Spennende DAC/pre fra Emotiva
Bjørn ("Orso")
Emotiva som er kjent for å lage knakende gode produkter til prisen skal lansere en DAC med volumkontroll. Emotiva XDA-1 er navnet og prisen er antydet til 299 USD. Mulig den dukker opp i august.
Litt info:
Frequency response: 5-50Khz
S/N: in excess of 110db
THD+N: 0.02%
Ground floor noise: 10uV
Output voltage: 1V nominal, 12V peak
Lonnie has also reiterated that the XDA-1 connected directly to an amplifier provides the highest quality of sonic reproduction, if that configuration works in your system.
Has full output attenuator (volume control) - preamp could be bypassed - a remote control is to be included for this purpose
It is 1RU (1 Rack Unit = 1.75 inches) in height
Cosmetics are currently being updated from early test models
Smaller black trim accessories are in the works for an all-black look
Inputs (both)
1) AES/EBU
2) Coax Digital
2) Optical Digital
1) USB (Should be PC & Mac Compatible)
Outputs
1) L/R Unbalanced RCAs
1) L/R Balanced XLRs (all outputs are hgh voltage)
Triggers (automatic on/off for amplifiers and XDA-1 itself)
1) 12v output trigger
1) 12v input trigger
Analog Devices AD1955 DAC, with 384k oversampling, and 1V rms (7V peak for extended dynamics), 24-bit, 192 kHz Sample Rate PCM Audio Data, 120 dB SNR/DNR (not muted) at 48KHz Sample Rate (A-Weighted Stereo), -110 dB THD+N (0.0003162%)
Burr Brown buffers coming out of the DAC
6 fully discrete output stages
Selectable inputs
Segmented power supply
The XDA uses a Dual dif input stage with crosslinked current sources, Darlington VAS stage and Darlington output stages, so the speed and current it can deliver is like night and day different from the ERC. So as good as the ERC sounded (and to be honest I thought it was amazing), the XDA is in a league all its own.
A little more detail from Lonnie regarding the quality and finesse of the XDA-1 design:
The DAC used in the XDA is the AD1955 which is the same DAC as used in the ERC-1, But the real magic is in the analog drive stage after the DAC. In the ERC it has a single stage drive where the XDA uses a Dual Differential input stage with cross linked current sources, Darlington VAS stage and Darlington output stages. The discrete output stage can easily produce in excess of 2 amps of current and swing in excess of 12v. So it will completely take all cables out of the equation.
http://emonatics.com/XDA-1.shtml
Usikker om bildene under er helt representative. Det ble nemlig avgjort at det kosmetiske skulle endres noe og har gjort at den er blitt forsinket.
pahf
huttuheita
Spennende, til den prisen er den helt klart verdt og prøve
Puscifer
Akkurat hva jeg trenger. ;D Venter i spenning. 8)
Knut :)
ketped
Fredrikstad
Så da vil en forforsterker bli overflødig?
Er det noen som selger Emotiva i norge eller må det importeres selv?
Bjørn ("Orso")
En aktiv forforsterker vil nesten alltid tilføre forvrengning. Så å gå rett fra kilden til effektrinn gir som oftest renere, åpnere og mer detaljert lyd. Det negative er at det kan bli for avslørende for en del anlegg.
Emotiva selger kun rett fra egen fabrikk. Og takk for det. Ellers hadde prisen vært vesentlig høyere.
Bjørn ("Orso")
Fikk e-post fra Emotiva i dag.
XDA-1 is a couple of months out for the release. Currently there is no pricing or shipping information or specifications at this time. Please keep up to date on our website www.emotiva.com and listen also to our Emocasts.
Puscifer
Da er en XDA-1 Bestilt/reservert.
"Emotiva will contact you about order details before your order ships (around November 30, 2010)"
http://emotiva.com/xda1.shtm
Knut :)
DIY_dude
OSLO
Hvis den leverer 2 ampere og 12 V peak så trenger man jo nesten ikke effektforsterker engang. ;D
Jeg skjønner riktignok ikke poenget med et diskret buffertrinn når de allikevel bruker OPA2134 til I/V. ::) Men prisen var ikke noe å klage på i alle fall.
Puscifer
Hei :)
Kan du utdype disse tingene for oss som ikkke er så teknisk inne i det ?
Knut :)
united
Indre Østfold
Den fjernkontrollen, kan man velge kilde med den?
Hvis den ikke kun er for volumkontroll, er dette en meget interessant DAC for meg også.
Vært på jakt etter en "budsjett-DAC" med fjernkontroll en stund.
Puscifer
Hvis du ser på bildene på siden, så ser du funksjonene på fjernkontrollen.
http://emotiva.com/xda1.shtm#
Knut :)
Bjørn.H
Å? -forklar. ::) -Burr Brown og Delta Sigma er vel ikke heeelt det samme..?
coolbiz
Sydvestlandet
1) multibit er ikke heeelt det samme som Sigma-Delta. (det er det "motsatte")
2) Burr Brown er ikke heeelt det samme som Analog Devices.
united
Indre Østfold
Knut :)
Takk, den kontrollen så veldig fin ut.
Da er det selve lydkvaliteten på DAC'n det står på.
Så ut som om den kunne levere 230V iallefall.
Puscifer
XDA-1 $349.00
Freight $109.85 FedEx Economy
Total $458.85
Ca 2700 NOK.
Jeg hadde reservert da prisen var 299 USD Så da blir prisen med frakt: Ca 2400 NOK
MVA tilkommer jo selvsagt senere !
XDA-1 $299.00
Total $408.85
Ca 2400 NOK
