SACD 5.1 i 2 kanaler hva skjer?
llossius
Når SACD platen er innspilt i 5.1 og spilleren spiller SACD i 2 kanaler. Blir inf fra bakkanalene sedt til forkanalene eller bare tatt bort?
Er det like godt å spille cd sporet som er mikset for 2 kanaler?
MVH
lollo
oddgeir
MVH
lollo
Den spiller hybridsporet som er mikset i 2 kanaler, men med SACD kvalitet.
llossius
Er det tre spor på en slik hybrid SACD/CD? Både 5.1 og 2 kanalSACD + 2 kanal cd?
K
knutinh
fra wikipedia:
"Overview
SACD uses a very different technology from CD and DVD-Audio to encode its audio data, a 1-bit delta-sigma modulation process known as Direct Stream Digital at the very high sampling rate of 2.8224 MegaHertz — with the typical sampling rate present on audio CDs currently being 44.1kHz at a resolution of 16 bit.
SACDs must always contain a 2-channel stereo mix and may optionally contain a surround mix — either 5.0 or 5.1 layout. Although the disc always stores all channels, the surround mix does not have to use them all, and some may be mute; for example the 2001 SACD release of Mike Oldfield's Tubular Bells remained in the old quadraphonic 4.0 mix. The correct designation for the surround part of a SACD is "multi-channel", and usually has its own "Multi-Ch" logo on the back cover.
There are three types of SACDs:
*Hybrid: The most popular of the three types, hybrid discs include an audio CD "Red Book" layer compatible with Compact Disc players, dubbed the "CD layer," and a 4.7 GB SACD layer, dubbed the "HD layer."
*Single-layer: Physically a DVD-5 DVD, a single-layer SACD includes a 4.7 GB HD layer with no CD layer.
*Dual-layer: Physically a DVD-9 DVD, a dual-layer SACD includes two HD layers totalling 8.5 GB, with no CD layer. This type is rarely used. It enables nearly twice as much data to be stored, but removes CD player compatibility.
Jeg tolker dette som at en hybrid SACD kan innholde inntil:
1. Rent CD (stereo) lag
2. DSD stereo lag
3. 5.1 DSD lag
Folk med mer erfaring enn meg med sacd kan kanskje utdype.
Knut
Mulelid
Det meste er i to kanaler uansett hva man spiller. 5.1-lyden er som for Dolby surround; Et tillegg. FM-stereo er mono, TV er svart/hvitt osv. Kompabilitet er stikkordet, Knut. ;)
K
knutinh
Mener du at SACD ikke kan inneholde 3 uavhengige lydspor?
-k
Mulelid
Jo, men som tillegg til det vanlige i stereo. Husk at de meste er laget for å kunne kombineres. Tviler på at folk vil ha eget TV for svart/hvitt-filmer og for monolyd, egen FM-radio for gamle mono-opptak og en bil som kun kan kjøre forover mens de må hoppe over i en annen bil når de skal rygge............... SACD er jo "kodet" med noe som "dekodes"? :)
K
knutinh
Jeg forstår ikke hva du snakker om. Trådstarter spurte om konkrete spørsmål ved hva som faktisk ligger på en SACD plate. Hva dette har å gjøre med svart/hvitt-tv vet bare du :)
-k
K
kbwh
Blandt de hybridplatene jeg har er multikanallaget alt ettersom...
2.0
3.0
5.0
5.1
llossius
Er det mulig å velge to kanals SACD spor hvis det er en spiller som takler 5.1 kanal.
Jeg har spillere av begge typer, men finner ikke noen muligheter for dette i menyene for 5.1 spilleren, bortsett fra å sette den opp uten bakkanaler da.
K
kbwh
Min Cambridge DVD89 (5.1) kan iallefall fortelles at den skal velge SACD 2ch som default.
Slike operasjoner kan være godt gjemt. Har du lest bruksanvisningen veldig nøye, lollo?
Karl_Erik
Det er også ofte en egen knapp på fjernkontrollen, og på frontpanelet. Jeg kjenner ikke til at det er produsert spillere der man ikke kan velge 2-kanalssporet, og tviler på at det er tilfelle.
llossius
Tja, men jeg er vanligvis den som finner ut slikt da.... Skal sjekke.
På 2-kanalsspilleren kan jeg jo velge mellom cd eller sacd, men på DVD/SACD spilleren har jeg ikke slike valg. Mulig det ligger under "Audio" for å velge lydspor på film, det virker logisk.
llossius
DVD/SACD spillerren er en Pioneer sak som jeg ikke husler betegnelsen på. Den spiller vel også DVD-Audio. CD/SACD spilleren er en Marantz SA15 er det vel den heter.
