Høyttalere Heftige semi-aktive høyttalere
  • Olympia
    Tenkte å lage en tråd hvor dere kan legge ut heftige og store highend semi aktive høyttalere som jeg mener har kjempefordel ift. rom tilpasning.
    Kan jo begynne med min egne.
    Montana RHS
    1x1" diskant
    2x7" mellomtoner
    4x10" basser som drives av 2x1000W innebygd forsterker med avansert equalizer og medfølgende software.
    16 - 22.000Hz
    Følger opp med noen til under....
    Olympia
    Følger opp med et par tyske heftige semi aktive, LANSCHE AUDIO No 8.2
    [h=2]Specifikation[/h]
    Description
    semi-active speaker
    Design2-way closed speaker with integrated active subwoofer
    Tweeter1x 0.3 in. CORONA plasma tweeter
    Midwoofer4 x 8 in. paper-coated cone
    active Woofer2 x 18 in. long neck construction
    Crossover Frequencies
    2.5 kHz
    Impedance (nominal)
    8 Ω (minimum 6.2 Ω)
    Sensivity94 dB / 1 W / 1 m
    Frequency range
    15 Hz - 150 kHz ±3 dB
    Dimension78.7 x 14.7 (20.5) x 29.1 in.
    Weighteach 880 lbs. (400 kg)
    Amplifier2 x 1.200 Watt (power output)
    Olympia
    Og disse ser heftige ut :)
    Gryphon Trident II
    [h=1]Product features[/h]
    • Three-way loudspeaker with on-board bass amplifier
    • Constant Phase crossover for perfect phase at all frequencies at all times
    • System response 16 – 40,000 Hz, -3 dB (depending on Q setting and room size)
    • Remote control for Q setting, Bass Level, Mute and Low Cut
    • Time-aligned front baffle curvature for identical arrival time from all drivers at the listening position
    • Ultra-fast Air Motion Transformer tweeter with low-mass pleated metal diaphragm
    • Customised, extensively modified Danish bass and midrange drive units
    • Special cone surround termination to eliminate edge reflections
    • Symmetrical vertical driver array for ideal point source presentation
    • Four Gryphon 8" bass drivers for extreme speed and precision with massive air displacement
    • Custom designed Gryphon bass amplifiers capable of delivering 500 Watts continuously (8 ohms) per channel
    • Integrated Linkwitz-Greiner Q Controller with preset and custom Q settings for ideal low frequency integration in any room
    • Individually adjusted passive mid/high crossover network
    • Triple-magnet bass/midrange driver motor system for maximum force and precise focus
    • Sealed enclosures with extensive internal bracing
    • Combination of pure wool and synthetic interior damping materials
    • Stylish string grille for driver protection
    • Virtually unlimited custom finish options
    Ketil
    GOLDENEAR TRITON ONE LOUDSPEAKER
    Driver complement:
    Three 5"x 9" long-throw quadratic sub-bass drivers coupled to four 7" x 10" planar infrasonic radiators; two 5-1/4" high-definition cast-basket MVP mid/bass drivers; one High- Velocity Folded Ribbon (HFVR) tweeter
    Frequency response: 14Hz–35kHz
    Sensitivity: 92dB
    Nominal impedance: 8 ohms
    Recommended amplifier power: 20–650Wpc
    Built-In subwoofer power amplifier: 1600W, DSP controlled
    Dimensions: 5-3/4" x 54" x 16-1/2"
    Weight: 80 lbs. (each)
    Price: $4995
    Gurba
    Gryphon Pendragon skal jeg ha når jeg blir stor. :)
    8x8" per side matet med 1000w og 4000w maks, 16hz-32khz. 1,7mill hos Oslo Hificenter.
    Gurba
    Adam Audio Tensor Alpha får både aktiv og semi aktiv. 2x500w per side, 20hz til 50khz.
    Ketil
    Audiosolutions Vantage
    Four way, five drivers ultimate speaker system featuring tri-amping binding posts and fine-tuning-capable crossover. Sub-bass and mid-bass drivers placed in vented enclosure. Mid driver and tweeter enclosures is completely sealed and separated. Multi-braced inner skeleton is triple in structure of what You see in Rhapsody speaker line. Side walls contains only plywood and total thickness reach 24mm (inner wall) + 18mm (outer wall) 42mm in total.
    Dimensions without plinth (HxWxD) : ~1434mm*347mm*564mm
    Dimensions with plinth (HxWxD) : ~1490mm*481*764mm
    Weight : 70 kg each
    Sensitivity : 92dB
    Power handling : 300w RMS
    Impedance (nominal) : 4om
    Crossover frequency : 50Hz;200Hz;10000Hz
    Frequency response (in-room environment) : 21-30000Hz
    Drivers : 1*26cm aluminium woofer, 2*18cm SPC bass drivers, 1*17cm Egyptian Papyrus mid-driver, 1*2.5cm silk dome tweeter;
