F...en og......
WayAhead
Sky No Limit....
Thank You Streaming Dritt....
https://tracks.technics.com/GB/restriction/closed
Technics TRACKS was launched in 2015 to complement the premium products from Technics and to provide a consistent high-end audio experience.
An actively managed portfolio policy is a part of our strategy to ensure that we deliver high-end services and products our customers expect from us. Following the market developments of streaming and downloading services as well as the general industry trends in the high-end audio segment we have decided to discontinue the Technics TRACKS platform and exclusively focus on our digital and analogue premium audio devices.
The download service will therefore end on the 30th of June. All customers have been informed by a separate email. Purchased music files can still be downloaded within this timeframe. Valid vouchers can be redeemed until the 31st of May.
Technics TRACKS has reached an agreement to further host the platform at the digital music and radio services "7digital". Currently, registered users on Technics TRACKS can sign up with their login data for the 7digital platform to access high-resolution music.
Technics TRACKS managed to attract and to gain the respect of a community of distinguished music lovers. We are proud of that and very grateful to all fans and subscribers of the platform. We trust in your loyal followership in our Technics products as we will continuously launch highlights in the high-end music sector because we believe in the infinite possibilities and enormous power of music.
If you have additional questions, need further assistance or contact information please visit our help section.
Thank you for supporting Technics TRACKS.
G
Gjestemedlem
Kanskje velge en litt mindre proprietær løsning neste gang? ... Spotify bare for å ta et tilfeldig eksempel... og for dem som "kjøper" enkeltfiler .... one born every minute.
WayAhead
Sky No Limit....
Dette er ikke døden, HD Tracks er vel mye større og oppe å går. Technics var kanskje bedre på nyere materiale, mer orientering mot artister jeg har sansen for og hadde et mye bedre interface og effektivere søkeløsning men siden det kun var brukere bosatt i UK, Tutonia og Nihon som fikk handle der er det sånn sett ikke noe tap men at de legger ned er et svært dårlig tegn i tiden.
Spotify HQ eller Tidal HQ er ikke noe alternativ, til det gir disse strømmetjenesrene alt for dårlig lyd til sammenligning.
Da gir filkkjøp fra iTunes i Apple Lossless format mer tilfredsstillene løsninger. Det har vel også vært snakk om at de skal levere ALAC og eller FLAC formater.
Twsts
Bodø
Hva gjør at en lossless fil kjøpt hos Apple gir bedre lydkvalitet enn samme fila streamet fra Tidal?
WayAhead
Sky No Limit....
Det jeg opplever med Tidal er at 3D lydbilder består av "blockiness", la oss tenke oss at det er et 3D bilde bestående av Rubicks kuber hvor noen av bitene på hver kube er fjernet for å lage et 3D bilde. Det høres ut som om filen har vært sterkt komprimert og pakket ut i mye dårligere oppløsning og så forsøkt å prosessere den tilbake til originalen. Dårlig codec?
Selv vanlige filer kjøpt på iTunes har ikke denne artifacten.
Apple kjøpefiler har ikke disse artifacts selv i standard kvalitet.
Eksempel på standard/Lossless:
Akwaaba (Diesler feat. Laura Vane Club-Remix) Standard: 256 kbps AAC lydfil
Akwaaba (Diesler feat. Laura Vane Club-Remix): Apple Lossless: 932 kbps
Har man kjøpt filen er "utpakkingen til Lossless er gratis og skjer med et klikk. Ingen ekstra kostnad.
Det utpakkede Lossless formatet kan typisk være mellom 1000 og 2000+ kbps
Spotify er "The Mud Club" i forhold.
iTunes filene er ikke perfekt sammenlignet med HiRes nedlastede filer men i det minste irriterer jeg meg ikke over "artifacts" i lyden.
lovemusikk
Enig med deg..er ikke overbevist over lyden på Tidal
Dazed
Absolutt alle HD-filer jeg har kjøpt har vært nøyaktig de samme (samme bølgeform, samme dynamikkområde) som 16/44-utgavene av samme låter, men upsamplet så de bruker mer båndbredde og tar mer plass. Ganske bortkastet, altså.
Forøvrig stiller jeg meg ganske tvilende til at noen hører forskjell på 16/44 og f.eks. 24/192 uansett, men som sagt har alle HD-filene jeg har vært borti vært "juks". Det hadde vært stas å få høre noen skikkelige DSD-"mastere".
Ang. 16/44 "lossless" fra streamingtjenestene, så er det nok det samme om stream-en kommer til DAC-en din fra Tidal, Quobus, Apple eller whatever. Gitt at det er den samme innspillingen.
WayAhead
Sky No Limit....
Nope, har verifisert samme låten fra HD tracks 96/24 FLAC nedlastet og i alle versjoner hele veien rundt til Tidal og forskjellen fra 96/24 er mildt sagt enorm.
Klarer du ikke å få fram den enorme forskjellen vil jeg tro du ikke har "gear" av kapabel kapasitet.
Dazed
Ah, en gammel klassiker, der altså. ;)
Svarer med en annen: Hører du disse enorme forskjellene blindt? Har du sammenliknet bølgeformen mellom filene og sjekket den dynamiske spennvidden. Kan det være at du "hører" at 24/96 låter mye bedre enn 16/44 fordi du "vet det må være slik"?
Jeg har ikke testet alt for mye, men har en 3-4 album i 24/192 som jeg har sjekket.
