Jeg har brukt MediaMonkey til å rippe flac. Denne har mulighet for "Secure Read" og å verifisere rippede spor mot en database på nettet. Går dette gjennom uten feilmeldinger slår jeg meg til ro med at det ikke kan bli bedre. Men om det finnes bevist bedre rippe programmer er jeg åpen for å bruke de.
Dette gjør alle anstendige CD-rippere. Dette er nøkkelinformasjon fra dBpoweramp
Digitally rip audio CDs without quality loss,
Secure (error free rips) our extensive tests highlight CD ripper as the securest of the secure,
Fast CD Ripper is as fast as they come,
Encoders practically every type of audio compression supported!
Meta Data track names, composers and high resolution album artwork,
PerfectMeta™ uses 5 meta data providers (AMG, GD3, SontaDB, Musicbrainz & freedb)
DSP Effectssuch as ReplayGain, Volume Normalize, or Graphic EQ
[Power Pack Option],
Multi-CPU Aware every last ounce of CPU horsepower is used [Reference Option],
Profiles store complete configuration settings with profiles [Reference Option],
Advanced C2 pointers, drive offset removal, audio cache defeating, HTOA
[Power Pack / Reference Options],
[Multi Encoder] encode to two formats at the same time,
All Windows from Windows XP, Vista and Windows 7,8 all supported.
