R
Roysen
Jeg tror ikke det finnes så mye der ute som objektivt sett måler bedre enn disse, men med en pris på 250K for et par blir det vel bare med å sparke litt i grusen og håpe på et mirakel for at noe slikt skal kunne lande i stua:
Alize 7 D/A converter completely new designed to create a final resolution above 130dB
16 separate high-power transformers developing a power close to 10'000 Watts
Transformers molded in an epoxy mix providong vibration and noise reduction
Maximum Instantaneous Power:
1510W for 8 ohms
3020W for 4 ohms
6050W for 2 ohms
Maximum Continuous Power:
1250W for 8 ohms
2500W for 4 ohms
5000W for 2 ohms
Maximum Continuous Current: 252A peak
Maximum voltage swing: 110V peak
Frequency Response:
+/- 0.1 dB, 0 - 300 kHz
+/- 1 dB, 0 - 800 kHz
+/- 3 dB, 0 - 2.5 MHz
Distortion: THD + N input stage analog: 0.0005% (1 Vrms input, 80kHz bandwidth measurement), Bal or unbalanced in and for any input attenuation settings (flat with freq, 20Hz-40kHz)
Noise:
Signal to noise: >122 dB
A weighted: > 138 dB
Circuit Speed:
Slew rate: > 200 V/us
Rise time: < 200 ns
Size and Weight:
94 x 47 x 39 cm
Weight: 260 kg
http://www.goldmund.com/products/telos5000/
Roysen
1510W for 8 ohms
3020W for 4 ohms
6050W for 2 ohms
1250W for 8 ohms
2500W for 4 ohms
5000W for 2 ohms
Frequency Response:
Noise:
Circuit Speed:
Rise time: < 200 ns
Size and Weight:
94 x 47 x 39 cm
Weight: 260 kg
Roysen
59.1 KB Visninger: 2.602