WayAhead
Sky No Limit....
Blindhet er ikke nødvendig for å avsløre blockiness og at det hele blir slitsomt, direkte plagsomt å høre på.
Anbefaler deg å hive ut alle equalizerene (DACer og annen drit) du har mellom lydkilden og effektforsterkeren så kan det hende du ser lyset du og....
WayAhead
Sky No Limit....
Bruker MACen og funker det ikke optimalt med den er Tidal likevel ikke bra nok.
Kjører jeg ukomprimert streaming fra Neil Young sin site finnes overhode ingen artifacts av noe slag, heller ikke med snippetsene på HD tracks eller X-Technincs downloads. Prima vare.
BeetleBug
Er bare å bytte codec for avspilling av Tidal. Flere mediaplayere tilbyr dette og selv foretrekker jeg Audirvana. Med Audirvana får man en bit perfect tjeneste som også har en utmerket remote funksjon som Tidal fortsatt ikke har klart å tilby sine kunder.
En ukomprimert WAV eller AIFF fil vil vel alltid spille i 1411kbps lik en CD plate. Apple Lossless vil vel variere noe med musikkvalg (https://www.kirkville.com/an-overview-of-apple-lossless-compression-results/) men vil typisk ligge mellom 800 og 1000kbps.
-BB-
1/2 Tam
Bruker du Mac som forforsterker? Og litt nyskjerrig på hvilke høyttalere du hører på som avslører disse enorme forskjellene?
Dazed
Pass på så du ikke lager svimerker i taket med den sigaren. ;)
WayAhead
Sky No Limit....
Kjører direkte i effektforsterkeren og det gir WYHWYG.
Ikke noe forringende ledd i mellom og får en ikke optimal gjengivelse den veien vil det ikke være aktuelt å vurdere slike tjenester.
WayAhead
Sky No Limit....
Har verdens mest avanserte brannvarslingssystem pga mitt uerstattbare lydsystem så sigaren kommer nok til kort :)
Har riktignok ikke overrislingsanlegg lenger slik jeg hadde i min forrige bolig men har en Halonflaske som backup :)
1/2 Tam
Du mener altså at dac i Mac er bedre enn en ekstern dac?
Dazed
Bruker ikke DAC i MAC. MACen bare vidreformidler de digitale signalene (untouched) rett i DACen i effektforsterkeren og den driver effektforsterkeren direkte.
Så min DAC er en equalizer, men ikke den som sitter i effektforsterkeren din? Hva for en forsterker er det, forresten, med dac, men ikke forforsterker? Høres litt rart ut.
1/2 Tam
Effektforsterkeren kan jo ikke fores med digitale signaler?
Trondmeg
Bastant bedreviting gjør meg alltid skeptisk :).
1/2 Tam
Enten så besitter du en effektforsterker som vi ikke har hørt om enda, eller kanskje du har konstruert den selv. Uansett så har du en DAC i mellom PC og effektforsterker.
1/2 Tam
Her skriver du jo at du ikke har DAC. Sånn tolker i hvertfall jeg det?
JENO
Saksvik - Trøndelag
Dette er helt vanlig i proverdenen. Man kan ha lange kabelstrekk digitalt (billigere og enklere enn masse kobber) og man får bedre signal/støyforhold.
Eksempel: K Series - Powersoft Audio
Audiofilt eksempel: https://www.stereophile.com/solidpoweramps/nad_m2_direct_digital_integrated_amplifier/index.html
(Hva skjedde forresten med Zetex DDFA-teknologien..? Syntes dette virket lovende)
Om det er bedre å ha DACen integrert i kilde, effektforsterker eller frittstående i egen boks med kabler i mellom, kommer selvsagt an på hva som er tilkoblet og kvaliteten på innmaten i de forskjellige boksene. Jeg tror ikke det finnes en fasit her, det er situasjonsbetinget.
Edit: Aktive monitorer med digital input er også et annet eksempel.
1/2 Tam
Da, lærte jeg noe nytt i dag. Er det en tillsvarende forsterker du har Wayahead?
Twsts
Bodø
Styrer du volumet på digital side Wayahead?
oyvjorge
Akershus,Vestby
Jess! Bare å skiftte side eller spor. Slippe alle duppedittene og formater og nettverk ol.
1/2 Tam
Reise seg opp fra godstolen, finne plate i reolene, se på coveret, ta platen forsiktig ut uten å lage fingermerker på rillene, sentrere platen, tre den ned på spindelen, føre armen forsiktig bort på sporet, knitre, knitre, justere hastigheten, sette seg tilbake i godstolen, høre musikk, knitre, knitre, der var den sangen ferdig, eneste som var bra på den platen, reise seg opp fra godstolen, ta av platen, putt den forsiktig i coveret. tilbake til reolene med den, lete etter ny plate, repeter, f..n, lei av all musikken, bestille nye plater, vente, vente, vente.
Om trent slik oyvjorge? ;)
BeetleBug
Bingo! Analog nytelse. Alt skal være så jævlig lettvint for tiden at det oppleves som befriende å sette på en vinyl. Men du glemte å nevne gleden av å studere coveret.
-BB-
OlaR
Helt åpenbart enklere enn å trykke "neste"... :rolleyes:
1/2 Tam
-BB-
Nei glemte ikke det. Står se på coveret, men glemte tørke støv av platen.
Men er helt enig at dette ritualet er en del av gleden med plater:cool:
