Side 1 av 2 12 SisteSiste
Resultater 1 til 20 av 29
Abonnér på denne tråden
  1. #1
    Æresmedlem LMC's Avatar
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    Knall tweak for rør-folk
    hei
    fikk nettopp inn 6 av disse og installerte 2 av de under driver-rørene på ampene mine
    resultat:roligere lydbilde med bedre oppløsning over hele linjen
    kjøpte de hos
    http://www.acoustic-dimension.com/
    topp service!
    Allnic Absorb-GEL™
    Vacuum Tube amplifier is an excellent choice of high-end audio equipment for its smooth, detailed and realistic sound. However depending on it's type vacuum tube generates "micro-phonic noise" resulted from its vibrations and resonance's. The micro-phonic noise is prodded and escalated by surroundings such as amplifier chassis, tube socket and loudspeakers.
    The micro-phonic noise is depending on vacuum tube type and brands. Basically weak construction and higher mutual conductance generates higher noise.
    There have been varies efforts to reduce micro-phonic noise of vacuum tubes, such as rubber rings and metal caps, although its result was not outstanding.
    Absorb-GEL™ Vacuum Tube Damper is an innovative solution resulted from several years of intensive research and experiments by the Allnic Audio Lab., significantly reducing vacuum tube micro-phonic noise. All the components and materials of Absorb-GEL™ Vacuum Tube Damper were carefully selected and customized through repeated experiments. Absorb-GEL™ Vacuum Tube Damper isolated and floats tubes from primary vibration transmission media, such as amplifier chassis or tube sockets. And Absorb-GEL™ Vacuum Tube Damper also absorbs direct airwaves from loudspeakers.
    Successful noise reduction of Absorb-GEL™ Vacuum Tube Damper was proven in our laboratory test and various field tests by high-end audio listeners. Fig. 1 is a snap-shot of oscilloscope showing dirty noise when tube amplifier chassis was impacted. Fig. 2 shows very clear output when Absorb-GEL™ Vacuum Tube Damper was used under the same impact on tube amplifier chassis. Laboratory measurement easily shows noise reduction rate up to 1/100 (-40dB).
    solderslinger og raskere enn sin egen skygge
  2. #2
    Rubinmedlem JanR's Avatar
    Jan 2006
    Tagget i
    0 Innlegg
    Hmm, interesant.
    Mere tro på denslags tweaks enn rørdempere/ringer. Skal sjekkes ut.
    Takk for tips.
    /jan
    Nomen mihi Legio est, quia multi sumus
  3. #3
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    satser på å kombinere tunge messingdempere og disse gel-basene
    Leif
  4. #4
    Æresmedlem rama's Avatar
    Jun 2003
    oslo
    Tagget i
    8 Innlegg
    wtf, ekstra fot til røret?
    og de var dyre...!
    kan godt tenkes at de gjør nytte for seg, though.
    Hornalliansen
  5. #5
    Roysen
    Guest
    Sitat Sitat fra LMC
    Leif
    Får du laget demperne selv eller hvor kjøper du de? Jeg kommer også til å prøve denne gelen.
    Roysen
  6. #6
    Æresmedlem rolfozzy's Avatar
    Nov 2005
    Tagget i
    0 Innlegg
    Gjør de gamle rør som nye ?
  7. #7
    Mar 2003
    Tagget i
    0 Innlegg
    Sitat Sitat fra LMC
    Så low-end audio listeners vi ikke høre noen forskjell?
    Jeg skjønner at jeg må finne ut hvilken kategori jeg tilhører før jeg vurderer anskaffelse.
    Masse utstyr - men mest musikk!
  8. #8
    Moderator bambadoo's Avatar
    Oct 2002
    Tagget i
    3 Innlegg
    Takker for et godt tips LMC..
    I don't believe in system matching. If something is good, it's good. If it only sounds good under certain conditions, it is not good - it is incorrect. - Charles Hansen
  9. #9
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    erato:
    sitatet er fra teksten i produktinfoen og IKKE fra meg!
    jeg hører hva de gjør så får du selv finne ut hvilken kategori du tilhører
    Leif
  10. #10
    Mar 2003
    Tagget i
    0 Innlegg
    Sitat Sitat fra LMC
    erato:
    Leif
    Hei sann. Ja jeg så at det var fra produktinfoen så ta det helt med ro Tviler ikke på at rørdemping funker - det er ingen grunn til at det ikke skal gjøre det, men reagerte på terminologien. Ved å formuleres seg slik sikrer man seg at de som tviler blir definert som low-endere, og hvem vil egentlig innrømme at de er low-end? Det blir litt sånn tradisjonell livsstilsreklame over det. Vel vel.
