Critical Mass Systems
JB rünnhilde
http://www.criticalmasssystems.com/
What will Critical Mass Systems do for my audio and video system?
1.      Critical Mass Systems help establish an emotional connection with music.  Our isolation systems and direct coupling systems minimize annoyances that manifest in your soundstage through mechanical interference with your components.
2.      Isolation systems help a component perform at its optimal level by accelerating the conversion of mechanical vibration to trace amounts of heat. Direct coupling systems move energy uniformly through a rack structure and filter creating a 2-way connection between the component and the floor.  The component is freed to pass musical signals naturally with both approaches.
3.      They give you a clearer window into and through the soundstage.  They enhance the perception of a seemingly boundless, holographic soundstage of striking purity, clarity and musicality.
4.      Critical Mass Systems render clearly audible improvements in the sonic fabric of your components.  They increase bass articulation and slam.  They facilitate a more natural midrange bloom and decay.  They enable highs to extend with a more effortless sense of headroom and ease.   They facilitate a wider, deeper sound stage with greater dynamic interplay between instruments and voices.
5.      Critical Mass Systems are designed to be invisible in the musical fabric.  Like a great pair of speakers, they do their job so well they just plain disappear.  There are no trade-offs.  There are no compromises.
6.      They are designed to remove the “black wall” from your soundstage.  Testing and research confirms that black is a color like silver is a color, and that beyond black is clarity.  When coloration is removed from the sound stage instruments and voices become solidly and realistically positioned and sound more like live events.
7.      Critical Mass Systems are designed to enhance and sharpen black/white contrast in video equipment.  Testing and research confirms that mechanical degradation of the video signal from vibration causes blurred edges, ghost images and a loss of holographic image placement in the video image field.  When vibration is removed from video images, they become solidly and realistically positioned with greater front to back depth, separation and stable borders.
Dyrt er det også. Løp og kjøp.
Og de har White Paper: http://www.criticalmasssystems.com/White Paper.pdf
Sandkasser til HiFi er da ikke noen ny oppfinnelse, kanksje spesielt til platespillere. De var vel ikke alltid like vellykket, særlig mht estetikk men ... SW.
N
nb
<i>
3 tier PXK - $3300 per level, or $9900. The system is modular so the user can select the vertical spacing.
3 tier Grand Master rack is $2400 X 3 + $1500 for the rack, or $8700. The rack and GMs are custom sized.
3 tier Master rack is $2000 X 3 + $1500 for the rack, or $7500. All can be custom made.
3 tier Reference rack is $1,800 X 3 + $1500 for the rack, or $6,900. All can be custom made.
</i>
Giveaway! Den nettsiden deres innehold usedvanlig mye rart, selv til denne hobbyen å være.
P
Parelius
De har nå valgt et navn som kan få det til å gå en jævel selv i en uskyldig lyrisk sjel som meg selv;
critical mass for the uncritical masses.
Neste ... critical music for the masses ... ?
Distinctive
Den satt !
Dist ;D
Haavard
Lena
Det var da pent å se på da.
Håvard
