LMC
hei
fikk nettopp inn 6 av disse og installerte 2 av de under driver-rørene på ampene mine
resultat:roligere lydbilde med bedre oppløsning over hele linjen
kjøpte de hos
http://www.acoustic-dimension.com/
topp service!
Allnic Absorb-GEL
Vacuum Tube amplifier is an excellent choice of high-end audio equipment for its smooth, detailed and realistic sound. However depending on it's type vacuum tube generates "micro-phonic noise" resulted from its vibrations and resonance's. The micro-phonic noise is prodded and escalated by surroundings such as amplifier chassis, tube socket and loudspeakers.
The micro-phonic noise is depending on vacuum tube type and brands. Basically weak construction and higher mutual conductance generates higher noise.
There have been varies efforts to reduce micro-phonic noise of vacuum tubes, such as rubber rings and metal caps, although its result was not outstanding.
Absorb-GEL Vacuum Tube Damper is an innovative solution resulted from several years of intensive research and experiments by the Allnic Audio Lab., significantly reducing vacuum tube micro-phonic noise. All the components and materials of Absorb-GEL Vacuum Tube Damper were carefully selected and customized through repeated experiments. Absorb-GEL Vacuum Tube Damper isolated and floats tubes from primary vibration transmission media, such as amplifier chassis or tube sockets. And Absorb-GEL Vacuum Tube Damper also absorbs direct airwaves from loudspeakers.
Successful noise reduction of Absorb-GEL Vacuum Tube Damper was proven in our laboratory test and various field tests by high-end audio listeners. Fig. 1 is a snap-shot of oscilloscope showing dirty noise when tube amplifier chassis was impacted. Fig. 2 shows very clear output when Absorb-GEL Vacuum Tube Damper was used under the same impact on tube amplifier chassis. Laboratory measurement easily shows noise reduction rate up to 1/100 (-40dB).
kjøpte de hos
topp service!
Allnic Absorb-GEL
