Resultater 1 til 4 av 4
Abonnér på denne tråden
  1. #1
    Hifi-entusiast
    Jan 2009
    Tagget i
    0 Innlegg
    Ytterst aktuelt produkt for pc basert avspilling!
    http://www.analogresearch-technology.net/LEGATO.html
    Her har du ett produkt med clock og psu av meget høy kvalitet, som gjør det mulig å bruke SPDIF protokoll.
    Støy fra pc er da ett nesten ikke eksisterende tema lengre ?
    Do you like Phil Collins? I've been a big Genesis fan ever since the release of their 1980 album, Duke. Before that, I really didn't understand any of their work. Too artsy, too intellectual. It was on Duke where Phil Collins' presence became more apparent. I think Invisible Touch was the group's undisputed masterpiece.
  2. #2
    Feb 2008
    Tagget i
    0 Innlegg
    Any questions I can answer for you?
    Pat
  3. #3
    Hifi-entusiast
    Jan 2009
    Tagget i
    0 Innlegg
    Oh, your here. Nice
    I have looked at the measurments, looks solid.
    My dac only has coax, toslink and usb inputs.. Is it possible to connect the legato to my dac with coax for example?
    I really dont understand all the technicalitys.. What is the difference between the protocols spdif, aes-ebu, coax, toslink etc ?
    What is the optimal approach to computer based audio in your world?
    Thanks for responding
  4. #4
    Feb 2008
    Tagget i
    0 Innlegg
    The Legato has a coax SPDIF output. It is a true 75 ohm output, transformer-coupled, via a BNC connector. Since most of you who have a DAC are stuck with the inadequate RCA jacks, we provide a cable and a BNC-RCA adapter. While this is not the optimum configuration, it will perform better than a cable with RCAs on both ends.
    The differences between coax and AES/EBU are not much. Impedance, connector type, signal level are slightly different. TOSLINK is an optical interface, that has some troubling problems. Yes, it provides galvanic isolation, but has other problems, that make it the least desirable of the group.
    To be honest, we are not experts in computer audio. Our expertise is in digital transmission. The only advice I can honestly give is to save your money, and buy a Mac. (No, no one here can afford one. So much for getting rich in audio!) It has been our experience, as well as lots of our customers, that PCs yield highly variable results, while the Macs always work great.
    I would advise you to look upon the computer as the transport. Use it for a music server only, not something to play games and surf the Web, at the same time.
    Even if you do buy a Mac, get the most memory, biggest HD and fastest CPU you can afford. The guy who writes the code says "You need enough horsepower to overwhelm the problems in the s/w." As you can imagine, PCs need lots of horsepower, to begin to sound good.
    That is the extent of what I can tell you about computer audio.
    Pat
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
