Side 1 av 27 12311 ... SisteSiste
Resultater 1 til 20 av 535
Abonnér på denne tråden
  1. #1
    Overivrig entusiast MarkusH's Avatar
    Jun 2015
    Toten
    Tagget i
    2 Innlegg
    Album
    Klasse A/B vs Klasse D
    Har i dag en eldre NAD S200 som er klasse a/b, forøvrig godt fornøyd med den, men lurer på oppgradering til klasse d.
    Hvordan er klasse D (spesielt hypex-moduler og ice-moduler) i forhold til klasse a/b generelt?
    Høyttalere: XTZ Divine 100.49 Elektronikk: Classe, NAD, Rotel, Consonance, Thorens
    Diverse DIY
    Mitt anlegg
  2. #2
    Hifi Freak
    May 2012
    Tagget i
    3 Innlegg
    Sitat Sitat fra MarkusH Se Innlegg
    MIT råd er New Class D. En mellemting midt mellem D og AB. Tror forskellen delvis er anvendelse af non SMPS.
  3. #3
    Hifi Freak Terje-A's Avatar
    May 2013
    En leilighet i Moss
    Tagget i
    0 Innlegg
    Torget
    Denne kan være spennende.
    115W + 115W of max output power from a Hypex Ncore power amplifier module, tuned by TEAC
    MUSES8920 op-amps for high quality sound
    Independent resistor ladder-type volume controls
    Large capacity toroidal-core power transformer with Schottky barrier diodes
    CCLC headphone amplifier circuit for linear sound
    1/8inch (3.5mm) 4-pole headphone jack supporting ‘ground-separate’ connection
    Dual level meter with 4-step dimmable backlight
    Passive-cooling design for silent operation
    Full-metal body for rigidity, stability and elegance
    Compact design with an A4-sized footprint
    XLR balanced analogue input
    Three sets of unbalanced RCA analogue audio inputs with a wide-pitch connector layout
    A set of gold-plated, screw-type speaker terminals compatible with AWG8 cable and banana plugs
    Auto power-saving
    Remote control included
    RoHS compliant
    Navn:      AX-505-S_Front_top_R640x320.png
Visninger: 2617
Størrelse: 177.5 Kb
    https://www.teac-audio.eu/en/article...cs-156610.html
    Pioneer U-05, McIntosh MC275 Mk.VI, ProAc Studio SM100, Bluesound Node 2, Sony K970ES, KA3ES, JA30ES, JA20ES. Audioquest, Klotz, Van Damme, Wireworld. Headset: Grado SR60e. På tur; Sony WM-20, MZ-R410, MDR-EX650AP
    - Good audio engineering is timeless -
  4. #4
    Jun 2015
    Toten
    Tagget i
    2 Innlegg
    Album
    Sitat Sitat fra Drossel Se Innlegg
    Har du eksempler på effektblokker/monoblokker som benytter slike moduler?
    Sitat Sitat fra Terje-A Se Innlegg
    Auto power-saving
    RoHS compliant
Visninger: 2617
Størrelse: 177.5 Kb
    Dette er en integrert ser det ut til, litt svak på "papiret" også, ser mer etter noe i 300watt per kanal i 8ohm, kan funke med to stereo effektblokker med bi-amp.
    Skal forøvrig drifte XTZ Divine 100.33
    Diverse DIY
    Mitt anlegg
  5. #5
    Hifi Freak
    Nov 2010
    Tagget i
    2 Innlegg
    Torget
    Ati 542 2x500w.Ncore moduler. Har en 543 på lån 3kanaler og den driver alt du putter på den.
  6. #6
    Overivrig entusiast TrompeteN's Avatar
    Jul 2013
    Tagget i
    2 Innlegg
    Jeg har mest erfaring med Hypex. Det korte svaret mitt er at klasse D har bedre kontroll i bassen, går derfor dypere, men oppleves ofte mindre dynamiske og derfor lysere i klangen. Noen klasse D kan oppleves litt for glatte i toppen.
