har nå bestemt meg..får jeg det jeg vil ha for cd\forsterkeren så kjøper jeg int 8s...da er nå jaffal muligheten til 5.1 lyd der...(hvis jeg skulle komme på andre tanker)
hører ikke så mye på musikk nå lenger...går mest i film..(da min musikksmak er litt sær,,så blir det mest lytting når jeg er hjemme alene)
er fortsatt i tvil når det gjelder høytalere...
holfi sier jo selv at ny integra er bedre enn gammel...
Integrated amps
Holfi at it´s best?
Even though we feel the urge to argue otherwise it is never the less a fact that the integrated amps is where our success was established. Since the first integrated amplifier from Holfi emerged in the market in 1993 the integrated amps has been where we have earned our reputation, getting quite a few awards (best integrated amp of the year, best buy of the year,etc.).
Nothing has changed - everything is new!
The basic philosophy and circuitry of the newest integrated amps from Holfi are closely related to previous models. Over the years there has been an evolution of course - better components and various finetunings has found their way into the present versions, but the revolution has nothing to do with the basic stereo quality, that we continuously offer.
The revolution is in the area of Analogue Surround. Even though we offer what´s still a 2-channel integrated amp we nowadays also built in preamp stages to handle rear, center and sub-signals. Also already there are the input/output sockets and the volume controls giving you the opportunity to play Analogue Sourround - now or later.
What´s needed and what´s the catch?
You add on the extra power amp, the extra speakers and get your signal from a multi format player and you are up and running! There is no catch - you can use it for SACD and DVD-Audio and homecinema - or any of the above. Advantages, however; are many: The Analogue Surround way you avoid degrading the sound quality in stereo, you avoid having a separate surround setup, you avoid the surround receiver, you actually benefit from your excellent stereo setup when playing surround and (if you use a Holfi multi format player) you can even play surround in outstanding quality, using Virtual Center Speaker (meaning no center speaker in reality, of course).
Better than ever?
Yes, sound quality is better than previous generations, they are more powerful and fully remote-controlled. Even without mentioning the surround capability the Int 2.5.1 and Int 8S are better products than their award winning predecessors.
Integrated amps
Holfi at it´s best?
Better than ever?
Page functions: Print page