  11. #11
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    syntes intuitivt at dette var en god ide
    har også noen varianter til 300B fra chimera labs hjemme
    skulle bare vært en variant som rørsokkel med integrert gel-demping for DIY ere
    alt som mangler nå er rør med innbakt demping av glødetråden som egentlig er det største problemet hva gjelder mikrofoni
    imo
  12. #12
    Hifi Freak Fosse's Avatar
    Aug 2003
    Tagget i
    6 Innlegg
    Kan du ta et mål av diameteren på "sokkelen" LMC? Ser at de bygger noe mer enn røret.
    Studer A80RC | Bergmann Galder og Odin | Kuzma 4point | SME V-D | Schick | Vdh Colibri XCP | DV XV-1s | Jan Allaerts MC2 Finish Gold | Garrard 301 med CTC power | EMT 997 | DV507MKII | EMT TSD15 og TMD25 | SPU Classic E | Music First | DV SUP-200 | Fidelity Research XF-1 | Gryphon Head | Allnic H-1500IIPlus | Accuphase C-27 | Eximus CD5 | DIY pre | Joule Electra VZN-160|Air Tight ATM-2 | Harbeth 40.2 |
    Bel Canto Dac 1.5 | Ars-Sonum Filarmonia SE | Tannoy Sandringham
  13. #13
    Nov 2005
    Tagget i
    0 Innlegg
    Sitat Sitat fra JanR
    Hmm, interesant.
    Takk for tips.
    /jan
    Da kjøper du et par slike så vi kan få testa de ?
    Størrelse 6922.
  14. #14
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    Sitat Sitat fra Fosse
    ja jeg snakket nettopp med en kompis med GM-20 og soklene der er forsenket i chassis.
    jeg måtte bygge om mine blokker slik at rør-sokkelen kom på oversiden av chassis ellers bygget gel-demperen for mye og pinnene er ikke lenger enn vanlige noval-pinner
    må forøvrig gjøre det samme på riaa´n...mulig jeg rekker det ila uken
    legger inn målene senere i dag
  15. #15
    Jan 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra rolfozzy
    Hmm, interesant.
    Takk for tips.
    /jan
    Størrelse 6922.
    Neppe
    Blir det kjøpt noe så blir det til 6SN7.
    /jan
  16. #16
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    fornuftig fordi octal-rør er ofte mere mikrofoniske enn de mindre noval-rørene
    imo
    Leif
  17. #17
    Hifi Freak
    Oct 2003
    Tagget i
    0 Innlegg
    De som bruker 5687-rør bør visstnok holde seg langt unna. Heater current limit på 0,8A
    I den nye preampen min har jeg festet rørsokkelen til en 5mm aluplate som igjen bare er limt til chassis med store mengder "tech7" transparent lim. Rent mekaniske var det svært vellykket og kosnaden var mikroskopisk sammenliknet med dette.
    AppleTV, Squeezebox, RAKK dac, Clearaudio Champion, AudioTechnica EV33, DIY jfet riaa, The Heretical preamp, DIY F5, Allen Wright kt88 klone, H6 klone.
  18. #18
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    men det er ikke sikkert at alle med kommersielle produkter er villige til å brekke ut rørsoklene for å lime dem fast igjen med tech 7
    disse kan dessuten flyttes rundt mellom apparater
    har du slike trix så kan du vel vise dem under DIY istedet for å klage på at disse var dyre
    alt er jo dyrt sammenliknet med diy reodor felgen løsninger
    Leif
  19. #19
    Hifi Freak JK's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Noen som vet om disse dempesoklene kan brukes til 6H30 rør?
    ARC REF-CD8 /ARC REF10 /ARC REF210/Meadowlark Blue Heron II/Renaissance Blue Master Signalkabler +Renaissance Blue Master høyttalerkabler/Transparent Audio nettkabler/PS Audio P5+DIY Nettfilter
    I Was Born With Nothing, I Still Have Most of It Left - Calvin Russell
  20. #20
    Aug 2006
    Drøbak
    Tagget i
    5 Innlegg
    Torget
    6h30 trekker 0,9A på gløden så den er vel strengt tatt over grensen på 0,8A
    Leif
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
