FANTASTISK!!!!! Patricia Barber Premonition Years 1994-2002
Kjetil_M
Fyttigrisen for en vanvittig god box! Ikke ett kjedelig sekund på 3 cder.
Dette er det beste plate kjøpet jeg har gjort på laaaaang tid.
Utrolig musikk og sinnssykt gode innspillinger. Lavmælt, melankolsk og vakkert.
Løp å kjøp og nyt i timevis!!
Kopiert fra http://jazztimes.com.
CD Reviews from the January/February 2008 issue
PATRICIA BARBER
The Premonition Years: 1994-2002 (Premonition)
It was as if a skylark had swallowed a bassoon that first moment singer/pianist Patricia Barber opened her mouth: a blues-hooting, nervously flitting bird with smartly semantic wiseacre lyrics beating her own drum vocally and rhythmically. Forget that her poorly titled albums seemed to signal some ersatz beat revivalism. Hers was a thoroughly modern listen whether tackling the classics or crafting bold new tunes low and slowly. And, OK, there was a hint of the beatnik chick chic to her—the dark hair framing a sunglass-filled face, the smoky bar brand of small-band arrangements, the algebraic Aesop-sopped texts.
Barber’s not dead. Mythologies came in 2006 and was a character-acted-out affair based on Ovid’s Metamorphoses, Guggenheim fellowship and all. But before that searing song cycle, Barber made five records for Premonition (1994’s Cafe Blue, ’98’s Modern Cool, ’99’s Companion, 2000’s Nightclub, 2002’s Verse), celebrated in this box in three categories: “pop song,” “standards” and “originals.”
Premonition is where she learned to fly.
Languid and sensual without the dread of cornball sentimentality lingering through her stylistic variations, hers was and is a dry jazzy élan comparable to Joni Mitchell (the sultriest parts of Hejira) and David Sylvian (his holy “Orpheus”). Maybe Barber’s a baroque cabaret answer to what would happen if Chris Connor and Nico had a baby. With all that, hers is a wholly unique vibe; a dusky musicality and odd métier that allows her deconstructionist takes on sexy “pop” songs a gray sensuality. Her organ-wheezing cover of Bill Withers’ slinky “Use Me” is creepier than Peter Lorre. Her threadbare, finger-snapping take on Tom Jones’ haughty “She’s a Lady” is distant and transient. In all cases, Barber removes these hits from their usual romanticism.
But that doesn’t mean there isn’t passion to be found. Her acoustic-guitar-strung-out version of “A Taste of Honey” is warmly inviting while remaining mysterious. That sense of invitation is made greater when Barber’s “standards” present an octave-higher sense of play and premonition. “I Fall in Love Too Easily” and “Bye Bye Blackbird” give her clear cranky piano lines a chance to out themselves. Her voice follows in slightly giddier order, toying with each word as if to go beyond the lyrical chilliness she finds in her “pop” selections. In essence, jazz and Tin Pan Alley war her a bit.
But not so much as to thaw her holiday hauteur. “Santa Claus Is Coming to Town” ain’t a believable myth when she shushes and slushes her baritone through that snow job. This leaves her calculated unsteady “originals” like the unnervingly chatty “Company” and the stretched-out noir prose and sleazy cowbell click of “Touch of Trash.” On “Trash” there’s one perfect line—among dozens of quotables in her catalog—that announces all that Barber is: “Orchestration and precision/The girl works harder than you.”
-A.D. Amorosi
http://www.cduniverse.com/productinfo.asp?pid=7487741&cart=672261598
Distinctive
Da var den satt i bestilling.
Har en del av henne og har full forståelse for din entusiasme :D
om.s
100 % enig, denne har fått sin fortjente plass i samlingen ;D ;D .....
Destiny
Da må vi ha denne om.s ;)
Takk for tipset.....
Destiny.. :)
Soundproof
Etter gårsdagens anbefaling tok jeg en lytt på iTunes Store. Mange bra arrangement og flott vokal - håper innspillingskvaliteten er på høyde.
Har bestilt CD-en. (For lav oppløsning på iTunes Store).
soundscape
Nordre Follo
Jeg har alle 5 CDene som boksen har hentet matrialet fra, og ja det er FANTASTISK.
om.s
Bonusen på denne boksen er de 4-5 xtra sporerene som ikke er fra orginal utgivelsene, damen befester bare sin suverenitet...
om.s
Distinctive skrev:
om.s skrev:
Distinctive skrev:
Bestilte Nightclub på SACD i samme slengen... 8)
Min förste kjärlighet til damen, ett godt valg ;) :D ....
Mener jeg kan huske en saftig trommesolo her !
Nå ble jeg litt usikker her, men det er ikke evnt fra cdén Cafe Blue du tenker på? (Har ikke spillt skiven på en stund) liker den pga dens standards settinger og rolige låter.....
Boe
Ikke bare det, men alle 36 spor er remastret av Alan Silverman i samarbeid med den originale innspillingstekniker Jim Anderson. I følge Stereophile er låtene løftet et nivå opp i realisme og gjennomsiktighet, en vesentlig grunn for å handle på nytt selv om man har originalvaren.
Kjetil_M
Blir bare mer og mer glad i denne boksen for hver lytting.
Er denne på vanlig cd også? Er det noen som har sett om det er mulig å få fatt i titler fra denne damen på vinyl? Hvilken er da et must?
Kjetil
om.s
Kjetil
Du kan nok bestille endel fra f.eks Elusive og lign steder på vinyl (har selv 4 stk MoFi 45/180 hjemme og venter på den femte), de er vel alle mer el mindre ett must, mange liker de tidligere skivene hennes best, selv har jeg "Verse" og nevnte boks som noen slags favoritter...om ikke jeg husker feil har jeg alle hennes 8-9 skiver, de er alle verdt å ha i samlingen.....