  7. #7
    Jun 2015
    Toten
    Tagget i
    2 Innlegg
    Album
    Sitat Sitat fra TrompeteN Se Innlegg
    Glatte i toppen?
    Har klart å stappe inn såpass med akustikk-tiltak at jeg har fått betydelig varmere lydsignatur slik det er nå og skulle nok ønske litt hardere topp enn det jeg har i dag, så det er bare en fordel her i mine øyne/ører nå.
    Diverse DIY
    Mitt anlegg
  8. #8
    Hifi Freak McLaren's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Ville valgt kl.A!
    I love the smell of napalm in the morning!
  9. #9
    Jun 2015
    Toten
    Tagget i
    2 Innlegg
    Album
    Sitat Sitat fra McLaren Se Innlegg
    Ville valgt kl.A!
    Det er ikke aktuelt for min del.
    Diverse DIY
    Mitt anlegg
  10. #10
    Jul 2013
    Tagget i
    2 Innlegg
    Glatte i toppen?
    Jeg opplever en glatt topp som en svakhet, men kan godt være det passer hos deg.
  11. #11
    Nov 2017
    Tagget i
    2 Innlegg
    Devialet, Gato etc er forsterkere i verdensklasse
  12. #12
    May 2013
    En leilighet i Moss
    Tagget i
    0 Innlegg
    Torget
    Kan jo slenge inn en ny power amplifier fra Teac også. Jeg kan ikke noe for det, men jeg liker størrelsen
    https://www.cepro.com/article/onkyo_..._1600_ces_2019
    Class D Technologies Help New TEAC Amps
    At the heart of the AX-505 and AP-505 are Hypex Ncore Class D amplification technologies helping the amplifiers to produce 70-watts per channel into an 8-ohm load. Both products also incorporate protection circuitry to help guard against current surges, overvoltages and overheating.
    The amplifiers also employ toroidal power transformers to help the products' power supplies avoid power output fluctuations.
    According to Onkyo, a stable power supply enables the amplifiers to maintain their rated power output capabilities under heavy load conditions. In addition, the amps' power sections utilize Schottky barrier diodes to increase the amps' efficiency, while reducing the amount of heat the amps generate.
    Related: Onkyo Introduces Commercial Line of Amplifiers
    Encased in aluminum enclosures, the products feature elegant touches such as machined aluminum knobs and gold-plated screw-style speaker terminals to help enhance their visual appearance.
    Aesthetically, the amps also include large volume meters (VU) that come with four-step dimmable, backlight and AD/DA circuits. The amps also provide headphone options for personal listening opportunities.
    The AP-505 Stereo Power Amplifier offers integrators a choice of three output modes: stereo mode, BTL bridge mode, and bi-amp dual monaural mode.
    Navn:      TEAC_AP-505_Power_Amp_large (1).jpg
Visninger: 2461
Størrelse: 33.6 Kb
  13. #13
    Apr 2016
    Tagget i
    0 Innlegg
    Nobel line fra MBL mener jeg bruker klasse d forsterkere, pimpa hypex saker. får bra test i den store verdenen men det koster
  14. #14
    Hifi Freak roeng2's Avatar
    May 2012
    Romsdal
    Tagget i
    1 Innlegg
    Torget
    Gato er i alle fall en bra klasse D, å man kan hente ut ennå mer med en ekstern dac.
