Hjelp til readynas duo
dipoler
Har kjøpt Readynas Duo men greier ikke å finne serveren med søkerverktøyet RAIDar ?
Har prøvd å lage untak i brannmuren men det hjelper ikke .
Er det noen som har en ide hva problemet kan være ?
MVH Terje
bluesman
Ha'kke peiling sjøl,men søkte litt på nett og fant vel noe det går å begynne med.Og så dukker det vel opp noen som 'kan litt'. ???
Lykke til!
RAIDar is unable to find the ReadyNAS on my network. How do I resolve this?
Make sure all the software firewall is turned off or disabled.
Make sure UDP ports on the routers are not blocked.
Make sure both client PC and the ReadyNAS are in same subnet.
How do I direct-connect between ReadyNAS and PC/Mac?
Assign a static IP address to the ReadyNAS, and set your PC with a static IP in the same subnet.
Connect the ReadyNAS and PC NIC using a straight or crossover Ethernet cable.
Power on the ReadyNAS and scan with RAIDar to locate the ReadyNAS.
http://www.readynas.com/forum/faq.p...eadyNAS_on_my_network._How_do_I_resolve_this?
