v11) for Skriften siger: »Ingen, som tror på Ham, skal blive til skamme.«
    King James Version (1987): That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved. For with the heart man believeth unto righteousness; and with the mouth confession is made unto salvation.
    Når man tror på korset og at det er Jesus der Frelser og der kun er den vej til Frelse, er man Frelst og ens synder er fjernet helt og aldeles. De er visket ud. De synder man gør i dag, bliver også slettet og de syndere vi kommer til at gøre i fremtiden, bliver også slettet, så længe vi tror på Jesus som frelser. Det betyder ikke, at vi bare skal være ligeglade med at synde.
    Fordi vi Tror, er vi desværre ikke blevet fejlfri, og det skal man være klar over! Vi synder stadig væk og forhåbentlig bliver der færre af dem hele tiden.
    Siste redigert av Sven_Palvig; 05.08.2018 kl. 18:46.
  14. #54
    May 2011
    Tagget i
    3 Innlegg
    Torget
    Jeg hviler min eske.
  15. #55
    Feb 2002
    Tagget i
    1 Innlegg
    Det forstår jeg ikke?
    Ok. Jeg har googlet ordet eske og på dansk betyder det kasse.
    Siste redigert av Sven_Palvig; 06.08.2018 kl. 01:20.
  16. #56
    Sep 2013
    Tagget i
    0 Innlegg
    Auro 3D er nok bedre enn Atmos, men ulempen er som nevnt før at det er for få filmer som kommer til dette formatet at det er verdt tid å investere i det dessverre.
    Atmos er bransjeledende og derfor den standarden jeg forholder meg til. Blir litt slik som å sammenligne DVD HD og Bluray, Bluray vant til slutt. Og VHS vs. Betamax, ikke alltid det beste formatet som vinner format-krigen, men det som er rimeligst til konsumer-markedet og har best tilgang til utvalg.
    Mange kino-filmer kommer med Atmos på kino, men på Bluray så er de kjipe og har knappt 7.1 surround.
    Stue1/stereo: Dali Epicon 6, NAD C388, King Cable Silver Code HT-kabel.
    Stue2/hjemmmekino: Epson LS-100, Quad Z4, Quad ZC, Nad C368, Yamaha CX-A5100, Forsterker endringer kommer, Sony UBP X800, 2x 12" Adam Audio sub, 4xCanton Vento 816 for atmos og bak, Kabling er PA
  17. #57
    Mar 2016
    Plankebyen
    Tagget i
    2 Innlegg
    Me synes Auro3D gjør en flott jobb med oppmiksing av Netflix sitt kjipe 5.1 kunne ikke levd uten
  18. #58
    Hifi-entusiast stianG's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    Jeg har brukt Auro 3D i et par år, og er utrolig godt fornøyd. Systemet brukes hovedsakelig til musikk som opprinnelig er 2 kanals, og auromatic gjør en super jobb med upmixing! Kommer nok aldri til å gå tilbake til stereo igjen selv om hovedkilden er vinyl. Bruker også auro 3D på netflix/hbo/amazon med gode resultater.
    Kjører et "not recommended" oppsett med 4.4.1 med Quad 2905 i front og els 63 bak samt noen små Dali som høydekanaler. Har aldri likt senterhøyttalere, og en ekstra 2905 hadde sperret for lerretet. Lyngdorf FR-1 er bestilt, så dali blir erstattet snart. Denon X8500 og Rogue M-180 som effekt på frontkanalene.
    Quad foran og Quad bak
  19. #59
    Feb 2002
    Tagget i
    1 Innlegg
    Navn:      Dolby Atmos Demo Disc 2015.jpg
Visninger: 156
Størrelse: 62.3 Kb
    Dolby Atmos Demo Disc 2015 har jeg og jeg bruger den tit med nogle udvalgte sekvenser. Afspillet med Dolby Atmos. Men det skulle i går prøves i stedet for Atmos så med Auro-3D og det gav et løft, synes jeg. Jeg synes, at det hang bedre sammen og der skete mere rundt om mig. Højdehøjttalerne front gør det så godt.
    Det er rigtig ærgerligt, at Dolby Atmos står så stærkt. Jeg vil i hvert fald bruge Auro-3D på dem der ikke har Atmos. Måske alle. Det vil tiden vise.
  20. #60
    Feb 2002
    Tagget i
    1 Innlegg
    Laban, du må endelige bidrage med din erfaring, når du får en center High.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