    MARTEN Django L - Gato DIA250s - Veridian Utopia - Bluesound node2i - Van Damme - Sony
    A/B til A så ble det D
  15. #15
    May 2013
    En leilighet i Moss
    Tagget i
    0 Innlegg
    Torget
  16. #16
    Hifi Freak
    Oct 2002
    Tagget i
    0 Innlegg
    Jeg gikk fra to Parasound A21 med aktiv deling til to Wyred4Sound med aktiv deling. For noen år siden tok Tor med Hammeren knekken på strømforsyninga til miniDSP'n så jeg gikk tilbake til passiv deling og bruker nå de to i biamp. Forskjellen mellom Parasound og Wyred4Sound kan best beskrives som om forsterkerne ble fjernet fra signalkjeden. Etter min ringe oppfatning har Wyred4Sound minimalt med egenlyd sammenlignet med Parasound. Det var også en av hovedårsakene til at jeg byttet ut de to A21, alt jeg spilte hadde litt den samme lydsignaturen (den andre var at to A21 bruker 150 watt hver bare de er påslått og utviklet uforholdsmessig mye varme, spesielt om sommeren).
    Stereo: McIntosh MCD500 - McIntosh D100 - 2x Wyred 4 Sound ST-500 Mk II - Klipsch RP280F - 2x Klipsch SW115 - DIY Gull/Sølvkabler
    Hjemmekino: Marantz AV8801 - Rotel RMB-1575 - Klipsch CF-3 - Klipsch KV-4 - Klipsch KSP-S6 - Dayton 18" m/Hypex FA502
  17. #17
    Hifi Freak Bergfinn's Avatar
    Jul 2013
    Tagget i
    3 Innlegg
    Jeg kjører aktiv deling, og må ha 4 forsterkere. Da kan man mixe forskjellige klasser.
    Synes kl.D fungerer bra i bassen, og bruker kl. A i midbass og mellomtone.
    Bruker en kl. AB helt øverst.
    Alle kjøpt rimelig på brukten.
    Høyttalere....det er der de store penga monner om man vil ha best mulig lyd for minst mulig pæng.
  18. #18
    Hifi Freak coolio's Avatar
    Sep 2015
    Tagget i
    0 Innlegg
    Ncore er tilstrekkelig bra til at det er "alt" du trenger - or so they say. Jeg har opplevd noen klasse D som litt glatt i toppen, deriblant Devialet (hybrid) og eldre Ice-moduler, men erfarer ikke det med Ncore i det hele tatt. Blir flere og flere av de store produsentene som bruker Ncore som hjerte i sine dyrere saker, så nivået på klasse D har nok kommet dithen at det er andre ting man bør legge tid og vekt på.
    Har du abstinenser er Benchmark ABH2 fortsatt bedre enn det aller meste annet uansett pris og klasse.
  19. #19
    Overivrig entusiast HAREPUSEN's Avatar
    Nov 2009
    telemark
    Tagget i
    1 Innlegg
    Torget
    Skal du bygge selv ? Da hadde jeg sett litt på Tripath amplifierne til Connex eletronic i Kina
    Ja de finnes ikke lenger , og gamle lageret av tripath ckips er kjøpt opp bla overnevnte , de har laget nye super komprimerte moduler , og har super soft switched PSU på over 2000 watt om du måtte trenge .Selv har jeg en kl A 100 w og en super 180w slede m rør og eneste digi ampen jeg har laget som kan konkurrere med disse er tripathen. Den er bare så sinnsyk nøytral og naturlig og alldri øre trettende som noen andre kan være .
    Jeg avhendiget min gamle Tripatn nesten motvillig , men nå har jeg bestillt 2stk 3020 tripath moduler v3b som jeg skal bruke fully bridged og med connex eletronic sin smps 2000 rxi pr kanal
    Mulig jeg kommer til å poste prosjektet evt her på forumet
    https://connexelectronic.com
  20. #20
    Hifi Freak Ketil's Avatar
    May 2004
    Tagget i
    0 Innlegg
    Du har jo også disse monoblokkene fra PS Audio
    Bryston BDP-2, PS Audio DirectStream DAC, PS Audio BHK pre, PS Audio BHK 250 effekt, Monitor Audio Platinum 200 II, REL S5 subwoofer, PS Audio P15 Power plant, Perfectwave AC12 strømkabler, Chord Sarum Tuned Aray IC, Chord Sarum Super Aray USB, Shunyata Anaconda HT kabler.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
