Side 1 av 3 123 SisteSiste
Resultater 1 til 20 av 55
Abonnér på denne tråden
  1. #1
    break_out
    Guest
    Innbrenning av kabler?
    Leste denne i Vandenhul sin kabel FAQ en tid tilbake. Er den noen på sentralen som har gjort lignende erfaringer?
    “Any cable’s conductors consist of many groups of atoms, clustered in crystals or atom clusters. The borders between these crystals or clusters are critical zones where electron movements are hindered when the condition of these boundaries is getting worse. This worsening takes place e.g. when your loudspeaker cable is moved every day and/or chemical activity is around - latter amplified by higher humidity levels, elevated temperatures and air pollution. Also imperfections in the cable insulation can trigger conductivity changes. Burning-in is the effect that, despite any affected crystal borders, the sound quality improves again thanks to electron movement through conducting zones like so-called electron tunnels. But... when you move a cable again, those tunnels are “broken” and you then have to start again by playing your music. You may wonder why (especially) on Sunday evening the music sounds so good again, this after a week with plenty of sound problems. Your cables finally are burned-in. But as soon as the killing Hoover (vacuum cleaning) hour on Monday morning comes and the over-active cleaning lady messes about with your cables, the problem returns: your cables are “burned-out” again, remaining that way until the following Sunday...”
  2. #2
    kbwh
    Guest
    Nei. Kanskje en ide å snakke lønnsforhøyelse med hushjelpen.
  3. #3
    break_out
    Guest
    Men er den plausibel denne teorien? Det finnes så mange voodoo lignende teorier rundt dette med kabler, så det er vanskelig noen ganger å luke ut de som kanskje skulle ha en gevinst. Tror ikke en kan oppnå de revolusjonerende forskjeller med å tweeke kablene, men alt monner og er det noe å hente så hvorfor ikke?
    Denne teorien høres på en måde litt sannsynlig ut… kanskje?
    Dersom denne var sann så ville vel denne VIDAR saken være litt bortkastet da en må flytte kabler fra innbrenningsenheten til utstyret, og da vil jo disse linkene som er oppstått i innbrenningen bli brutt??
  4. #4
    nb
    Guest
    Elektronntunneler og lydkvalitet i samme avsnitt er en ganske sikker indikator på svada.
  5. #5
    OldBoy
    Guest
    Humre, humre....
    Dette var jo et artig populærvitenskapelig forsøk.
    Krystaller i et metallstykke, og i en kabel er ganske diffuse saker. Det første vi skal huske på er at atomer og elektroner er ganske ensomme vesener. De står ikke tettpakket som Hi-fi-kartonger hos Elkjøp. Mer som trær i en skog. Masse tomrom rundt hvort elektroner kan bevege seg fritt.
    Hvor fritt, avhenger av hvilket grunnstoff vi snakker om, men hvis vi tenker oss atomkjernen forstørret opp til størrelse med jorda, vil elektronene typisk sveve rundt like langt borte som sola, med et ganske anselig tomrom i mellom. Bare som en indikasjon. Med forbehold om at jeg husker noenlunde riktig.
    Grensesonen mellom forskjellige krystaller kan synes skarp sett fra vårt ståsted. For et elektron på vandring, er overgangen gradvis. Det blir som å bevege seg fra en skog av overveiende grantrær til en skog av overveiende bjerk. Lett å se hvor du er når du ser det et stykke fra oven, men ikke godt å si hvilken del av skogen du er i når du går rundt blant trærne.
    Like like som en lett sommerbris flytter på trærne, like lite flytter atomer og molekyler på seg bare fordi om luftfuktigheten øker eller vi tar lett på kabelen. Gir vi kabelen en alvorlig knekk, blir jo saken en annen: da kan vi få en varig deformasjon av krystallstrukturen. Analogt med at en storm kan velte trær eller brekke noen grener.
    Man skal imidlertid aldri si aldri, så det skal bli interessant å følge med i hva Rhesus finner ut, jfr. den parallelle "Innbrenning av kabler under lupen", når han kjørt sitt praktiske eksperiment en stund.
  6. #6
    break_out
    Guest
    Hva er da en innbrenning av kabler dersom det ikke har en forklaring som tilsier en oppretting av tunnel/optimal bane for musikken (kremt!… strømmen).
    Kan dette ha en sammenheng med retningsanvisning som de fleste seriøse kabelleverandører angir, har de gitt kablene en slags ordre om å lede optimalt i en retning, for så å virke mindre ledende i den andre retningen .
  7. #7
    OldBoy
    Guest
    Ja, du spør mer enn ti vise kan svare på.
    "Innbrenning" er et veldig misvisende uttrykk. Hvis det blir så varmt at kabelen gløder, er det greit nok. Ved gløding, vil som regel krystallstrukturen endre seg, og da kan vi tenke oss at kabelens struktur endrer seg permanent og at elektronene får nye baner. Men ved romtemperatur og vanlig signalstrøm?
    Det at en kabel er retningsbestemt, betyr bare at den kan ha forskjellige egenskaper avhengig av retning. Det kan være at kabelen er valset eller trukket på en måte som gjør at krystallstrukturen fremstår som forskjellig, avhengig av hvilken retning man "ser inn i kabelen" på. I et kabelsett kan det muligens godtas at det kan være greit å holde orden på det. Men siden signalstrøm i et hi-fi-anlegg er vekselstrøm, hvilket betyr at elektronene går frem og tilbake i en begrenset område av kabelen, vil kabelens ledningsevne være retningsuavhengig. Det kan teoretisk godt tenkes at ledningsevnen når elektronene går i den ene retningen er bedre, men det taper man i så fall når elektronene snur og skal skal gå tilbake.
