Noen som har erfaring med Tact DRC?
http://www.tactlab.com/DRC/how_DRC_works.html
Tact DRC ser ut til å korrigere i frekvens og tidsdomenet, og har mulighet for target-kurver. Men den har også en etter min mening en veldig spennende funksjon jeg har savnet i andre korreksjonsløsninger.
Tact DRC systems are the only ones in the world to address the issue that sound perception is both frequency and level dependent. (Fletcher-Munson Curves) What this means is that as you change the level of your music, your perceptions of certain frequencies will get skewed - you will perceive certain frequencies as either louder or softer. The natural tonal balance of your music will be lost.
DRC is the only technology in the world that preserves natural tonal balances by dynamically adjusting your entire system in accordance to the human hearing characteristics, your hearing characteristics. By using your relative loudness perception, equal loudness curves,Tact DRC connects your sensory perceptions directly into your system. It then, for every 0.1 db level change, dynamically recalibrates your system based upon your unique loudness perceptions and full-spectrum room correction. The future of audio is here.
Tact ser også ut til å komme med en avansert 12-kanals prosessor med denne korreksjonen på alle kanaler, og som også inneholder delefilter som gjør (etter som jeg skjønner) at den kan brukes i en løsning med aktive høyttalere. Ser ut som den har samme DRC som RCS 2.2 XP (og som noen her kanskje har erfaring med?).
Support for all major decoding algorithms including HDMI support
Support for simultaneous processing of eight analog or eight digital input channels
Twelve output channels. Each output can be configured as main or subwoofer channel
Dynamic Room Correction on all twelve outputs
Subwoofer Diversity Correction can be applied to selected subwoofer channels
Variable frequency correction
Measurement and target curve normalization
Crossover filter design
On-the-fly adjustments of all correction parameters on all twelve channels
Eight channel mixer on each output
Twelve channel time alignment and level balancing
Complete system verification on all twelve channels
Impulse response screen
Fully supported by Tact-V1.0 software platform
Extensive RS232 control codes.
8 digital inputs - six SPDIF, one AES/EBU and one optical
5 stereo analog inputs - four single ended (RCA) and one balanced (XLR)
4 HDMI inputs and one output
6 digital outputs - six SPDIF and six AES/EBU
12 analog outputs - twelve single ended (RCA) and twelve balanced (XLR)
Microphone input
One 12V trigger output
Two RS232 ports - one for PC connection and one for amplifier control
Microphone input
