Bryston kommer med en ny serie kabler.
Baard
The old cable was a twin lead side by side so given it's different geometry it has different electrical characteristics than the new cable. New Cable is 4 conductors twisted to provide very low self-inductance.
Bryston SC-4 Speaker Cable
The Bryston 9-gauge speaker cable utilizes four multi-strand conductors of OFC copper with advanced insulation. Bryston SC-4 speaker cable provides accurate signal transfer and an ideal match to any Bryston amplifier. It provides power and control for maximum performance especially over long lengths. The SC-4 employs twisted combined opposing conductors (red and white) to positive and (black/gray) to negative for very low self inductance and resistance. Also the cable can easily be configured for utilization in Bi-Wired applications.
Shielding is almost a non-issue in speaker cables as signal levels are very large and circuit impedances very low. Speaker cables, however, should be kept as short as possible to minimize power losses and the associated dynamic compression of the music signal. If a choice must be made as to which of your cables should be made longer, always let the additional length be taken up with your interconnects.
Det er helt etter min bok...
JB rünnhilde
Gode 6 kvadrat per leder? Da trenger de ikke være snuppekorte, og det er jo heller ikke illustrasjonen.
Forøvrig forbilledlig reklametekst fri for blomsterspråk, som man vel kan forvente fra den kanten.
Anonym
Lite overraskende fra den kanten, fritt for kvantemekanikk og nanoteknologi.
Sannsynligvis en av de bedre høyttalerkablene på markedet.
