Side 1 av 2 12 SisteSiste
Resultater 1 til 20 av 30
Abonnér på denne tråden
  1. #1
    Roysen
    Guest
    Ny gigant forforsterker fra Audio Research
    Audio Research Reference Anniversary Preamplifier
    Dette blir nok noe aldeles storveis:
    The Reference Anniversary's all-tube, class-A, triode audio circuit uses no feedback. The dual-mono gain stage has eight 6H30 tubes -#8211; four per channel. The separate power supply is immensely overbuilt, "ensuring unrivalled dynamic headroom." It features twice the power-supply energy storage as that of previous Audio Research Reference preamps. There are separate low- and high-voltage transformers and separate vacuum-tube regulation (6550C and 6H30 tubes) for each channel. Multiple stages of electronic regulation are used. Separate umbilicals for each channel attach the power supply to the audio chassis. All critical components were designed and manufactured solely for use by Audio Research.
    The front-panel layout is identical to that of the Reference 5, with knobs for volume and input on either side of a vacuum-fluorescent display. Six small aluminum buttons provide control functions, which are duplicated on the Reference Anniversary's remote control. Inputs and outputs are typical of recent Audio Research preamps: seven balanced/single-ended inputs and two pairs of balanced/single-ended main outputs along with a monitor (record) output.
    When the Reference Anniversary is turned on, the vacuum-fluorescent display will read "Anniversary Edition Reference Preamplifier 1970-1971" and begin to count up, year by year, until it reads "1970-2010." Silver handles are standard on silver units, but all-black units are also available. For optimal sonics and beauty, the top covers of both chassis are smoked acrylic. Black metal covers are also available at no additional cost.
    The Reference Anniversary will have its own website -- www.astound-me.com -- that will allow a 360º view front and back and a 180º view above.
    The Reference Anniversary will be available for only one year, Audio Research's 40th. At this time in 2011, production will cease
    Roysen
  2. #2
    Hifi Freak Music4all's Avatar
    Apr 2009
    Tagget i
    0 Innlegg
    Sitat Sitat fra Roysen
    Roysen
    Heisan & takk for sist Hmm, er det også et fremtidig sikle / investerings & oppgraderingsobjekt ? ? ?
    Amp : Krell S 300 I Lyd : Denon DCD 3560 Bilde: Sony BDP 5000 ES HT : PSB New Stratus, internwiret med Renaissance Audio Blue Standard <br />HT kabler : Renaissance Audio Blue Standard, biwiret Signalkabler : Renaissance Audio Blue Standard &amp; Renaissance Audio Blue Signature Strømkabler/filter : Furutech
  3. #3
    Roysen
    Guest
    Sitat Sitat fra DoMentor
    Roysen
    Hei, DoMentor!
    Takk for sist!
    Nei, jeg tror vel egentlig ikke denne havner hos meg. Jeg er veldig fornøyd med de preampene jeg har og om jeg skulle finne på å kjøpe en til vil nok det bli en transistor konstruksjon.
    Roysen
  4. #4
    Apr 2009
    Tagget i
    0 Innlegg
    Roysen
    Hei, DoMentor!
    Takk for sist!
    Roysen
    Oki, tja du begynner vel å få litt snadderstash å velge mellom etterhvert skulle jeg tro, jah
  5. #5
    Hifi-entusiast
    May 2007
    Tagget i
    0 Innlegg
    Hvor dyr blir den tro ?
  6. #6
    Hifi Freak Cobra2's Avatar
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Gjesp. Tror heller jeg venter til neste jubileum, og ser om de ikke klarer noe dyrere.
    Arne K
    Of all the things I've lost, I miss my mind the most.
    For sale:
    http://www.hifisentralen.no/forumet/...ser&userid=701
  7. #7
    Hifi Freak Finn M's Avatar
    Sep 2008
    Tagget i
    0 Innlegg
    Ja, ja. Da måtte ARC også hive seg på bølgen og komme med en svindyr to bokser....
    Men kommer jeg til å bytte ut min kjære ARC Reference 3...? Aldri i livet!
