Resultater 1 til 2 av 2
Abonnér på denne tråden
  1. #1
    Hifi-entusiast pcnr's Avatar
    Jan 2009
    Tagget i
    0 Innlegg
    Hva er forskjellen på Pioneer BDP-51FD og LX71?
    Vurderer å kjøpe meg Blue-Ray-spiller, men lurer på hva egentlig skiller Pioneers to mest aktuelle modeller i praksis på lyd og bilde.
    Er det kanskje på lyddelen den dyrere versjonen skiller seg ut? Mulig det er litt upløyd mark dette, men har noen her testet disse mot hverandre?
  2. #2
    Apr 2006
    Tagget i
    0 Innlegg
    Hei. Fra AVS forum så finner du dette (05FD er LX71 hos oss):
    http://www.avsforum.com/avs-vb/showthread.php?t=1054927
    Jeg valgte derfor 51. Jeg testet de ikke mot hverandre. Pengene dine avgjør
    Veldig fornøyd. Fikk endelig HD lyd, men venter på DTS Master HD oppgraderingen.
    Bra oppgradering på bilde også fra PS3. Bruker den ikke som CD spiller.
    DIFFERENCE BETWEEN 05FD & 51FD
    Internal differences:
    -05FD has higher quality analog component video DAC.
    -05FD can use HDMI for audio WITHOUT using HDMI for video. 51FD requires you use HDMI for video in order to support HDMI for audio.
    Cosmetic differences:
    -05FD has touch capacitance controls vs. buttons on the 51FD
    -05FD has glossy black metal front plate (likely to enable touch cap.) vs. glossy black plastic front plate on the 51FD
    -05FD has gold plated rear terminals vs. standard terminals on the 51FD
    -05FD has primarily gold highlights vs. silver highlights on the 51FD
    -05FD has amber LED display vs. white LED display on the 51FD
    -05FD remote has metal buttons vs. plastic buttons on 51FD - enter button feels cheap on both, however.
    -05FD has Elite badge, 51FD does not.
    Other differences:
    -05FD has a 2yr warranty, 51FD only has a 1yr warranty.
    Non-differences:
    -Both have the same analog audio DACs
    -Both have identical output quality over HDMI (Audio & Video)
    -Both have the Pioneer-specific PQLS jitter-elimination circuit
    -Both have a general jitter-reduction circuit
    -Both support the same sound formats, have the same outputs, and support the same features in software
    -Both are of the same general build quality
    -Both use the same firmware
    Adyton Imagic 1.6, Audio Physic Luna x 2, Burmester 082, Copland 823, Audio Physic Center II, System Audio SA208, Yamaha surround, Rotel RMB-1066, Mitshubishi HC7800D, Dreamscreen 106" Nordost Red Dawn XLR, Nordost Blue Heaven RCA, Nordost Red Dawn HT kabel, Transparent Musicwave Plus, T+A Power Four strømkabler
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
