Resultater 1 til 4 av 4
Abonnér på denne tråden
  1. #1
    Banned
    Oct 2006
    Tagget i
    0 Innlegg
    Hei noen som kan justere bias på min Cayin forsterker!
    Hei dette med justering av bias er nytt for meg og på cayin så har jeg ingen bruksanvisning på dette.Er jo en del oppegående mennesker her inne som kansje vil hjelpe
  2. #2
    Rubinmedlem JanR's Avatar
    Jan 2006
    Tagget i
    0 Innlegg
    Det som hadde vært kjekt da er info om ampen, type, link til amp osv osv osv.
    /jan
    Nomen mihi Legio est, quia multi sumus
  3. #3
    Banned
    Oct 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra JanR
    /jan
    link til forsterker
    http://www.sparkaudio.com/en/products/A-88T.html
    Her kommer en lang forklaring på hvordan bias justeres...
    This amp is NOT AUTOBIASING. I owned a Jolida 302 also and now the a88t and it needs at least 10 hours breakin before sound improves.
    Here's the biasing instructions graciously provided to me by another Cayin owner:
    "Unless you swap out tubes, you do not need to bias the amp more than once every few months. Anytime you change tubes however, you must re-bias.
    If you can go to the Acoustic Sounds web site and enter Cayin in your search...you will find the A-88T and can click on that model. Then find hi-res pics that show the underside of the amp and it’s circuits. It will be a big help if you can look at the picture on the Acoustic Sounds site before you start to see “what’s what”.
    Be careful of course when doing this. Be certain the amp is turned up on its side (supported by something) - The amp needs to be up on it's side and plugged in, but no interconnect or speaker cables should be connected- it should just be plugged into the wall....
    Okay, the directions:
    You will see under the tube sockets where the wires are soldered. You will
    also see the blue plastic pots (with screwdriver slots on their tops) next
    to the sockets.
    You want to use the blue wires on the front two Kt-88 (front of amp) and
    use the Orange wires on the rear two Kt-88's as your + test points. They
    are the only wires that are single wires on the sockets and have a double
    solder connect. The second soldered connect (with NO wire attached) is the
    test point for the + Positive probe of your multi-meter...The - Negative
    test probe attaches to any black (- neg.) speaker terminal on the rear
    binding post. Doesn't matter which one.
    The test point is 0.4V or 400mV on your meter. Make sure to set it for
    Volts or mVolts DC- NOT Amps or Voltage AC. I use a Sperry DM 4100A
    meter purchased from Home Depot or Lowe's.
    This may seem a bit confusing. But if you pop the bottom cover, you'll see
    the KT-88 sockets from the bottom- then locate the Blue (front of amp) and
    orange wire (rear of amp) and you will also see the 4- blue plastic pots for
    adjustments. One by each tube socket. It won’t take much turning to find
    the 0.4V...Adjust slowly with the probe on the test point and you'll see that.
    Allow it to warm up for about 10mins before checking the bias. After
    you've made the initial adjustments, wait 10 mins. and check again for drift.
    They will settle a bit, but not a lot. You can fine adjust at this point"
    Having said that, don't judge your amp untl you get it some time to really burn-in or perhaps tube role.
    skal prøve og finne noen bilder hehe
  4. #4
    Hifi Freak Sleiven's Avatar
    Dec 2003
    Tagget i
    0 Innlegg
    OBS. Veiledningen her feil!!!
    Man må ALDRI frakoble høyttalerne fra en rørforsterker. Utgangstrafoen får overspenning og kan kortslutte og hele forsterkeren svis av!!
    Om det går godt utenhøyttaler har man hatt griseflaks, noe man ikke bør satse på...
    Sleiven
    &quot;Not everything that can be counted counts, and not everything that counts can be counted&quot; <br />-ALBERT EINSTEIN
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
