Side 280 av 622 FørsteFørste ... 180230270278279280281282290330380 ... SisteSiste
Resultater 5,581 til 5,600 av 12428
Abonnér på denne tråden
  1. #5581
    Overivrig entusiast Sting's Avatar
    Jan 2007
    Sola
    Tagget i
    0 Innlegg
    Torget
    Selger du V800 nå ?
    Mac Mini, Amarra, Audirvana Plus, Devialet 120, Vivid Audio 1.5, Project Sunrise ii, Fostex HP-A8, Stax 007 Mk2
    På tur: PA2V2, CAL!, Shure Se 215, etymotic
  2. #5582
    Hifi Freak ardilla's Avatar
    Dec 2009
    OSLO
    Tagget i
    1 Innlegg
    Album
    NAD vs. V800 !!
    Vi følger med! I enden av regnbuen
  3. #5583
    Hifi Freak Loevhagen's Avatar
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    He, he. V800 selges ikke. Planen var for tusan å ha M51 som pre ved TV-en - ikke i head-fi riggen. Vi får se. Mulig jeg beholder Mjolnir/M51/LCD-3 som et dedikert oppsett og V800/V200/LCD-2 som et annet.
    Siste redigert av Loevhagen; 26.09.2012 kl. 23:05.
    I enden av regnbuen http://loevhagen.blogspot.com/
  4. #5584
    Jul 2012
    Tagget i
    0 Innlegg
    Fant noen denon på finn.no om noen ser etter.
    D7000 http://www.finn.no/finn/torget/tilsa...nkode=37400385
    D5000 Denon AH-D5000 - FINN Torget
    D2000 Denon AH-D2000 - FINN Torget
    Likte denne posten som jeg fant på headfi:
    When reading these forums, I always remember a funny study: Psychologists sat down various people at consoles, in pairs, separated by a wall from each other so each couldn't see what the other was doing. They had to categorize various pictures of cells as either "normal" or "pathological" via trial and error, without prior laboratory training. When they pressed a button, they were shown whether they were right or wrong. The catch was, only subject A was classifying the pictures. Subject B could press whatever button he wanted, he was always shown whether A was correct or wrong, so his own diagnosis didn't matter, but he didn't know that. Subject A got the hang of it eventually and classified most pictures correctly. B was however living in his own world so to speak, his diagnosis had no connection to the feedback he got, so he had to constantly question his previous, now contradicting assumptions. Neither knew each other's score. When asked how they classified the cells afterwards, A came up with simple and concrete explanations and B with very subtle and elaborate ones (after all, he came to them via contradictory assumptions) -- both were basically talking about different realities but were convinced that they were talking about the same thing. The real joke was: after listening to B, A was impressed and assumed that his simple explanations were worse than B's elaborate ones -- the more absurd B's ideas were, the more A was impressed by their detailed brilliance! They were asked to do the same test again, but first they had to guess whether A or B would be more accurate now. Most guessed B. And so it was, because A took on some of B's explanations so A was actually wrong more often. The corollary is that when humans are confronted with things they don't understand and try to get their heads around it, wrong theories of how stuff works tend not to be thrown away but expanded to wrap around corner cases and contradictions.
    I have the feeling that this is the cause of the "you must listen to it to form your own opinion" notion. Simple descriptions like e.g. the HD 650s sounding darker than the DT 880s are easy to verify. But elaborate descriptions of how amps, dacs, cables, etc. sound and compare to each other are most likely wrong (as e.g. DBT of cables or level-volumed DBT of well-enough-made amps show) and therefore contradict each other. Instead of questioning those subjective reviews by others, all of them are given weight because obviously all these people can't be wrong with their detailed analyses! You can't derive anything useful from a bunch of contradictions, but you don't want to discard them either (e.g. with the help of double-blind tests), so instead you establish the opinion that you have to listen to something to form your own (probably wrong) opinion about it and discredit anything that would undermine this stance (e.g. double-blind tests). The simpler, more probable alternative would be to assume that most, if not all, audiophile writing is wrong and that Head-Fi is nothing more than a dumping ground of fallacies. Note how there's not a single person to blame -- it's the group dynamic.
