Er det noen som kjenner til dette merket og har hørt det spille i ett oppsett ? Spesielt interresant er jo monoblokkene DMA-360 Series 2 som går fra 0-350 Watt på ett øyeblikk.
Speed:
Risetime: less than 300 nanoseconds
Settling: 1.5 microseconds to -40 dB
Slew Rate: 600 volts/microsecond
Noise:
SpectralAudio
DMA-360 Series2
Code: 00679
Description:
Specifications
DMA-360 Series 2 Monaural Power Amplifier
Power Output (continuous): @ 8 ohms - 350 Watts RMS
@ 4 ohms - 552 Watts RMS
@ 2 ohms - 680 Watts RMS
Output Compliment: 90 Amps peak
Frequency Response: +/- 0.1 dB, DC - 150 KHz
+/- 1 dB, DC - 1 MHz
+/- 3 dB, DC - 1.8 MHz
Distortion Static: less than 0.015% from DC to 100 KHz, typically 0.009% @ 350 WRMS/8 ohms
Dynamic: 8 Tone Cluster Test 20 KHz @ 500 Hz separation 0.01% @ 8 ohms
0.015% @ 4 ohms
Speed: Risetime: less than 300 nanoseconds
Noise: Signal to Noise: 97 dB unweighted, 107 dB ASA A
Crosstalk: 98 dB @ full power 8 ohms
Input: Impedance: 10k ohms
Sensitivity: 1.5 volts / nominal output
Power Supply: Line Voltage: 120 volts AC Voltage Range: +-10%
Maximum Consumption: 2000 Watts
Quiescent Consumption: 250 Watts
Operating Temperature: 0 deg. to +50 deg. Celsius range, 32 deg. to +122 deg. Fahrenheit
Protection Features: DC Protection Servo: 0.5 volt range Current Limit Onset: 90 Amps
Thermal Threshold: Protects at 85 deg. Celsius, 185 deg. Fahrenheit
AC Main Fuses: 120v 5A/3AG slo-blo
Size and Weight: Dimensions: 20" (50.8 cm) W, 7.23" (18.4 cm) H, 19.6" (49.9 cm) D,
Weight: 69 lbs, 31.2 KG Net
Ikke så veldig kjent men etter hva jeg googler meg til så for det strålende kritikker stort sett overalt jeg har lest.
Noen som vet om det finnes Norske importører.
Speed:
Noise:
SpectralAudio
DMA-360 Series2
Code: 00679
Description:
Specifications
0.015% @ 4 ohms
40 KB Visninger: 219
