Resultater 1 til 7 av 7
Abonnér på denne tråden
  1. #1
    Hifi-entusiast 2112's Avatar
    Apr 2011
    Tagget i
    0 Innlegg
    Tweaking: Apparatsikringer og Contact enchancer
    Har noen på forumet her erfaringer med å byttet ut sirkinger i komponenetene? Da for eksempel "HiFi Supreme fuses". Videre erfaring med å smøre inn koblingspunkter på kabler og apparater med "Contact enchancer"?
    Fra beskrivelsen (HIFI TUNING FUSES SUPREME SMALL SLOW at Music Direct):
    "HiFi Tuning & Mundorf Teamed Together to Create these Supreme Fuses
    HiFi Tuning Supreme Fuses are truly special and offer quality of sound which far exceeds any fuse available on the market. Made from Mundorf’s proprietary blend of ultra-pure silver and gold, Supreme fuses deliver outstanding speed, jaw-dropping resolution and a gorgeously smooth tonal balance. Treat your gear to the best, HiFi Tuning Supreme Fuses.
    HiFi Tuning has long been a fan of Germany’s legendary Mundorf capacitors. Revered in audiophile circles for creating gorgeous sounding no-compromise capacitors which grace some of the world’s best electronic designs, Mundorf capacitors are built using a special conductive material. Ultra-pure silver is impregnated with gold creating a material with gobs of resolution and golden warmth; glorious tonal color with truly outstanding dynamic shading, essentially the best of both gold and silver and absolutely no compromise. Each Supreme fuse uses this special material for its end-caps and conductive filament and pure silver solder connects everything. Inside the ceramic casing, Supreme fuses further distinguish themselves by receiving proprietary resonance and quantum treatments. Can a fuse really make a difference? Are Supreme fuses worth it? One listen will erase all doubt."
    "Contact enchancer" fra Furutech (NANO LIQUID | FURUTECH). Koster ca en tusenlapp for 2 milliliter. Fra beskrivelsen:
    "High End Performance NANO Liquid Contact Enhancer
    Revives old connections and improves new connections
    Incredible Nano Liquid’s molecules are so tiny they
    “fill up” any air bubble holes left during the plating process when brushed onto connectors.
    The result is much better contact between metal surfaces.
    Nano Liquid is a result of Furutech’s Total Attention to Detail regarding every aspect of signal transmission. Use only a little!
    This product is super-micro particle(with nano-meter technology) made by two material i.e. pure Gold and pure Silver.
    The particle diameter is 8 Nm Max., i.e. 8/1,000,000mm.
    2CC/PCS
    Illustration of the Nano Liquid Efficiency:
    1. Squalene Oil can remove oxide...etc, form the surface of metal, make the surface clean and free of pollution, activate metal surface.
    2. Apply the principle of atomic adsorption to make gold & silver super-micro particle can be adhered to metal surface averagely; Fill concave-convex section on surface, increase electric conduction area and debase impedance (Ω).
    3. Meanwhile, stable Squalene Oil can form a layer protective film on the surface of metal to prevent oxidation happen again. Utilize it’s excellent adsorbed effect to make gold & silver super-micro particle average and adhere to surface of metal stably."
    Siste redigert av 2112; 14.08.2014 kl. 19:16.
  2. #2
    Hifi Freak ou812rh's Avatar
    Mar 2006
    Tagget i
    1 Innlegg
    Bruker HIFI Tuning Supreme fuses over hele linja. Har i utgangspunktet gode erfaringer med å bytte fra standard sikringer. Min erfaring er at jo bedre strømkvalitet du har i utgangspunktet (evt. med bruk av filter/kabler) jo mindre utgjør bytte av sikringer.
    OU812
    Densen DenDac 50, Densen B-330+
    Michell GyroDec, SME 309, Lyra Kleos, Avid Pellere
    Bluesound Vault 2, Isotek EVO3 Sigmas, Piega Coax 511
    Whistler, Audience, Nordost, Oyaide, Audioquest
    Vibrapods, Furutech, crTech
  3. #3
    Hifi Freak Audirvana's Avatar
    Sep 2012
    Tagget i
    0 Innlegg
    Denne videoen omhandler en annen "kontaktforbedrer", kalt "quicksilver".
    https://www.youtube.com/watch?v=9Le1...TiHYDf9_NX9c2Q
    Musical Innovation MI9.2 | Musical Innovation MI25 | Magnepan MG 1.7 | Linn Akurate DS | Rega Planar P3 | Nordost Purple Flare | Kimber 12TC høyttalerkabler| kinarøverversjonen av Nordost Odin | Isol8 Minisub 2 | Electrocompaniet 25W | Electrocompaniet EC1 | B&W Preference 6 | Museatex Melior One.
  4. #4
    Moderator bambadoo's Avatar
    Oct 2002
    Tagget i
    3 Innlegg
    Sitat Sitat fra satriani Se Innlegg
    Tok et ultrakjapt søk på forumet og noen tråder dukket opp.
    http://www.hifisentralen.no/forumet/...-kvalitet.html
    http://www.hifisentralen.no/forumet/...sikringer.html
  5. #5
    Hifi Freak Scrooge's Avatar
    Nov 2008
    Tagget i
    1 Innlegg
    Verden vil fortsatt bedras....
    Hva jeg er belemret med: |ASR Emitter 1|ASR Mini Basis MK III|Hegel HD20|Martin Logan Vista|Musical Innovation Mosfet|DIY DUAL 701|OPPO BDP 83|Onkyo 875|JVC HD1|2xSVS 20-39|Squeezebox Touch| http://www.klikk.no/teknologi/lydogb...icle563967.ece
  6. #6
    Hifi Freak Lgrons58's Avatar
    May 2012
    Nord for Sinsenkrysset
    Tagget i
    0 Innlegg
    Tar heller en Øl når nevrosene kommer
  7. #7
    Apr 2011
    Tagget i
    0 Innlegg
    Sitat Sitat fra Scrooge Se Innlegg
    Vil helst ikke bedras, men gjerne ha enda bedre lyd
    T+A Criterion TCD 210 S | Burmester 032 | Avid Volvere SP | SME 309 | Avid Pulsare II | Burmester 113 | Bel Canto uLink | Isotek GII Titan | Nordost
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
