Ny gigant forforsterker fra Audio Research
R
Roysen
Audio Research Reference Anniversary Preamplifier
Dette blir nok noe aldeles storveis:
The Reference Anniversary's all-tube, class-A, triode audio circuit uses no feedback. The dual-mono gain stage has eight 6H30 tubes -#8211; four per channel. The separate power supply is immensely overbuilt, "ensuring unrivalled dynamic headroom." It features twice the power-supply energy storage as that of previous Audio Research Reference preamps. There are separate low- and high-voltage transformers and separate vacuum-tube regulation (6550C and 6H30 tubes) for each channel. Multiple stages of electronic regulation are used. Separate umbilicals for each channel attach the power supply to the audio chassis. All critical components were designed and manufactured solely for use by Audio Research.
The front-panel layout is identical to that of the Reference 5, with knobs for volume and input on either side of a vacuum-fluorescent display. Six small aluminum buttons provide control functions, which are duplicated on the Reference Anniversary's remote control. Inputs and outputs are typical of recent Audio Research preamps: seven balanced/single-ended inputs and two pairs of balanced/single-ended main outputs along with a monitor (record) output.
When the Reference Anniversary is turned on, the vacuum-fluorescent display will read "Anniversary Edition Reference Preamplifier 1970-1971" and begin to count up, year by year, until it reads "1970-2010." Silver handles are standard on silver units, but all-black units are also available. For optimal sonics and beauty, the top covers of both chassis are smoked acrylic. Black metal covers are also available at no additional cost.
The Reference Anniversary will have its own website -- www.astound-me.com -- that will allow a 360º view front and back and a 180º view above.
The Reference Anniversary will be available for only one year, Audio Research's 40th. At this time in 2011, production will cease
Roysen
Music4all
Roysen
Heisan & takk for sist :) Hmm, er det også et fremtidig sikle / investerings & oppgraderingsobjekt ? ? ? ;D
Mvh :)
R
Roysen
Roysen
Mvh :)
Hei, DoMentor!
Takk for sist!
Nei, jeg tror vel egentlig ikke denne havner hos meg. Jeg er veldig fornøyd med de preampene jeg har og om jeg skulle finne på å kjøpe en til vil nok det bli en transistor konstruksjon.
Roysen
Music4all
Roysen
Mvh :)
Hei, DoMentor!
Takk for sist!
Roysen
Oki, tja du begynner vel å få litt snadderstash å velge mellom etterhvert skulle jeg tro, jah ;D
Mvh :)
Cobra2
Gjesp. Tror heller jeg venter til neste jubileum, og ser om de ikke klarer noe dyrere.
Arne K
Finn M
Ja, ja. Da måtte ARC også hive seg på bølgen og komme med en svindyr to bokser....
Men kommer jeg til å bytte ut min kjære ARC Reference 3...? Aldri i livet! 8)
tweakMan
Hm... Lurer på hvor lenga man holder seg til 6h30 røra...
F
fjellvåk
Ihvertfall ut 2011 kan det se ut som.....og bra er det, ingen grunn til noe annet.
tweakMan
Bare ikke noen hører om WE 175HQ/TAT-1 så er vi safe...
Ramses
Ser man det, ja.
Da spørs det jaggu om ikke Ref.5'en ikke blir nødt til å finne seg et nytt hjem, gitt. ;D
-Nei da. Den blir stående i all overskuelig framtid. :)
FZ
Rudi skrev:
Endelig en skikkelig oppfølger til SP-10 ?? ;)
Den kom for snart 25 år siden og het SP-11 ;) ;)
Audiophile-Arve
Nei, det var snarare ein støyfri, transistorbasertstrauforsyningsversjon av SP 10. Eg høyrde SP 11 og fann ut at eg heller gjekk for rimelegare pris og råare dynamikk, og kjøpte gamleutgåva.
Kunne verkeleg tenkt meg å prøve noko nytt. Men det er vel ikkje riaa på denne, så....
Nokon som veit prise, forresten?
Ramses
Om det medfører riktighet at prisen i USA blir 25.000,- USD, noe som ikke vil
forundre meg, skal man ikke bli mindre forundret om prisen her hjemme havner på
"feil" side av 250.000,- NOK.
Som sagt: Man får kose seg etter beste evne med det man har!
R
Roysen
Lille_Adam skrev:
Beskjedne $25.000,-
Sammenlignet med mye annet er jo det der rene røverkjøpet, og jeg tviler på at ARC lager et statement produkt som ikke tåler sammenligning med det aller beste på market.
Roysen
Lille_Adam
Det var da også derfor jeg skrev "beskjedne". Å bruke ordet røverkjøp om en forforsterker til 150 laken krever nok at man ligger på et lønnstrinn langt, laaangt over mitt, men for et statementprodukt fra en produsent som Audio Research kunne prislappen fort vært mye verre.
R
Roysen
Så flott da er vi jo enige. Ellers burde formuleringen min nok vært "røverkjøp". ;)
Roysen
jakr
uten tvil en "tøff sak" og så leveres den i sort. jeg så jo på ref 3-en som tilnærmet permanent her i huset, men nå ser det nesten ut som fristelsen nærmer seg et nivå der planlegging av nye duppeditter i racket blir neste steg 8)
sikkert 20 ukers leveringstid på denne saken
jakr
F
fjellvåk
Roysen skrev:
Lille_Adam skrev:
Beskjedne $25.000,-
....jeg tviler på at ARC lager et statement produkt som ikke tåler sammenligning med det aller beste på market.
Roysen
De lager allerede produkter som tåler den sammenligningen, denne nye saken her tar den nok bare hinsides lengre enn det andre på markedet.
Cobra2
Jeg har nå min sterke tvil om akkurat det...
Arne K
tweakMan
:D
Dette ser jo ut til å være en pryltrimma Ref 5, hvis man studerer bilder av kretskort og layout og slik ser man MER enn
dobbling av kretser i vitale områder.
Men Ref 5 ser ut til å være utgansgpunktet ja, rent designmessig.
Dette er ikke noe nytt med andre ord. Dette er superbygge deluxed av kjent fungerende lest!
Og ja, det var det med flere nivå da... tja, det er iallefall den råeste på markedet akkurat nå, det tror jeg!
Så hvis jeg skal tippe på røverkjøp, så må det bli ReF5 !!!
R
Roysen
Arne K
Selvsagt! Hadde ikke ventet noe annet fra DIY gutta som vet bedre enn en skarve bransjeaktør som ARC hvordan tingene skal lages for å lyde best. ;)
Roysen
mag
Støtter deg fullt ut Imperial. Tror nok også Ref 5 er det beste kjøpet.
Vel, særlig med tanke på at jeg venter på at en Ref 5 snart ankommer :)
Må si ARC er aktive med nye produkter om dagen, men håper og tror jeg kan leve en god stund med den aldrende, avdankede
og snart utgåtte Ref 5 til ARC.
De svarte håndtaken kommer til å forsvinne også. Her blir det rent sølv på alt. Som å få et nytt anlegg i stuen.
mvh mag.
R
Roysen
Er det noen som virkelig tror at ARC slipper et produkt på toppen av sitt produkthierarki med tilhørende pris dersom de har et mindre kostbart produkt under i hierarkiet som lyder bedre?
Selvsagt er denne bedre enn Ref 5, men det kan selvsagt diskuteres om lyd pr. krone er bedre.
Roysen
