Resultater 1 til 12 av 12
Abonnér på denne tråden
  1. #1
    Hifi-entusiast haden's Avatar
    Sep 2004
    Tagget i
    0 Innlegg
    Transistor effekt til Avantgarde Uno
    Jeg vil ha meg en transistor effektamp , 15-30w, til mine Avantgarde Uno'er .(har preamp...)Sugden , Lavardin..?? , gi meg noen gode tips/erfaringer.
    haden
    1 stk fransk blank boks :-)
  2. #2
    Overivrig entusiast Unplugged's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Re: Transistor effekt til Avantgarde Uno
    Har ingen personlig erfaring med dette her, men etter hva jeg har lest her på sentralen og i Fidelity bør Abrahamsens nye "The Two Channel Amplifier" også være en kandidat for deg.
    There&#39;s one good thing about music<br />When it hits you feel no pain.<br />So hit me with music.<br />Bob Marley
  3. #3
    Æresmedlem LMC's Avatar
    Aug 2006
    Drøbak
    Tagget i
    6 Innlegg
    Torget
    bd30 fra bert doppenberg i NL chip amp med kanon lyd
    www.bd-design.nl
    Pick your currency
    BD30 DIY
    High quality DIY 30 Watt mono ‘plate’ amplifier designed primarily for use in combination with our bass systems.
    Each mono amplifier is built on a solid 4mm thick aluminium base plate (250*135mm). The power supply (110-220V selectable) features a shielded 300VA torroidal transformer plus 12(!) Black Gate NX Rubicon power caps wired in 'Super E-Cap' configuration to give optimum results.
    BD30 DIY "plate" amplifier...
    While designed as a woofer amplifier, the BD30 amplifiers are so good that you can also use them as main amplifiers for our "Quasar" or our other high resolution systems, and also as a budget solution for powering our "ORIS" horns. These amps are quick, clean and dynamic but also musical and without typical annoying solid state characteristics.
    The relative small overall dimensions make the amplifiers suitable for mounting in the stands for the Oris horn. A simple wooden cover screwed to the aluminium plate with the same finish as your bass enclosure is the perfect solution for achieving a great look, minimal visibility and the shortest possible wiring. A wooden cover such as the examples shown below is easy to build. The ones shown were made of MDF with veneer. As you can see, you can build them for use as stands below the Oris horns.
    Example amplfier using the BD30...Example amplfier using the BD30...
    You can find more information about building the amplifiers and the stand/housing on the BD30 DIY-manual page.
    Safety note: While completely electrically safe if properly assembled, some wiring of the BD 30 amplifier has to be soldered to connections that will be hooked up to your mains power supply. This means that you can be exposed to high voltage (110-230V) if you do not take appropriate precautions. Therefore you always must have the mains cable unplugged from the amplifier while you are building it and, subsequently, before you open the cover for any reason!
    If you need more information feel free to contact Bert Doppenberg or use our Forum for support.
    BD30 DIY (one pair)
    €647.00
    Add to basket Favourites
    The price listed is for one pair excluding sales tax (i.e. VAT, Mwst., BTW, etc.).
    The kit includes the finished amplifier module mounted on a 250*135*4mm base plate with 300VA transformer. Additional parts included in the kit are: mains connector with fuse + On/Off switch + 110-220V selector and rubber feet.
    With this kit, along with the materials you will supply for building a case and any parts you might need for the integrated filter that may be required (depending on which of our speakers you are using the amps with) you can build your own high quality mono amplifiers to be used either as stands for your Oris horn, or as stand-alone amplifiers. For detailed assembly instructions see our BD30 DIY-manual.
    solderslinger og raskere enn sin egen skygge
  4. #4
    Apr 2004
    Tagget i
    2 Innlegg
    Torget
    Har en liten Charlize som backup til rørforsterkerne på mine Uno: http://diyparadise.com/charlize.html
    Den krever jo som LMC sitt forslag litt egeninnsats - eller hjelp fra andre som kan montere den i en passende boks.
    Men hvorfor må det være transistor?
