Commodore iMac?
baluba
Kopervik og Bergen
Commodore USA is a new company that has licensed the Commodore name from Commodore Gaming, which makes games for PCs and consoles. The PC company is trying to invoke the glory of the Commodore 64's past to promote the new PC. On its Web site, the company shows an image of the old Commodore 64 with the caption "you loved us then," and then an image of the new PC, with the caption "you'll love us again."
The device is small, measuring 17.5 inches (0.44 meters) wide and 2 inches (0.05 meters) tall, Commodore said. "It's designed to take up far less room -- and use far less energy -- than any other desktop computer," Commodore USA said. The PC will run the Linux, Windows and Mac OS X operating systems.
http://www.pcworld.com/article/191896/commodore_64_awakes_from_slumber_with_makeover.html
http://www.commodoreusa.net/os.html
Dette er begynnelsen på... hva?
DSP
Noe som atter en gang vil gå konkurs...
Fenalaar
Nja - det er vel snakk om at maskina kan brukes som en Hackintosh - dvs. at maskinvaren funker.
Det er jo bl.a. en del Dell som funker på samme viset.
Litt uforsiktig av "det nye Commodore" å gå ut å reklamere for at slikt er mulig, men de definerer det jo slik at
We do NOT sell, install, support, promote, repair or deal in any way with products made by Apple, including any hardware or software. If you would like to purchase any Apple products just head over to one of the Apple locations or visit them online.
De selger heller ikke maskina med EFI, slik som Psystar gjorde.
Extensible Firmware Interface is a revolutionary standard to manage the booting process of next-generation PCs in a modular, interactive way. EFI standards allow the user to boot multiple operating systems, with a fully graphical interface and instant recognition of the peripherals. This feature requires the purchase and installation of a small, internally mounted module, supplied by others, that connects to an available motherboard USB header socket.
Litt risky business å erte på seg "ulvene" til Apple, men her er det en sjanse for at de sniker seg unna...
Tuxflux
De kan nok forvente at saftig søksmål fra Steve Jobs og Co. hvis de fortsetter med den markedsføringen i hvertfall...
baluba
Kopervik og Bergen
Jeg vil anta at det er hardware-basert kompatibilitet med hack i bios, men det kan jo godt hende at dette bare er en maskin som er egnet for hackintosh. Men siden det ikke nevnes med et ord så er det lov å håpe. Trøbbel med Apple kan de nok få, men det er neppe ulovlig å lage hardware som er kompatibelt.
Fenalaar
Det er det ikke- Fra siden til Commodore (om EFI, som du må ha for å få MacOS til å boote):
Det er her problemene med EFI kommer inn. Fra den rettslige forføyningen som ble servert til Psystar (som var siste strået som knekte ryggen på Psystar):
Circumventing any technological measure that effectively controls access to plaintiff’s copyrighted Mac OS X software, including, but not limited to, the technological measure used by Apple to prevent unauthorized copying of Mac OS X on non-Apple computers
http://www.theregister.co.uk/2009/12/16/psystar_apple_injunction/
Dermed vil en gå på en smell, dersom en prøver å selge en maskin ferdig med EFI innebygget.
Johan-Kr
nma
BIOS-utskiftningen i PC'er går bare raskere og raskere, og innen et(?) års tid vil alle nye PC'er komme med EFI. Det er ikke dermed automatisk sagt at OSX virker rett ut fra esken, men om hardwaren er kompatibel med de innebygde driverne i OSX så er det ingen sak å få OSX til å fungere 100%. Neppe så elegant at jeg tør kjøpe en hackintosh til bestemor, men for de fleste andre burde dette være null problem.
baluba
Kopervik og Bergen
For å si det slik, på den måten har de fleste råd til en stasjonær supermac. Å bygge selv basert på kvalitetskomponenter vil nok uansett svare seg, selv om designet på gode pc-kasser ofte ikke er særlig voksent. Men det finnes nok lekre pc-kabinetter som holder mål også. I dag har jeg en følelse av at min neste mac blir hjemmebygd.