Karl_Erik
Jeg har registrert at Pioneer har lagt dette under "Option Settings" i oppsettmenyen, med tittelen "SACD Playback". Men dette kan kanskje variere fra modell til modell.
Et modellnavn hadde selvfølgelig hjulpet.
Karl Erik
Mulelid
Metaforen var bare ment til å illustrere at det her også er snakk om å kombinere, for å si det sånn. ;) På min spiller, som nettopp ble kassert, var det et valg for "Downmix" i lydmenyen. Kunne m.a.o. slå av surround samt stille dynamikkomfanget, tidsforsinkelse m.m... :)
llossius
Downmix er vel forresten ikke å skifte lydspor, men å kjøre alt fra 5 kanal ut i frontkanalene hvis jeg fostår det rett?
Mulelid
Stemmer! Når man slo av downmix gikk den i surround.. :)
MusikkGal
Hei Lollo. Selvfølgelig at du kan velge 2 kanaler Stereo selv om du kjører rent SACD med Direkt Stream Digital eller DSD teknology som de kalles. I min Marantz multispiller ( som har den samme menyen som Pionner) finnes det 3 mulighetene: !. Rent CD ( 2 kanaler eller Dolby Prologic ( noe som ikke anbefales) 2. Rent SACD ( 2 kanaler) og 3. Rent SACD i Multikanal noe som anbefales i noen tilfeller. Det er en smakesak... Jeg må si at noen artister og titler har blitt bedre mixet i DVD Audio versjoner. Eksempler? Tubular bells- Mike Oldfield. Gaucho-Steely Dan SACD versjoner virker "kastret" etter min mening. I DVD Audio alt lyder "renere" "direkte" " å være der følelse" er veldig høy faktisk. Bruk ørene uansett mix og spiller du bruker. Lykke til.
OB. i noen spillere -min for eks.- man må stoppe spilleren før du kan gjøre noen forandring på menyene ( man kan ikke bytte fra Stereo til multikanal eller fra CD spor til SACD spor med "play" på. Håper det hjelpe deg
MusikkGal
...dette med å stoppe spilleren gjelder bare med SACD plater, ikke filmer (DVD Video)
llossius
Takk for innspill. Min Marantz er en tokanals cd/sacd spiller (SA15). Jeg lurer egentlig på hva som kummer ut i to kanaler når sacd platen er spillt inn flere en to kanaler. Hvor blir det av informasjonen som er lagt til bakkanalene? Eller spiller den et eget tokanals sacd spor. Noen sier at det er to sacd spor på platene.
Oddgeir sier lenger oppe i tråden at den spiller et eget sacd hybridspor som er mikset i to kanaler.
breuer
Kristiansund
SACD har ALLTID et 2 kanals spor. Så stereo DSD er IKKE downmix av multikanalssporet. De fleste SACD'er har i dag et multikanalspor, men ikke alle. Alle har stereospor.
Espen R
Her er det mye surr og misforståelser...
Det er ingen musikk som blir spilt inn på CD eller SACD. Musikken blir spilt inn på profesjonelle studioformater, og blir deretter overført til CD, Lp eller SACD.
En hybrid SA-CD er en plate som alltid inneholder både vanlig CD lyd og SACD lyd. Platen har 2 sjikt (lag). På CD sjiktet er det alltid bare stereolyd. På SACD sjiktet er det alltid stereolyd, og i noen tilfeller også 5.1 multikanalslyd. Når du spiller musikk på din Marantz spiller, en SA15 som er en 2-kanals spiller, vil du ikke kunne spille multikanalslyden på en SA-CD disc. Kun 2 kanals lyden (stereo), enten på SACD (som også kalles DSD), eller CD. Du kan velge med fjernkontrollen om spilleren skal spille CD sjiktet på hybriddiscen, eller 2-kanals SACD sjiktet på hybriddiscen. På denne måten kan du sammenligne lyden på CD og SACD, og vi snakker fortsatt kun stereo, ikke multikanal!
Hvis du derimot hadde hatt en multikanals SACD spiller, kunne du da også lyttet til multikanal, hvis du i tillegg hadde hatt 5 høyttalere og en forsterker som har 5 kanaler.
Var dette godt forklart?
llossius
Topp. Flott avklaring dette. Ja for meg er dette godt forklart EspenR! Jada, jeg skifter mellom de to formatene på spilleren min. Det var da jeg fikk sacd med lyd i flere (en to) kanaler jeg begynte å lure.
jakv
Har en SACD spiller på vei i posten. Sony SCD-XB 770. Den har både stereo og multikanalutganger. Hvilke utganger er i bruk der dersom jeg spiller 2ch SACD? Kommer dette ut på stereoutgangene.
Spør fordi disse to utgangene i prinsipp vil bli koblet til hvert sitt anlegg.
