Knall tweak for rør-folk
LMC
Drøbak
hei
fikk nettopp inn 6 av disse og installerte 2 av de under driver-rørene på ampene mine
resultat:roligere lydbilde med bedre oppløsning over hele linjen
kjøpte de hos
http://www.acoustic-dimension.com/
topp service!
Allnic Absorb-GEL™
Vacuum Tube amplifier is an excellent choice of high-end audio equipment for its smooth, detailed and realistic sound. However depending on it's type vacuum tube generates "micro-phonic noise" resulted from its vibrations and resonance's. The micro-phonic noise is prodded and escalated by surroundings such as amplifier chassis, tube socket and loudspeakers.
The micro-phonic noise is depending on vacuum tube type and brands. Basically weak construction and higher mutual conductance generates higher noise.
There have been varies efforts to reduce micro-phonic noise of vacuum tubes, such as rubber rings and metal caps, although its result was not outstanding.
Absorb-GEL™ Vacuum Tube Damper is an innovative solution resulted from several years of intensive research and experiments by the Allnic Audio Lab., significantly reducing vacuum tube micro-phonic noise. All the components and materials of Absorb-GEL™ Vacuum Tube Damper were carefully selected and customized through repeated experiments. Absorb-GEL™ Vacuum Tube Damper isolated and floats tubes from primary vibration transmission media, such as amplifier chassis or tube sockets. And Absorb-GEL™ Vacuum Tube Damper also absorbs direct airwaves from loudspeakers.
Successful noise reduction of Absorb-GEL™ Vacuum Tube Damper was proven in our laboratory test and various field tests by high-end audio listeners. Fig. 1 is a snap-shot of oscilloscope showing dirty noise when tube amplifier chassis was impacted. Fig. 2 shows very clear output when Absorb-GEL™ Vacuum Tube Damper was used under the same impact on tube amplifier chassis. Laboratory measurement easily shows noise reduction rate up to 1/100 (-40dB).
JanR
Hmm, interesant.
Mere tro på denslags tweaks enn rørdempere/ringer. Skal sjekkes ut.
Takk for tips.
/jan
LMC
Drøbak
satser på å kombinere tunge messingdempere og disse gel-basene
Leif
rama
biskopen av holmlia
oslo
wtf, ekstra fot til røret?
og de var dyre...!
kan godt tenkes at de gjør nytte for seg, though.
R
Roysen
Leif
Får du laget demperne selv eller hvor kjøper du de? Jeg kommer også til å prøve denne gelen.
Roysen
rolfozzy
Gjør de gamle rør som nye ?
erato
Så low-end audio listeners vi ikke høre noen forskjell?
Jeg skjønner at jeg må finne ut hvilken kategori jeg tilhører før jeg vurderer anskaffelse.
LMC
Drøbak
erato:
sitatet er fra teksten i produktinfoen og IKKE fra meg!
jeg hører hva de gjør så får du selv finne ut hvilken kategori du tilhører
Leif
erato
LMC skrev:
erato:
Leif
Hei sann. Ja jeg så at det var fra produktinfoen så ta det helt med ro ;D Tviler ikke på at rørdemping funker - det er ingen grunn til at det ikke skal gjøre det, men reagerte på terminologien. Ved å formuleres seg slik sikrer man seg at de som tviler blir definert som low-endere, og hvem vil egentlig innrømme at de er low-end? Det blir litt sånn tradisjonell livsstilsreklame over det. Vel vel.
LMC
Drøbak
syntes intuitivt at dette var en god ide
har også noen varianter til 300B fra chimera labs hjemme
skulle bare vært en variant som rørsokkel med integrert gel-demping for DIY ere
alt som mangler nå er rør med innbakt demping av glødetråden som egentlig er det største problemet hva gjelder mikrofoni
imo
Fosse
Kan du ta et mål av diameteren på "sokkelen" LMC? Ser at de bygger noe mer enn røret.
rolfozzy
JanR skrev:
Hmm, interesant.
Takk for tips.
/jan
Da kjøper du et par slike så vi kan få testa de ?
Størrelse 6922.
