Side 1 av 2 12 SisteSiste
Resultater 1 til 20 av 34
Abonnér på denne tråden
  1. #1
    Hifi Freak lovemusikk's Avatar
    Nov 2009
    Tagget i
    2 Innlegg
    USB til DAC Hva er bedre en Biltema?
    Hei hei.
    Har en Biltema kabel på 5 meter pr i dag.
    Hva finnes som er betydelig bedre?
    Kjører det anlegget som står i signaturen.
    Lovemusikk
    Hovedanlegg: Tuner, Heed Obelisk DA, Musical Innovation MI25, Musical Innovation MI18, Uscher Dancer Mini 2 DMD, Kjellerrommet: Marantz CD 17, Bel Canto 2.5, Marantz PM 17, Klipsch RP160M Loftet - billig anlegget : Tuner, Technics og B&W
  2. #2
    Æresmedlem Pink_Panther's Avatar
    Mar 2006
    Tagget i
    0 Innlegg
    Biltemakabelen er en av verdens beste kabler. Laget på samme fabrikk som Nordost.
    Er det fremskritt om en kannibal bruker kniv og gaffel?
    Stanislaw Jerzy Lec
  3. #3
    May 2012
    Tagget i
    0 Innlegg
    20374,- for 0.9 meter.
    Fra brosjyren:
    It all starts with raw materials, I have a vendor partner who I have have taught (and wasted more money than I want to think about teaching them) to make my wire exactly like I want it made, and exactly to my specs, which I then treat with my CryoFreeze™ process as soon as I receive it. So, the raw materials are without peer.
    I then braid this masterpiece of a wire into a proprietary braid so that the conductors are evenly spaced, and arranged in the configuration I want them to be.
    Around this core, I then add many different layers of shielding and damping. Some of the materials I use are carbon fiber, cotton, SPC braid, ERS fabric, Nylon, Teflon, and many more. This damping/shielding arrangement ensures that the inner cores that carry the data and VDC lines are isolated not only from each other, but from any external influences to the cable, be they mechanical, or electrical. In addition, these layers damp the conductors themselves, and prevent micro vibrations inside the cable from affecting the signal. These layers are one of the reasons that the cable takes a while to "settle" back in after it has been moved, or unplugged.
    RASSY DIBO EDT - eta autumn 2013
  4. #4
    May 2012
    Tagget i
    0 Innlegg
    Ps. eg vant ein Transparent kabel til tusenlappen. Såg bra ut. Fin emballasje. Bra kvalitet på pluggene. Ingen verdas forskjell i lyd mot medfølgende kabel. Fås kjøpt hjå Norsk Audio Teknikk.
    Transparent Audio - Transparent Cable Digital Audio Cables and Digital Video Cables
  5. #5
    Nov 2009
    Tagget i
    2 Innlegg
    20.000 er litt drøyt :-)
  6. #6
    May 2012
    Tagget i
    0 Innlegg
    101870,- for 5 meter må vite
  7. #7
    Nov 2009
    Tagget i
    2 Innlegg
    Sitat Sitat fra Pink_Panther Se Innlegg
    Phuu. Kan jeg ikke tenke meg.. Det må dokumenteres da ja!
    Biltema har jeg egentlig i halsen..kastet vekk så mye penger på dritt derfra, at det er trasig.
    Ørnbjørn: 10.000 var og litt drøyt du :-)
    5 meter kabel til rundt 1000.- men hva er best i verden her da?
  8. #8
    May 2012
    Tagget i
    0 Innlegg
  9. #9
    Nov 2009
    Tagget i
    2 Innlegg
    Sitat Sitat fra Ørnbjørn Se Innlegg
    Nei, offa.. gadd ikkje lese mer en et par avsnitt der.. hehe.. drit egentlig i hvordan den er laget, om det er brukt pølseskinn er ikke nøye, så lenge
    det er en kabel som er mye bedre en den biltemakabelen.
    Skal forøvrig teste en annen skikkelig DAC om ikke så lenge, men vis den og svikter/ikke leve opp til ryktene, blir Biltemakabelen dømt av meg, ned mot nivået til
    høyttalerkablene til Europris hehe..
  10. #10
    Hifi-entusiast
    Jul 2009
    Vest-Agder/Søgne
    Tagget i
    0 Innlegg
    Ingen problem med biltema kabel, MEN ikke bruk noe særlig lenger kabel, litt over 5 meter så begynner dem gjerne å svikte, dyre som billige.