  8. #8
    Hifi Freak
    Nov 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra break_out
    Man skulle jo da tro at innbrenning a'la Nordosts Vidar er helt meningsløst. Man vil jo da ødelegge de fine strukturene når man flytter kabelen fra Vidar og inn i anlegget.
    Hippies, prepare to be punished!
  9. #9
    Hifi Freak
    Jan 2005
    Tagget i
    0 Innlegg
    Sitat Sitat fra Rhesus
    Mulig det har gått meg hus forbi, men er innbrenning av digitalkabler også like "hot", for å si det slik?
    Jeg skal ALDRI ALDRI ALDRI fly med Ryan-air!!! Jeg skal ALLTID ALLTID ALLTID kjøpe TINE-produkter!
  10. #10
    nb
    Guest
    Sitat Sitat fra realist
    Det kan se ut som alt trenger å spilles inn / brennes inn eller hva man nå velger å kalle det. Hva gjør man med optiske digialkabler? Lyser de inn?
  11. #11
    OldBoy
    Guest
    Hvis man kjøper selvinnlysende optiske kabler, trenger man ikke å gjøre noe som helst.
  12. #12
    Hifi Freak
    Jan 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra OldBoy
    Det er jo innlysende... Hva med CD-plater? Bør de også spilles noen ganger før de låter optimalt? Er dette noe platebutikkene kunne tilby? For et lite påslag i pris selvsagt...
    Alt med måte.
  13. #13
    Hifi Freak JORFIN's Avatar
    Sep 2004
    Tagget i
    0 Innlegg
    Sitat Sitat fra Fush
    Jeg kan gjerne spille inn platene dine, bare send videre til meg etterhvert som du kjøper, kunn 1500 per plate!!
  14. #14
    Hifi Freak
    Jan 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra J.Finvaag
    Glimrende tilbud! Når det koster så mye MÅ det jo bare bli bra!
    Alt med måte.
  15. #15
    Hifi Freak
    Jul 2007
    Tagget i
    0 Innlegg
    Folk som holder på med HiFi burde få utdelt Bullshit-målere, men da ville jo slike diskusjoner bli langt mindre interessante.
    Kan jeg få anbefale MIT professor Walter Lewins GRATIS fullstendige og utførlige VIDEOkurs i alt som har med elektriske egenskaper å gjøre? Gratis, nedlastbart fra iTunes University. Fullstendig omfattende, og det begynner på "idiotnivå" og slutter langt udi teorien. Så vil man stå seg bedre mot denslags sprøyt som Van den HUHEI leverer her - og kanskje også ha grunnlag for å kikke på muligheter som er basert i kunnskap, og ikke svadasalgsprat.
    Electricity & Magnetism, ved Walter Lewin, fra 2002. Hele 37 undervisningstimer, fullstendig utførlig. Jeg vil spesielt anbefale nr. 20 - Inductance, RL Circuits, Magnetic Field Energy.
    Litt ned på siden finner du en link til samtlige timer på video; og du finner samme på iTunes U>MIT>Physics>Electricity&Magnetism. Kursets egen videollink krever RealPlayer, mens du kan legge forelesningene på din video iPod via iTunes.
    http://ocw.mit.edu/OcwWeb/Physics/8-...02/CourseHome/
    SCIENCE WILL CATCH UP WITH HI-FI, ONE DAY!
  16. #16
    Oct 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Soundproof
    Jeg ville være forsiktig med å kalle Dr. Van Den Hul en dust og en svadapreiker!!
    RØR
  17. #17
    Hifi Freak
    Jul 2007
    Tagget i
    0 Innlegg
    Hvorfor det? Jeg kan tenke meg en rekke mulige forklaringer på hvorfor anlegget lyder bra søndag, sammenlignet med mandag ettermiddag etter hushjelpen.
    Kjas og mas i løpet av uken gjør at man fysiologisk ikke er i mottakssituasjon. Søndag har "systemet" kommet i bero, det er stille utenfor og i huset, man har tid og lyst til å sette seg ned og oppleve musikk. Det har absolutt ingen ting å gjøre med at "kabelen er spilt inn i løpet av uken."
    At det så lyder dårlig igjen mandag kveld skyldes at nå er man i kjas og mas modus påny, og har ingen ting med hushjelpens flytting av kabel å gjøre.
    Occams Høvel er et nyttig redskap.
  18. #18
    Hifi Freak
    Jul 2007
    Tagget i
    0 Innlegg
    Vil ellers også anbefale forelesning 7: Capacitance, Field Energy og nr. 8: Polarization, Dielectrics.
  19. #19
    Oct 2007
    Tagget i
    0 Innlegg
    Det ene utelukker ikke det andre.
    RØR
  20. #20
    Nov 2007
    Tagget i
    0 Innlegg
    Sitat Sitat fra Dr.Evil
    Jeg velger å ikke karakterisere andre, så jeg skal ikke kalle Van den Hul for dust, men at han preiker svada er åpenbart. Nå var jeg uforsiktig, kommer han og tar meg nå, eller du?
    Hva om man har vært bortreist hele uka og ikke spilt på anlegget, låter det fint på søndag likeveL? Må man ha på anlegget med musikk døgnkontinuerlig hele uka, for så å kunne lytte bare på søndag?
    TENK ETTER, skal en liten bevegelse på kabelen ha NOE å si for lyden!!? Det foregår nok heller oppe i hodet på folk, som påpekt tidligere i tråden.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