    The tragedy is that budding audiophiles who don't know better are driven by general forum thrust into buying expensive crap they could be happy without. There would be no problem if the forum would tell these newbies "Hey, don't worry, just enjoy your HD 800! If you want something special, try these amps, dacs, whatever, they change around the sound some, maybe you'll like it. But they aren't necessary for a good experience." Pro tip: if you're happy with the sound you're getting with your HD 800s out of your PC's onboard sound plug and the phones play loud enough for you, you don't need an amp. Really. All the people who report just how lush this and that amp/cable/whatever sound are most likely not just imagining things but they would also be happy if they didn't knew about the gear in question (or not, because they seek an emotional rush that their music/rig cannot give them, but then the problem lies in their head, not in their rig).
    hmmmmm hmmmm hmmmm.. i like. Kanskje vi kunne laget en liten newbie tråd? Q n A type eller anbefaling tråd basert på et generellt lydbilde ut i fra headphone, amp/dac type. Subjektive og objektive målinger/tester.
    Siste redigert av Nipton; 27.09.2012 kl. 15:40.
  5. #5585
    Tittentei
    Guest
    Y-ledd for splittesting av hodetelefonforsterkere
    Finnes det noe Y-Ledd som lar deg koble to forsterkere til én hodetelefon, og så har man en bryter som gjør at man kan switche over lett som ingenting?
    Det skulle vel enkelt la seg lage, men finnes det noe ferdig, mon tro?
    Edit: Kanskje en boks med velger kunne vært et DIY-prosjekt for oss som vil teste, hehehe. Må se å få hentet den loddebolten...
    Siste redigert av Tittentei; 27.09.2012 kl. 17:44.
  6. #5586
    Hifi Freak CDWMcInSpots's Avatar
    Sep 2010
    Bergensregionen
    Tagget i
    0 Innlegg
    Jack-svitsjebokser
    Sitat Sitat fra Tittentei Se Innlegg
    Det har tidligere på HFS vært skrevet (av Ulf-B?) at man uten problemer kan splitte utganger med Y-ledd, men at man ikke bør samle innganger med Y-ledd. For sistnevnte formål benytter man svitsjebokser som bryter før de slutter kontakt.
    Det finnes i hvertfall svitsjebokser for linje- og høyttalersignaler.
    Sitat Sitat fra CDWMcInSpots Se Innlegg
    Sitat Sitat fra tittentei1000 Se Innlegg
    [Bilde av baksiden av Grace Design m903]
    Jeg kunne ønske at m903 hadde en utgang til for RCA og flere digitale innganger. MER MER MER!
    Svitsjeboks
    En del usorterte eksempler fra mitt arkiv:
    Mapletree Audio Design og muligens Goldpoint Level Controls driver skredder- eller målsøm.
    Promarkedet har TRS-/jackpatchepaneler. Kanskje de også har svitsjebokser?
    Løsøreoversikt. Jeg lytter med høyst moderate lydstyrkenivåer.
    Subjektiv observasjon vs. forsøk etter anerkjente vitenskapelige prinsipper.
    Standardforbehold: Meg, mine ører, min smak, på den aktuelle dag, i det aktuelle system, med den aktuelle musikk, ...
  7. #5587
    Hifi Freak authentic's Avatar
    Jul 2007
    Tagget i
    3 Innlegg
    Navn:      DSC_9619.png
Visninger: 253
Størrelse: 476.8 Kb
    Hentet noen nye klokker hjem idag...
  8. #5588
    Tittentei
    Guest
    Hahaha, grattis, grandis! Hadde aldri trodd det var deg, etter den hardhendte diskusjonen rundt mariusaas fraktrater
  9. #5589
    Dec 2009
    OSLO
    Tagget i
    1 Innlegg
    Album
    Faren for kortslutning gjør at ingen har gjort der før deg..... Nesten, da. Man bør ikke ha strøm på forsterkerene samtidig med mindre man har dobbeltsikret seg. Det er skumle saker. Bedre å dra jacken ut og sette den inn på vanlig måte. Du klarer nok det.