    Ayon CD-3sx - darTZeel CTH8550 - Marten Django L - Transparent Reference MM2 kabling (XLR/høyttaler/strøm) - Audio Insight Isovolt - Basscontinuo rack
  8. #8
    Moderator bambadoo's Avatar
    Oct 2002
    Tagget i
    3 Innlegg
    Hvorfor så mange rør i et linjetrinn?
    I don't believe in system matching. If something is good, it's good. If it only sounds good under certain conditions, it is not good - it is incorrect. - Charles Hansen
  9. #9
    Hifi Freak Rudi's Avatar
    May 2004
    Syd for det nordre, øst for det vestre, så m.a.o midt ute i skauen der hvor ulvene vanker.
    Tagget i
    2 Innlegg
    Endelig en skikkelig oppfølger til SP-10 ??
    ルディさん Analog-testskribbler og hvistnok vinyl Guru for bla www.Audiophile.no Har drevet med platespiller hobbyen i over 40 år, så litt erfaring har jeg. Har testet 50 armer, 67 Riaa'er og 359 pickuper August 2018. 150 av pickupene har jeg publisert tester på. Når jeg er på HFS er det fordi analog lyd er min store interesse. Mine tester og pickuplista kan du lese under Rudi's vinylhjørne på Audiophile.no. Til info: Jeg får IKKE betalt for mine skriblerier/tester av noen.....desverre .
  10. #10
    Rubinmedlem JanR's Avatar
    Jan 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra Rudi
    Endelig
    /jan
    Nomen mihi Legio est, quia multi sumus
  11. #11
    Hifi Freak tweakMan's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Hm... Lurer på hvor lenga man holder seg til 6h30 røra...
    fjellvåk
    Guest
    Sitat Sitat fra Imperial
    Ihvertfall ut 2011 kan det se ut som.....og bra er det, ingen grunn til noe annet.
  13. #13
    Feb 2002
    Tagget i
    0 Innlegg
    Bare ikke noen hører om WE 175HQ/TAT-1 så er vi safe...
    Kaare G. Opsahl
    Guest
    Minimum 5000 timer med innbrenning!!
  15. #15
    Feb 2002
    Tagget i
    0 Innlegg
    Sykt...
    Feb 2007
    Tagget i
    0 Innlegg
    Ser man det, ja.
    Da spørs det jaggu om ikke Ref.5'en ikke blir nødt til å finne seg et nytt hjem, gitt.
    -Nei da. Den blir stående i all overskuelig framtid.
    Audio Research, SME, Oracle, Ortofon, Electrocompaniet, Audio Note, Respons, Isotek, Black Magic.
  17. #17
    Hifi Freak FZ's Avatar
    Apr 2002
    Tagget i
    0 Innlegg
    Torget
    Den kom for snart 25 år siden og het SP-11
  18. #18
    Æresmedlem Audiophile-Arve's Avatar
    Nov 2002
    Kysten av Nordvestlandet. I aller argaste nynorskdistriktet
    Tagget i
    5 Innlegg
    Sitat Sitat fra FZ
    Nei, det var snarare ein støyfri, transistorbasertstrauforsyningsversjon av SP 10. Eg høyrde SP 11 og fann ut at eg heller gjekk for rimelegare pris og råare dynamikk, og kjøpte gamleutgåva.
    Kunne verkeleg tenkt meg å prøve noko nytt. Men det er vel ikkje riaa på denne, så....
    Nokon som veit prise, forresten?
    Helsing Arve;
    www.audiophile.no går så det susar - nesten attende til gamle høgder!
    Ta kontakt om du vil ha testa noko...
  19. #19
    Hifi Freak
    Nov 2007
    Tagget i
    0 Innlegg
    Beskjedne $25.000,-
  20. #20
    Feb 2007
    Tagget i
    0 Innlegg
    Om det medfører riktighet at prisen i USA blir 25.000,- USD, noe som ikke vil
    forundre meg, skal man ikke bli mindre forundret om prisen her hjemme havner på
    "feil" side av 250.000,- NOK.
    Som sagt: Man får kose seg etter beste evne med det man har!
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
