Gotcha !!!
  • WayAhead
    Sky No Limit....
    Gotcha Today... Sansui Høyttalerkabler....
    Der Schmatten Kari.... Det er et par på Taiwan til salgs for $7,000....
    For Auction: One Pair Vintage Sansui High Efficiency Speaker Cables PS-112C.
    Each cable is 12 meters long (40 feet)
    These cables were designed to bring out the best sound from high-end Japanese audio gear from the 1970's & 1980's.
    I believe these were only sold in Japan; I bought this pair in Akihabara Tokyo in 1979. They cost 12,000 yen (over $100) - which was a lot of money back then! I have NEVER seen another pair of these cables on ebay. (The shorter, 7-meter version, PS-107C, comes up once every 5 ~ 10 years; people have bid as high as $375 for those - and that was back in 2014.)
    These made an incredible, glorious difference in the sound quality of my stereo system. My younger friends (and my brother-in-law with golden ears) can still hear that difference with these cables, but I - having worn hearing aids for 10 years now - can no longer hear the difference (too many years in noisy engine rooms aboard Navy ships). Time to let some other Hi-Fi purest / Sansui collector have the pleasure of owning them. Besides, downsizing in retirement I no longer need 40 foot speaker cables!
    These wide-range cables are serious equipment, designed and built for the dedicated Japanese audiophile in the early '80s. See detailed specifications below. Please see photos for condition. Note that I have never cleaned the ends or replaced the solder on the tips. With the right cleaning solution they should shine bright again, or you can trim the ends and expose 'new' copper - your choice.
    If you google "Sansui high efficiency speaker cables" you will find the information shown here along with comments and testimonials from other users/owners on audiokarma.org.
    Details from the original box:
    Sansui's High-Efficiency Speaker Cable was developed on the basis of our knowledge and know how about the special types of cables, 'primarily those used for telecommunications purposes'. Because of it's excellent transfer characteristics, ultra-low DC resistance and super-wide frequency range, the new Sansui cable is ideal as an interface between advanced "DC" configuration amps and contemporary wide-range speaker systems. It's major features are:
    1. Ultra-wide frequency range of DC (Zero Hertz) to 400kHz (+/-0.5dB), and phase response of DC to 300 kHz (less than 10 degrees).
    2. Ultra-Low DC resistance (8.7m ohms/m for "+"cable and 11.6m ohms for "-" cable.
    3. Sansui exclusive three layer braided conductor construction for best transfer characteristics.
    4. Ideal characteristic impedance of 12 ohms for best impedance matching with amp and speaker.
    5. Un-plated wire surface for improved tone quality.
    6. High-Density braided conductor (90%) coverage for minimum skin effect, proximity effect, crosstalk, and noise pickup.
    7. 99.96% or more pure elastic copper wire.
    8. Terminal ends molded with elastic PVC.
    Actual wire construction from outside casing to inside core:
    1. PVC jacket
    2. Polyester Tape
    3. Braided shield (-)
    4. PVC Insulator
    5. Braided Conductor (+)
    6. Polyester tape
    7. Braided Conductor (+)
    8. PVC core.
    From an old Sansui brochure:
    1. PS107C/PS112C Super High Fidelity Speaker Cables
    2. Speaker cables for accurate transfer of HighFidelity information.
    3. Three braided conductors, each insulated from others and coaxially woven (Sansui exclusive)
    4. Super low DC resistance.
    5. Low AC resistance for improved frequency response (+/0.5db at DC400kHz)
    6. Effective shielding of external noise
    7. The PS107C and 112C come in 'pairs of cables' in each box.
    WayAhead
    Sky No Limit....
    Well, todays D Day... fikk kablene i dag og har kjørt en evaluering på 1974 anlegget med Linærspilleren som kilde.
    Har lagt ut et videoklipp nederst der jeg har forsøkt å formidle noe av det jeg har hørt på / verifisert.
    Kort oppsummert, fenomenalt lineært løft som forventet, noen detaljer, beefier, mer artikulert bass, mellomtone og luftigere diskant- Har aldri savnet noe i disse regionene men det er liten tvil om effekten disse kablene gir. Jeg tror det handler mest om at de ikke gjør noe galt men slipper fram det som skal fram, ingen lumske impedanskruseduller. Det er slik de er spekket og skal fremstå.
    Bassgitar/basstrommen sitt samspill på Beatles studioplater åpnet i et nytt vindu. På Lucy In tHe Sky with Diamonds kan en tydelig høre at Lennn synger med vibrato i stemmen når han synger alene dette. Blåsverk låter generelt sett fett - ubetinget.
    Filmklippets lyd klarer naturligvis ikke gjengi detaljene slik jeg hører de men deler det likevel.
    Løp og kjøp? Ingen anelse, det er vel omtrent like mange øreparvariasjoner som det er -/fi kombinasjoner der ute og opphøyes det hele i Nte så det er sikkert ikke gitt at andre får samme erfaring som meg men at kablene er bra og leverer er det ingen tvil om. Dessuten er de tekniske kunststykker, :)
    "Spillelisten:"
    Beatles,
    Good Morning Good Morning
    Within Me Within You
    Marilyn Horne
    Klassisk (Erato)
    Ronnie Aldrich
    Togetherness, Klassisk, Piano DECCA Phase 4
    Will Glahe
    Bierstuben Ompa kutt, the skaters waltz.. DCCA Phase 4
    Beatles Live, Starclub, Desember 1962 Fab drive for å høre variasjoner.