    - Evelen
  11. #11
    Nov 2009
    Tagget i
    2 Innlegg
    Sitat Sitat fra Evelen Se Innlegg
    Okai.. Fortæll, som han nrk mannen sier (og Valen) Fortell!!
    Kjører eg 3 meter er den litt kort, men kan gå til nøden. Blir det bedre lydmessig? Evnt Hvorfor?
  12. #12
    Hifi-entusiast
    Sep 2010
    South of heaven
    Tagget i
    0 Innlegg
    Jeg har også en transparent usb kabel til ca 800 kr. Kan ikke si jeg hørte noen forskjell i lyden fra billig-kabelen som jeg hadde fra før. Men den ser i det minste litt mer påkostet ut
    Bladelius Thor MKIII - T+A DAC8 - Gallo Ref. 3.5
    XTZ a100dIII - Tannoy Mercury
    Philips Fidelio X2 - Beyerdynamic DT 770 Pro - AKG K550 - Focal Listen
  13. #13
    Hifi Freak Ulf-B's Avatar
    May 2008
    Tagget i
    0 Innlegg
    Sitat Sitat fra lovemusikk Se Innlegg
    Det henger sammen med USB-standarden.
    F.eks. har USB1.0 en maks lengde på 3m, mens USB2.0-standarden tillater opptil 5m lengde på kabelen. Skal man ha lengre kabelstrekk, er må man skjøte seg frem til ønsket lengde ved hjelp av en USB-hub.
    1) SB Touch m/iPad, Beolab 5
    2) SB Touch, Weiss DAC-1 MkII, Get-boks, Hegel HD20 DAC, Copland DRC-205, Primare BD32, ML 326s, 2x Bryston PP 300 SST, ProAc DB1, REL S3 sub
    3) SB Touch, Benchmark DAC-3 HGC, 2x Benchmark AHB2, ProAc D1, ProAc ER-1 sub, Denon AH-D7000
  14. #14
    Nov 2009
    Tagget i
    2 Innlegg
    Sitat Sitat fra Ulf-B Se Innlegg
    Ja, når du sier det så mener jeg at jeg har lest det for lenge siden.
    Ellers da, du har jo litt peiling. Er biltema godt nok, som jeg kan slå meg til ro med, eller kan det vere noe å hente her også?
  15. #15
    May 2008
    Tagget i
    0 Innlegg
    Takk for tilliten - men dette med USB har jeg ikke forsket veldig mye på. Jeg kjører all musikk og nettradio via Squeezebox - og da går det i trådløst pluss koaks. Men hvis DACen din er noenlunde moderne - d.v.s. at den tar seg av jitter på en allright måte - tipper jeg at du klarer deg godt med den kabelen du har.
  16. #16
    May 2012
    Tagget i
    0 Innlegg
    Det tror eg også. Om du skal brenne av mange tusen ville eg prøvd den først. Mulig opplevd kvalitet er nok til å spandere på seg ein fancykabel.
  17. #17
    Nov 2009
    Tagget i
    2 Innlegg
    Ja, riktig..
    JA, der har vi noe.. om DACen min er god nok? I den forbindelse dukket denne kabelen opp, om den var god nok liksom. Nå skal jeg få lånt meg en DAC snart som skal vere meget god, så da får jeg sjekket den opp mot min nåverende billig DAC.
    Min nåverende trodde jeg var bra, men hadde ikke sjangs da jeg koblet til cd spilleren..da falt cd lyden i grus.
    Her er link til den jeg har.
    Valab WM8741 24bit 192k USB DAC - Dual WM8741 Balanced XLR Output (Black Face) | eBay
    Så kanskje du kan si noe utfra det?
  18. #18
    tce-teams
    Guest
    Monster har jo brae kabler til fornuftig pris spør du meg.
  19. #19
    May 2008
    Tagget i
    0 Innlegg
    Ja, riktig..
    Jeg kjenner ikke denne DACen - men den er mest sannsynlig helt OK til prisen, og sannsynligvis helt OK m.h.t. jitter og slikt. De fleste nyere DACer er det. Du har antageligvis mest å hente på å tenke oppgradering av DACen - den står ikke i stil med resten av utstyret ditt - så kan du jo eventuelt ta kabeldiskusjonen ved en senere korsvei.
  20. #20
    Nov 2009
    Tagget i
    2 Innlegg
    Ja, der har du nok helt rett. Takk for svar.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
