jonas
Noen som kjenner til hva denne integrerte forsterkeren vil koste når den når butikkhyllene?
Seriøs sak på 2x150 H/K watt i 8 Ohm , og meget vellutstyrt
Type: Integrated amplifier
Power (FTC) / 20Hz 20kHz, 8 ohms, both channels
driven: 2 x 150W @ 8 ohms/2 x 300W @ 4 ohms
High Instantaneous Current Capability (HCC): ±100 Amps
Ultrawide Bandwidth @ 1W ( 0, 3dB) : 10Hz 170kHz
Discrete Amplifier Output Devices : Yes
Signal-to-Noise Ratio (IHF-A) : 109dB
EzSet: EzSet/EQ, 2.2-channel
Audio Inputs: 8
Tape Monitor Loop: Yes
Phono Input: Yes, MM and MC
Digital Audio Inputs : Rear panel:
2x coax
2x optical
Processor Input : Yes, 2.2-channel
Balanced XLR Inputs : Yes
HRS Link : Yes
Digital Audio Outputs (Coax/Optical) : Rear panel 1/0
Preamp Outputs : Yes
Subwoofer Output : Yes, dual
Power Consumption : 800W max
IR In/Out Jacks : Yes
Dimensions (H x W x D) : 165mm x 440mm x 435mm
Weight : 19.6kg
Audio Inputs: 8
2x coax
2x optical
HRS Link : Yes
Weight : 19.6kg
72 KB Visninger: 1.026
72.6 KB Visninger: 1.026