Kjetil_M
Kjetil
Takk for tips!! Skal sjekke det ut med en gang :) ;D
Kjetil
om.s
Kjetil_M skrev:
Kjetil
Kjetil
"Companion" hennes förste liveskive, er det mange som setter veldig höyt, som ett lite tips ;) :) ....
kjoenik
Hmm, jaja, da måtte jeg også bestille for å høre hva dere er så entusiastiske for :)
kjoenik
Premonition years.. :)
Grumpy
Hev meg straks på bølgen og bestilte.
- Innrømmer gladelig å ha kost med Nightclub i hele kveld på 45/180 halfspeed vinyl (SLE-versjon) mastret av Paul Stubblebine i Mobile Fidelity Sound Lab.
Søker samtidig om junior æresmedlemskap Patricia intimate fanclub ;D
Jan P.
mteinum
Øya
Den søker jeg også meg inn i, har disse platene
Samt "Live A Fortnight in France" og "Mythologies"
holder det?
om.s
holder det?
Det holder! ;D får du tak i "Split" og "A Distortion of love" har du vel det som er å få tak i ;) ....
hans
...stor beundrer af denne dame og hendes musikere. Havde den store fornøjelse at se hende live i Hamburg i 2007. Her oplevede man virkeligt et stref af personen Patricia Barber. Kæmpe oplevelse! Står tilbage som én af de bedste live oplevelser til dato.
om.s
Det er noe jeg skulle lagt penger på, å høre denne damen live :) ....
Boe
Jan P.
Tror kanskje du må være veldig junior for å bli intim med Patricia, siden damen er kjent for å foretrekke det kjønnet som vanligvis ikke heter Jan... ;D
Grumpy
Boe skrev:
Jan P.
Er man fra Nederland og heter Jan, så kunne det jo ha vært en ørliten mulig mulighet.
Sliter nok mer med både "P'en" i mellomnavnet og får neppe løst inn barnebillett på trikken lenger også ....uff
- Man kan jo lukke øynene ....fantasere, drømme og late som litt allikevel... ;D
kjoenik
Joda, dette var da bra saker. Ikke veldig utfordrende, men absolutt behagelig :)
om.s
Vil du ha litt mer "utfordring" fra damen anbefales "Verse", kanskje ikke blandt de største og vanskeligste av jazz plater, men den krever vel litt mer enn de mer standard´s hun har sluppet, imho....
Distinctive
Fikk den jeg også.
Har ikke fått tatt en skikkelig gjennomgang enda. Førsteinntrykket er bra, men Verse tiltaler meg nok mer.
vinyljazz
Denne måtte jeg bare ha,er en stor fan av Barber.
Håper lyden er knall god.
Herved bestilt fra cduniverse.
Rune
Destiny
Denne har jeg spillt masse i det siste ;D
Kjempefin plate...
Destiny.. :)
vinyljazz
Kjempefin plate...
Destiny.. :)
Den er bestilt og like rundt hjørnet,gleder meg enormt.Er en sor Patricia fan.
Håper lyden er så god som det blir snakket om her i tråden.
Rune
Destiny
Lyden er bra den ;)
Men inneholdet er enda bedre, her er det bare å glede seg ;D
Destiny.. :)
Soundproof
Denne tråden fikk meg på sporet av Patricia Barber, som jeg kun har hørt sporadisk før.
Kjøpte Verse - og i tillegg til oppfinnsomme komposisjoner, vidunderlig stemmearbeid og suveren instrumenttraktering så skilter dette med fremragende opptaksarbeid. Faktisk lenge siden jeg har hørt bedre opptak av trommer.
Så nå er det Premonition Years neste.
Hva? Er det faktisk noen her som ikke har kjent til Patricia Barber fra lenge tilbake? ;)
Jeg er også av dem med et halvt dusin av hennes CD'er i hyllen. "Nightclub" er lettest tilgjengelig, "Mythologies" mest ambisiøs, og "Modern Cool" generelt best, etter min mening. De tom-tom'ene på "Postmodern Blues" og måten hun dissekerer et kvinnelig bekjentskap på i "Touch of Trash" - må høres. Stemningen er ganske nattsvart og humoren enda svartere, så dette er ikke spesielt muntre greier, men likevel nesten hypnotisk.
CD'en "Cafe Blue" er også fenomenal, rett oppunder "Modern Cool" etter min mening. "Ode to Billy Joe" blir litt av en grøsser når hun avleverer den. Litt mer variert, litt flere eksperimenter med uttrykksformer.
"Companion" er et glimrende live-sett tildels basert på "Modern Cool", pluss lysende versjoner av "The Beat Goes On" og "Use Me".
I sammenligning er "Verse" og "Mythologies" mer ambisiøse, mindre melodiske, og jeg har ikke samme følelsen av sanger som virkelig griper tak i meg. Veldig, veldig bra, men jeg foretrekker likevel "Modern Cool", "Companion" og "Cafe Blue". Men jeg ser at allmusic.com har en annen oppfatning enn meg.
Soundproof
Ja, du kan lure på hvor jeg har vært. Har hørt spor hos venner, men av en eller annen grunn aldri gått til innkjøp selv. Det skal det jo rettes på nå!
Ikke ofte jeg hører gjennom en CD tre ganger på første forsøk.
om.s
Selv har jeg "Verse" som min favoritt, av alle de 10-12(?) skivene jeg har av damen, hyggelig at du holder på å läre damen å kjenne ;)
