Resultater 1 til 11 av 11
Abonnér på denne tråden
  1. #1
    Hifi Freak Zerostat's Avatar
    Jun 2003
    Skjetten
    Tagget i
    0 Innlegg
    Torget
    Fakta om Merlin VSM og BAM
    Jeg har lest flere steder på forumet at BAM vil forårsake en del ulemper i form av effektsug etc... Her kan du lese hva konstruktøren selv skriver... interessant…
    >>> Zerostatic Cables >>>
  2. #2
    Bransjemedlem Audio Art's Avatar
    Nov 2004
    Tagget i
    0 Innlegg
    utgangspunktet/tanken bak merlin er vel OTL mat slik jeg har forstått Bobby som, etter "min" mening er den beste Synergi/matsh. Nå har ikke jeg hørt de siste versjonene av MXe på ss men, tror likevel OTL is the way to go mho.
  3. #3
    Jun 2003
    Skjetten
    Tagget i
    0 Innlegg
    Torget
    Sitat Sitat fra Cable Guy
    imho, there is no downside to the bam. the eq is in a very narrow bandwidth from 30 to 60 hz and centered at 35hz with a 5.2db boost. up 2db at 45 and 1 at 60, gone at 30. when you filter out all of the energy under 30, how much power are you saving? alot depending on the material. and a 5.2db boost over a very narrow band in less than a doubling of the power in the range and not 3.5x. so if one tries to make a box big enough to go to 32 like a competitor's speaker with a similar woofer, the usable sensitivity goes down to 84db from the vsm's 89. now there is another 5db. and with the bigger encloser the woofer has less pressure on it so the mids suffer, the woofer is more easily unloaded causing reduced playback loudness potential and much increased distortion. with the bam in, you can use a much lower powered tube amp than with a speaker using the same woofer in a large cabinet and the impedance of the vsm will undoubtedly be flatter and easier on the amp. impedance fluctuation causes increased or decreased output at a given frequency depending on whether you use ss or tubes.
    the bandpass is a must for all speakers...period. the more uniform the speaker and the more continuous it sounds, the more resolution it has. then things like rfi and emi in big cities is obvious and detrimental to the overall sound.
    when you play any woofer or midwoofer below its fs, you do so with increased im distortion in the usable bandwidth. this makes the mids sound fuzzy and destroys the contrast. and when you play a woofer below its fs, the excursion takes the woofer out of linear drive in the magnet and the distortion goes way up and the maximum output level is greatly reduced. hook a voltmeter/impedance to a woofer and push the cone in. now it is taken out of linear drive and the impedance skyrockets. think what this is doing to the amp and what it causes. this causes 2nd and 3rd order harmonic distortion and the usual chugging or booming of typical speakers. all speakers would benefit by bandpass filtration...period!
    anyone who does not see this is stuck in the forest and cannot see the trees. one listen and you hear that so much is improved in the sound that you cannot live without it.
    there this one made it.
    best,
    b
  4. #4
    Dilla
    Guest
    Et nytt spørsmål til en gammel tråd:
    Hva er output fra strømforsyningen til BAM? Tenker på likespenning (VDC) og strøm (A), evt. effekt (W) om det er oppgitt.
    Noen som kan ta en titt på strømforsyningen sin og se etter om verdiene jeg søker står skrevet der?
    Jeg håper å finne en passende forsyning i lista her: http://www.mascot.no/?CatID=1185
    Vil være veldig takknemlig for svar.
    May 2012
    Asker
    Tagget i
    0 Innlegg
    Det har vel blitt gjort forbedringer på de strømforsyningene Bobby leverer med de nye modellene så vidt jeg vet. Er ikke det enkleste å bestille en slik fra Merlin?
    Tror du at en annen strømforsyning skal gi bedre lyd?
    JP
  6. #6
    Dilla
    Guest
    Har et par merlinhøyttalere med Battery BAM på innkommende der medfølgende powersupply er tilpasset 115V / 60Hz, derfor mitt spørsmål.
    Prøvde meg på å bestille fra produsent men mr Bobby P insisterte på at jeg måtte sende over BAM'en slik at han kunne utføre jobben da det var veldig komplisert. Det gidder jeg ikke, dette er standardvare som kan kjøpes for en hundrings eller to. To ledninger greier jeg fint å lodde fast i et print selv....
    TK
  7. #7
    May 2012
    Asker
    Tagget i
    0 Innlegg
    Skjønner. Jeg har en helt ny strømforsyning fra Merlin. 100-240v 50/60 hz A 0,7 output 48 volt 0,52 A 25 watt max.
    China made av typen Mean Well. Sikkert billig.
    Det Bobby gjerne foreslår er oppgraderinger av Bam og høyttaler og der har det skjedd mye de siste årene. Duelund, nye Caps, lodding, strømforsyning, kabinett, Cardas Clear intern kabling etc.
  8. #8
    Dilla
    Guest
    Mange takk skal du ha JP!
    Ser den slik ut den du har: https://www.elfaelektronikk.no/elfa3...1-96&toc=19681
    TK
    Navn:      mean-well-gs25a48-p1j.jpg
Visninger: 163
Størrelse: 101.8 Kb
    Siste redigert av Dilla; 07.03.2014 kl. 11:13. Årsak: bilde inkludert
  9. #9
    May 2012
    Asker
    Tagget i
    0 Innlegg
    Helt korrekt .
    Du har PM.
    JP
  10. #10
    Dilla
    Guest
    Glimrende, takk for hjelpen JP!
    Da kan denne tråden få synke ned i sin dype søvn igjen.
    Forhåpentligvis kan den siste infoen komme til nytte for noen andre også en gang i framtiden...
    mvh TK
  11. #11
    Jun 2003
    Skjetten
    Tagget i
    0 Innlegg
    Torget
    Kutt ut hele bammen. Bruk aktiv deling og sett inn 2 subber. Da får du full kontroll over bassen. Du kan da dele hvor det er mest hensiktsmessig i rommet ditt. Bassen i VMS er monoton med bam.
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