    MVH Tormod
    Luxman PD 300 - Technics SL-7 - Nuprime HPA-9 - ADL Esprit - Welborne Labs Ultrapath BP - Pioneer PD-S06 - Tonian TL-NFSM - Händel Horn 10P - Supratek Merlot - Kora Explorer 150CSC
  5. #5
    Jul 2003
    Tagget i
    0 Innlegg
    Hei Haden
    Det finnes mange gode små klasse D forsterker. Jeg har god erfaring med Charlize fra Diyparadise. Utrolig bra i forhold til prisen. Har benyttet den litt til og fra siden i sommer og er imponert over hva den kan varte opp med av godlyd. Horny her på forumet benytter den også med godt resultat på sine Uno'er.
    Men det er en stjerne av en klasse D forsterker som du bør sjekke ut om du har råd. Det er Signatur 30 fra Redwine Audio Den har fått stjerneomtale og blir sammenlignet med de beste SE rørforsterkerene. Ta en titt på den fine omtalen på 6moons
    Bjørn
    Edit: Horny kom meg i forkjøpet
  6. #6
    Hifi Freak tweakMan's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Bortsett fra at jeg virkelig hadde anbefalt rør...
    F.eks Quicksilver horn mini mono. (25w).
    Her testet med Uno... :
    http://www.stereophile.com/tubepoweramps/581/index.html
    Så kan jeg tenke meg at disse nye Pass labs sakene
    F3 og hva de nå heter må jo bare passe max!
    First Watt serien vøttø!
    Red Wine Audio Custom Clari-T er jo og feeeet.
    Ellers da Lavardin har jo ett utrolig sluttrinn i Model AS (2x30w)
    Jeg vil nok mene at Lavardin nok bare skal velges om man ønsker skikkelig bøøs lyd. DVS mest mulig dynamikk!
  7. #7
    Hifi Freak 6bm8's Avatar
    Jan 2005
    Gressvik/Fredrikstad
    Tagget i
    0 Innlegg
  8. #8
    Jun 2003
    Tagget i
    1 Innlegg
    haden
    Tja, siden ingen andre har nevnt det så får jeg vel anbefale Avantgarde's egen Model 5.
    "Må" dog enten modifiseres eller være av den aller nyeste Model 5+ typen.
    Har personlig erfaring med Lavardin IS, Pass Aleph 30 og Gaincard på Uno'er og IMHO så er Model 5 klart å foretrekke fremfor disse ihvertfall.
    Sugden ser spennende ut, men har aldri prøvd dem med Avantgarde........
    Nyeste Abrahamsen er sikkert bra, men ville ikke ha våget å kjøpe uten å prøve den hjemme først............
    Platespillere: Garrard, Teres, Technics, Thorens, TW, VPI. Tonearmer: Graham(er), VPI. Pickuper: Air Tight, Lyra. MC trafo: Kondo(er). Preamp/riaa: Kondo(er). Amp: Air Tight, Kondo, Supratek. Høyttalere: Avantgarde(r). Kabler: Avantgarde, Cardas, DIY, Kondo. Diverse: Isotek, Rives.
  9. #9
    Overivrig entusiast Lexluthor's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Jeg har brukt rør og en rekke transistorforsterkere med Avantgarde DUO. Det som fungerte overlegent best på hornene var Avantgarde Model 5. Det er nemlig en utfordring å finne en dynamisk kjapp forsterker som også spiller optimalt ved meget lav effekt - det gjør Model 5. For 15000 DKK ny må du lete lenge etter en bedre løsning:
    http://www.artsound.dk/index.php3?m=44
    Everything should be made as simple as possible, but not simpler.
  10. #10
    Sep 2004
    Tagget i
    0 Innlegg
    hei
    ja model 5 er nok god , men kan den "splittes" og brukes som en ren effektamp ?
    haden
  11. #11
    Jun 2003
    Tagget i
    1 Innlegg
    hei
    haden
    Det kan den ved å flytte en enkel "strap" innvendig i amp'en fungerer den ene linjeinngangen som en inngang som går utenom volumpoteret.
    Og "voila" så har du en power amp
  12. #12
    Hifi Freak
    Jul 2003
    Tagget i
    0 Innlegg
    Denne er iallefall en Trio-eier fornøyd med:
    http://www.mother-of-tone.com/byob.htm
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
