Når det gjelder delefilter, finnes det jo f. eks en del bra digitale til en forholdsvis billig penge. Men en av fordelene med høyttaler som Quad har jo nettopp vært fravær av delefilter, så det hadde jo vært spennende å prøve den største modellen, uten noe ekstra sub, kanskje det var nok?
Tror at elementene er stort sett de samme? En variant av disse. Det finnes tegninger, for å lages sine egne "Gradient SW 63 kloner", lett tilgjengelig på nettet.
Peerless Data Sheet
315 SWR
315 SWR 39 134 PPX AL 4L 8 ohm - Order ID: 831857
The ultimative 12" subwoofer driver with an over-sized magnet (1.3 kg) and a heavy voice coil securing a clean, fast, and dry bass performance even at high volumes. Nothing is spared in this driver. Highly recommended for surround sound systems and THX systems.
315 SWR
Thiele Small parameters: Free air Common Baffled
Nominal impedance Zn (ohm) 8
Minimum impedance/at freq. Zmin (ohm/Hz) 6.3/124
Maximum impedance Zo (ohm) 46.9
DC resistance Re (ohm) 5.5
Voice coil inductance Le (mH) 2.8
Capacitor in series with 8 ohm
(for impedance compensation) Cc (µF) 24
Resonance Frequency fs (Hz) 24.0 22.9
Mechanical Q factor Qms 3.72 3.90
Electrical Q factor Qes 0.49 0.52
Total Q factor Qts 0.44 0.46
F (Ratio fs/Qts) F (Hz) 50
Mechanical resistance Rms (Kg/s) 3.25
Moving mass Mms (g) 80.2 88.2
Suspension compliance Cms (mm/N) 0.55
Effective cone diameter D (cm) 25.7
Effective piston area Sd (cm²) 520.0
Equivalent volume VAS (ltrs) 210.0
Force factor Bl (N/A) 11.6
Reference voltage sensitivity
Re 2.83V 1m at 124 Hz (Measured) (dB) 89.3
Magnet and voice coil parameters:
Voice coil diameter d (mm) 39
Voice coil length h (mm) 26.0
Voice coil layers n 4
Flux density in gap B (T) 0.99
Total useful flux (mWb) 1.52
Height of the gap hg (mm) 8
Diameter of magnet dm (mm) 134
Height of magnet hm (mm) 22
Weight of magnet (kg) 1.28
Power handling:
Long term Max System Power (IEC) (W) 220
Max linear SPL (rms) / by power (dB/W) 110/170
De orginale Gradient subbene for ESL63 gikk ut av produksjon for flere år siden, og det er veldig sjelden du finner dem på bruktmarkedet. Gradient lager nye subber nå hvor bassene er montert over hverandre. Disse ser selvsagt ikke like fine ut sammen med Quadene, men de er helt sikkert mye bedre enn orginalen, og har et delefilter som etter sigende skal være langt bedre. Eneste aberet er prisen på ca 50k hvis jeg ikke husker helt feil.
Orginalfilteret har kun deling på 100Hz noe som jeg synes er alt for høyt. Du får litt mere trykk i mellombassen og kan spille høyere, men det går ut over kvaliteten etter min mening. Deling på 200Hz er helt bortkastet. Da mister du mye av det som er veldig bra med ESL63.
Det ligger et par Celestion 6000 (push-pull dipol)subber til salgs på bruktbørsen. Disse gjør en minst like bra jobb som de orginale Gradientene. Filteret er ikke det aller beste, men har variabel delefrekvens osv.
Homogenitet får du ved å dele så lavt som mulig. Husk at bassen på ESL63 er bra!
Du kan forøvrig spille langt høyere enn du tror med ESL63.
