Mer eller mindre audiofile sitater
el_mariachi
Her er det bare å fylle på med gullegg.
Kabelselger skrev:
I en blindtest hvor det kobles kabler frem og tilbake vil dette som regel være totalt i favør av den dårligste kablen.
Adam Savage skrev:
I reject your reality, and substitute my own
Valvester
Manualen til Rega P3 skrev:
Don’t worry about visible dust on the record surface, this is brushed aside by the
stylus and any that collects on the stylus can be easily blown away. In general, record
cleaning is overdone and one should not believe all the claims made by record cleaner
manufacturers.
JENO
Saksvik - Trøndelag
"To every complex question there is a simple, easy to understand, wrong answer."
-Ivan Beaver, Danley Soundlabs
"It is not "open-minded" to reject knowledge."
-Bob Lee, QSC
JB rünnhilde
Vik fra meg, o kjetterske vranglærere! Jeg hører forskjell på alt! Halleluja!
8)
JENO
Saksvik - Trøndelag
Just for yucks, if you're looking to buy speakers, contact the company and ask for their polar response plots. You'll get:
1. We don't have them (translation, we don't have a clue how our speakers perform); or,
2. We have them but don't give them out (translation, they either don't have them or there is something about their speakers they don't want you to find out); or,
3. Where can we send them (translation, good bet they're good speakers for the designed intended use).
EDIT: There is a fourth response I heard once ... you're too stupid to understand what the plots mean. (Came from a fine English company ... name starts with a "B".) Ok, then. Next.
__________________
Dennis Erskine CFI, CFII, MEI
Erskine Group, Inc.
Subject Matter Expert
Certified Home Theater Designer
Ulf-B
8)
Hehe - Vik fra meg, o kjetterske vranglærere! Jeg hører nesten ikke forskjell på noe. Bare såvidt - if you squeeze my arm - og knapt nok da. Halleluja!