    Little Qeenie...
    H
    Hifibasillen
    Grattis,Fornøyd? hva betalte du? hva gjør disse kablene i forhold til andre kabler og hva jeg har lest fra din tidligere post?
    WayAhead
    Sky No Limit....
    Bør vel først nevne at jeg ikke er noen kabelhysteriker men kjøpte denne først og fremst for å finne ut om denne avanserte konstruksjonen gjorde en forskjell, noe jeg ikke var i tvil om.
    Følte intet behov for å "oppgradere" da anlegget spiller framifrå likevel. Førsteinntrykket var at dette er "over the top" og at det kanskje var for mye av det gode. Får se etterhvert. Forskjellen ved avspilling av klassisk er direkte skremmende.
    Ja absolutt
    hva betalte du?
    Middag på byen 4 2.
    Ut fra en teknisk betraktning er formålet en total linearitet fra DC til 400 kHz noe som er målt og verifisert. Dette gjør at det ikke finnes "strøimpedanser" over frekvensområdet som kan virke som "choker" og redusere ledningsevnen for deler av det hørbare frekvensområdet. En kan vel sammenligne det med et vannrør som er helt glatt innvendig vs et med rustskall og andre hindringer som reduserer "ledningsevnen" for å beskrive det litt enkelt. Selve konstruksjonen ser også ut til å være designet for å eliminere strøfelt.
    Opplevelsesmessig er det en lineær økning av lydopplevelsen fra bass via mellomtone til diskant.
    Bass: Strammere, kraftigere, mer artikulert.
    Mellomtone: Det samme
    Diskant: Nivå nokså uforrandret i "styrke" men den er mer transparent og oppløst.
    Jeg vil anta at totalt så vinner man mellom 1 og 2 generasjoner i lydkvalitet med denne kabelen sammenlignet med andre jeg har (ikke fanatisk) testet.
    Den lineære forbedringen gjør at man ikke opplever noe kompromiss i forbedringene. Det er et genuint løft over hele spektret og ingen negative faktorer registrert.
    Da jeg ble klar over denne kabelen har jeg brukt mye tid på å se om andre produsenter (alle slags kabler/produsenter) har noe tilsvarende men har ikke klart å finne det. Noen av de oppgir lignende specs og at teknologien også er hentet fra telecomindustrien men kabellayouten et absolutt helt forskjellig så karakter/ytelse er nok ikke lik. Jeg visste at Sansuikablene var vanskelige å slå kloa i, de ble visstnok kun solgt i Japan en periode på 70 tallet - myntet på HiFi galninger. Derav kikket jeg etter alternative konstruksjoner som kunne testes ut men fant aldri noen. Sansuikabelene starter med en PVC senterkjerne, ikke leder. Deretter to adskilte skikt med flettede (+) ledere og utenpå der nok et adskilt flettet sjikt som utgjør (-) lederen.
    H
    Hifibasillen
    Jøss artig da lærte jeg litt idag også =) takk for utfyllende info og lykke til med lyden =)
    WayAhead
    Sky No Limit....
    Ja, håpløst å formidle resultatet men gjør likevel et nytt forsøk.... om dere gidder å høre igjennom så legg merke til bass / Vokal-kor om ikke annet dette klarer seg rimelig greit selv om det ikke er i nærheten av "the real thing"....
    Me full bakoverschWeiZ i hvertfall...
    1974 forsterker og høyttalere, ca 1980 lineærspiller - ca 1975 høyttalerkabler som vist over....
    WayAhead
    Sky No Limit....
    Gottcha #2
    Kom tilfeldigvis over en annen original Sansui høyttalerkabel som jegaldri har hørt om eller kan finne noe om på nettet.
    Det er en mer tradisjonell konstruksjon med OFC, mangetrådet fin men cordellene føles nokså stive. Tverrsnittet er 2.5 mm2
    P
    WayAhead
    Sky No Limit....
    So wHyKnott...?
    Nærmere beskrivelse i første posten i denne tråden.
    Jaggu dukka det opp et nytt sett PS-107C, denne gang i 7 meter lengde, de ble laget i hhv 7 og 12m lengder... mmm... jeg tenkte 7m passer jo bedre sånn rent praktisk så jeg klinket til...
    Som nevne ad nett går det vanligvis 10 år eller så mellom hver gang disse dukker opp så jeg knallet til med et par kubanere....
    Wel....
    WayAhead
    Sky No Limit....
    Gotcha !!! soon to be mated with Gotcha-iii
    ToaysDDay.. Kind of...
    Som nevnt for en tid tilbake vurderte jeg å gå ned fra SCI-FI til plain HiFi og nå Scmattn Kari.....
    På tide å tenke litt mer møbel... og plain musikk tenkte jeg så nå blir det bare 4 x 17" mellomtone/bass + noko attåt. 17 tommerene drar fra 0-1000 Hz,
    1977 modeller dat is.
    Well....vI fÅr Ze... når jeg får koblet de opp mot/med Gotcha! II
