el_mariachi
- Ble medlem
- 28.11.2002
- Innlegg
- 5.636
- Antall liker
- 394
Vet noen om denne dac'n har blitt testet / omtalt noe sted?
DAC-3 adopts up-to-date digital technology. It uses Delta digital interface, solely developed by Xindak, which transfers and upgrades 16Bit/44.1KHz digital signal of common CD to 24Bit/96KHz, and then decodes 24Bit/96KHz to improve quality of sounds. The power system is the most important one of the device. It adopts twin transformer with excellent performance to supply power to analogue and digital parts. Each power supply adopts independently voltage-stabilizing and filtering, and is separated by a high frequency inductive choke. A lot of low capacitors with excellent high frequency characteristics are used close to IC circuit. Input channels: Digital Optical, Digital Coaxial Output channels: RCA, Balanced XLR Dynamic range: 113dB Frequency response: 20Hz - 20kHz(0,±0.5dB) Signal-to-noise ratio: 112dB Output: 2V (RMS, 0dB)
Ble litt nysjerrig, koster jo ikke all verden så.........
