Resultater 1 til 2 av 2
Abonnér på denne tråden
  1. #1
    Hifi-entusiast Nolfi's Avatar
    Jul 2006
    Tagget i
    0 Innlegg
    Zu Audio - anbefalinger?
    Hei.
    Jeg skal kjøpe meg nye høyttalere og er blitt imponert over utseendet av Zu sine. Masse supre reviews finnes også av de ulike modellene. Dette er bra!
    Jeg har aldrig selv hørt disse, så jeg trenger litt input fra dere
    Vurderer Zu Druid og Zu Essence. Også Zu Soul er interessant og oppgraderingen SuperFly er jo også det, men den koster litt..
    Højttalerne skal formidle fra et sett Naim 5i eller XS kombo (cd/amp).
    Input mottas med takk!
    Mvh. Nolfi
  2. #2
    Jul 2006
    Tagget i
    0 Innlegg
    Fikk et svar fra Zu Audio ang. Zu Soul / Soul Superfly / Essence:
    Main differences between the Standard and Superfly are cosmetic, but there is a difference with the tweeter network. The Superfly will be a bit more detailed, and have that extra splash in the higher frequency. Really noticeable in the upper mid to highs, especially vocals.
    The Druid is no longer available. The Soul is definitely better in every way.
    It is more extended from top to bottom. It is more detailed, more relaxed, easier to place and not room finicky.
    The Superfly and Essence are completely different. Different drivers and construction.
    The Essence will play a bit deeper for things like pipe organ, but with the sacrifice of not so much in the kick drum and tom tom.
    The Soul Superfly, still plays pretty deep. We're getting in room measurements down to 30 Hz.
    Basically here's the breakdown. If you're in to gutsy rock & roll, electric blues, etc. Real blood and guts of music, then Soul.
    If you're in to more classical, jazz (not so much with vocals), orchestral, etc., then Essence.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