  10. #5590
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    OMG! Overraskende, johnnygrandis. Positivt overraskende. Grattis. Og du skal drive disse med _____?
  11. #5591
    Dec 2009
    OSLO
    Tagget i
    1 Innlegg
    Album
    Ayon!
  12. #5592
    Aug 2005
    L -> her <- H
    Tagget i
    0 Innlegg
    Album
    dB Warning.
    Navn:      earbleeding-300-md.jpg
Visninger: 256
Størrelse: 12.1 Kb
  13. #5593
    Tittentei
    Guest
    Sitat Sitat fra Loevhagen Se Innlegg
    dB Warning.
Visninger: 256
Størrelse: 12.1 Kb
    Der skrudde jeg automatisk ned volumet. fyttigrisen.
  14. #5594
    Jan 2007
    Sola
    Tagget i
    0 Innlegg
    Torget
    Velkommen i klubben johnnygrandis! Er øm oppå toppen av hodet etter mye bruk av disse i det siste
  15. #5595
    Jul 2007
    Tagget i
    3 Innlegg
    Jeg hentet den så han slapp å sende - Tror det passet mariusaa bra !! :=)
    Takk forresten.
  16. #5596
    Jul 2007
    Tagget i
    3 Innlegg
    Ja det var det da (?) Ikke videre imponert over Myteken da volumet nærmer seg max på normal lytting - Lydbildet er heller ikke slik jeg hadde håpet, jo det spiller bra men bare ikke magisk slik jeg vet LCD kan, så en forsterker som kalles gulni eller gnugi eller noe annet Schiit kan jo kanskje funke. Hva bruker Loeven og Sting og Ardilla... (den harde kjerne ..lol)
    Takk forresten.
  17. #5597
    Jan 2007
    Sola
    Tagget i
    0 Innlegg
    Torget
    Mjolnir anbefales iallefall varmt, der er det skikkelig bånndrag
  18. #5598
    Jul 2007
    Tagget i
    3 Innlegg
    Sitat Sitat fra Sting Se Innlegg
    Bra men er det luft og klang ?
  19. #5599
    Hifi Freak pstraums's Avatar
    May 2007
    Flateby
    Tagget i
    0 Innlegg
    Velg heller denne varianten av albumet?
    https://www.hdtracks.com/index.php?f...etail&id=10090
    96 låter iallefall bra, men er ikke helt sikker på om jeg skjønner hva det dreier seg om. mange artige demoer mellom låtene, men jeg er kanskje litt for novise til å fatte hva det dreier seg om (hører jo han kommer nærmere og romklang er flott etc.., men må man ha en spesiell mic/innspillingsteknikk for å få til DET?)
    Sitat Sitat fra mteinum Se Innlegg
    Head-Fi: HiFiMan HE-500 / DT770 / CAL <- Schiit Lyr <- DACs <- Tidal/Server
    Stereo: Snell J/3 <- RX-A2050 <- DAC <- Chromecast Audio <- server / Tidal HiFi
    \\ Fuji-X //
  20. #5600
    Jan 2007
    Sola
    Tagget i
    0 Innlegg
    Torget
    Ikke den store eksperten jeg, Loevhagen må nok på banen Har hørt de med Fostex, Psii, V200 og Mjolnir kom ut på topp for meg. Drømmer litt om en Woo etterhvert men har noen klåfingrede småtasser som også liker rør så jeg venter nok litt. Koser meg med Psii når jeg er alene og da kan jeg rulle litt rør og lære litt om det når det er trygt. For meg mangler ikke Mjolnir noe, den er luftigere og mere detaljert enn Psii over hele spekteret og LCD-3s gode 3D egenskaper passer meget bra med Mjolnir. Et røverkjøp til den prisen synes jeg
Tags for denne Tråden
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
