mteinum
Neida... siste ut på denne fronten er:
K2 HD MASTERING GOLD CD* (COLLECTOR'S UD)
Du milde :
http://www.elusivedisc.com/prodinfo.asp?number=LIMHD028CUD means the "Ultimate Disc", which is a combination of a 24K gold disc with Resonance Control Coating (RCC), directly burnt from the master disc/hard drive one at a time, then, washed by de-ionized water and finally dynamically balanced and tested and certified to be under 10 Averaged Block Error Rate (Industry standard is 220).
Du milde :
