Hva er dette?! Revolusjon?
Atlant
Dear Fellow Clients and Fellow Audiophiles:
The new Oppo Digital BDP-95 Universal players are in. The results turned out simply amazing:
No stock player/dac or competitors modified player we've got here for testing has bested this finalized version of the upgraded Oppo 95.
Not even the stock $65,000 Esoteric P-01/D-01/G-0Rb 5 box CD/SACD setup sounds better.
A colossal waste of money.
The technologically advanced 32bit Oppo 95 once upgraded with our new innovations makes all previously stock or previously upgraded players sound weak in the bass and highs, lacking in depth, lacking in organic. Any update we ever did to previous players is not
The finalized 95's even beat all of these players in direct side by side comparisons:
Playback Designs
Zanden CD player
Ayon CD2S
AMR CD-77 w/V-Caps
Esoteric P-01/D-01/G0Rb
I'm sure you're probably saying to yourself "No Way!".
(4) 95's were extensively double blind A/B/X compared against stock & upgraded & modified 95's, as well as the most expensive digital on the market today. Including tubed modified players from other mod firms, for R&D comparisons to extract the most from this incredible 95 platform.
The new $25,000 EMM LABS XDS-1, not even close! Upgraded XDS-1, yes it beats the upgraded 95. The new 95 CREAMS our previously upgraded Esoteric and EMM players, as good as they are over stock versions.
Audio plays every format out, even HDCD encoded discs, all to 32 bit resolution. Not many players do High Definition CD. The once great EMM LABS players PALE to the upgraded Oppo 95. Honest.
XLR AND RCA outputs w/volume + mute. USB input for your IPOD, music server or computer based storage, all accessible from the remote control.
Video on the 95 is the best on the market right now for both DVD's and Blu Ray & 3D Blu Ray. Fastest loading times as well.
If you've been itching to upgrade your source, now is the time. The upgraded Oppo 95 is a true jack-of-all- formats player that does everything far better then any stock player at any price. Dedicated CD players do not outperform the new & upgraded 95. In fact they're not even close.
This remarkable transformation is a testament to the new 95 base player and to our latest innovations.
A solid state source with fast loading that sounds more tubelike and musical and lush then the best tubed gear once upgraded.
100% Buy Back Guaranteed.
Of course we would not offer the buy back guarantee or put this in print if it were not true.
Yours in Music,
David J. Schulte
The Upgrade Company - The leader in Hi-Fi upgrades and modifications
1222 Walkabout Lane
Harbor Springs, MI 49740
www.upgradecompany.com
1.231.242.0946
N
nb
Det er vel først og fremst Store Ord, noe som ikke er mangelvare i denne hobbyen. Revolusjoner osv blir jo annonsert rett som det er, men de dør som regel hen når den første hypen har lagt seg og det kommer noe annet.
Oppo er jo teknologisk på høyden så sikkert et greit utganspunkt for de som vil modde og leke seg litt. Forrige versjon - BDP-83 eller hva den heter dukket som kjent opp som utgangspunkt hos Ayre og som en tilnærmet(?) ren kopi hos Lexincon og Theta.
BT
Dette ser ut som markedsføring.
N
nb
Ja, det er visse klare kjennetegn på den slags. Det viktiste av sorten kanskje at uttalelsene kommer fra de som sleger disse modsene.
DIY_dude
OSLO
Med mindre de redesigner hele analogtrinnet, alle strømforsyningene og klokkekretsløpet så tviler jeg littegrann på akkurat de uttalelsene.
Spilleren ser i utgangspunktet ganske bra ut, men er ikke akkurat banebrytende. Vanlige lineære IC-baserte strømforsyninger, opampbasert analogtrinn hele veien, ikke spesielt imponerende kretsdesign. Jeg blir litt underveldet av hele greia. Men, for all del, det låter sikkert bra selv om de store ordene kanskje ikke er helt på sin plass.
Atlant
Det overrasker meg at de rakker ned på, eller iallefall slår fast at oppo spilleren er så mye bedre enn andre spillere som dette firmaet har modifisert og bygget om for kunder før
V
vredensgnag
Større marginer og de forventer langt større volum.
Trane
Fikk et lite flashback til 94/95 da Radio Shack Optimus CD-3400 til $129.95 var det hotteste i amerikansk hifi og alle de hotteste hifiskribentene i fullt alvor testet den mot Theta, Mark Levinson 30/31, Forssell, Krell og resten av banden. Den fikk jaffal sin 15 minutes of fame.
Er vel mer teknologisk substans bak Oppo, men likevel...store ord :eek:
Olav E
Kanskje det er en god multispiller til en riktig pris? :)
Mvh Olav E.
FatmanFlump
Amerikanere er rare. Dersom påstandene var i nærheten av realistiske så hadde jeg kanskje trodd på dette, men med slike overdrivelser i annonsen er det vanskelig å ta det seriøst. Jeg har hørt en del bra om denne Oppo´n, og en modda versjon vil sikkert kunne nå langt, men dette er bare latterlig.
BT
Tja, når de får vann med 1/3 sukker, kullsyre og smakstilsetning til å bli verdens største merkevare, ved å fortelle folk at de blir lykkelig av å drikke det, så hvorfor ikke?