LMC
Drøbak
ja jeg snakket nettopp med en kompis med GM-20 og soklene der er forsenket i chassis.
jeg måtte bygge om mine blokker slik at rør-sokkelen kom på oversiden av chassis ellers bygget gel-demperen for mye og pinnene er ikke lenger enn vanlige noval-pinner
må forøvrig gjøre det samme på riaa´n...mulig jeg rekker det ila uken
legger inn målene senere i dag
JanR
rolfozzy skrev:
JanR skrev:
Hmm, interesant.
Takk for tips.
/jan
Størrelse 6922.
Neppe 8)
Blir det kjøpt noe så blir det til 6SN7.
/jan
LMC
Drøbak
fornuftig fordi octal-rør er ofte mere mikrofoniske enn de mindre noval-rørene
imo
Leif
andreas
De som bruker 5687-rør bør visstnok holde seg langt unna. Heater current limit på 0,8A
I den nye preampen min har jeg festet rørsokkelen til en 5mm aluplate som igjen bare er limt til chassis med store mengder "tech7" transparent lim. Rent mekaniske var det svært vellykket og kosnaden var mikroskopisk sammenliknet med dette.
LMC
Drøbak
men det er ikke sikkert at alle med kommersielle produkter er villige til å brekke ut rørsoklene for å lime dem fast igjen med tech 7
disse kan dessuten flyttes rundt mellom apparater
har du slike trix så kan du vel vise dem under DIY istedet for å klage på at disse var dyre
alt er jo dyrt sammenliknet med diy reodor felgen løsninger
Leif
JK
Noen som vet om disse dempesoklene kan brukes til 6H30 rør?
LMC
Drøbak
6h30 trekker 0,9A på gløden så den er vel strengt tatt over grensen på 0,8A
Leif
andreas
OT:
Leif
Point taken, det skal jeg selvsagt gjøre.
LMC
Drøbak
topp ;D
viktig at alle tips kommer frem slik at det blir en pool av ideer og løsninger til fremme for vårt hovedmål: BEDRE LYD
hvor bra de viser seg å være kan den enkelte teste ut selv i eget system
imo
Leif
LMC
Drøbak
hei igjen folks!
på produsentens side står det max 1A PR. PINNE, så da skulle 6h30 være OK
ellers måler de 26.82 mm i omkrets og høyde uten pinner er 20,4mm
pinnelengde er lik pinnelengden på røret
Leif
Fosse
Det er i feiteste laget for GM20 etter undertegnedes øyemål som er nøyaktig, men neppe avleser to desimaler. Et alternativ for pre, takk for tips LMC.
LMC
Drøbak
Fosse
mål med skyvelær
det gjør ingenting om de blir stående litt klemt i ytterchassiet av demperen fordi innmaten er uavhnegig av ytterdelen
Leif
Fosse
Skal sjekke litt nærmere når forsterkeriet er kaldt, men, det ser ut som det kan mangle 1-2mm, dessverre.
LMC
Drøbak
ok min kompis på Nesodden skulle også sjekke nærmere
lykke til
Leif
Sleiven
Javel,
På bildet ser det ut som ordinære "socket savers". Hva med å prøve noen sånne til 1/10 av prisen..
http://www.tubesandmore.com/scripts/foxweb.dll/moreinfo@d:/dfs/elevclients/cemirror/ELEVATOR.FXP?item=P-ST9-900
De dyre demperne kan jo være laget av naturgummi,teflon eller annet eksotisk resonansdempende materiale som forsvarer prisen.
Er de myke eller harde?
Mikrofoni må alltid bekjempes, og chassis vibrerer lett. En dekobling der bør jo hjelpe, men kapasitansen i røret øker jo med lengre tilførslelssnabler...
Sleiven
PS ellers så har jeg revers mikrofoni!!. Dvs når jeg kjører 36triode watt i en dummy 8 ohms last (ingen høytaler) så hørte jeg plutselig 1000Hz sinusen fra 6550 rørene... Det var ikke magnetostriction fra trafoene, de var dødsstille selv med stetoskop!!
