Bladelius Oden (The Beast) er på vei inn.
Neste uke så ankommer Bladelius hittil største Integrerte forsterker Oden med Vallhalla utgangstrinn og Phono modul i sort finish.
Oden ble lansert i 2020 i to utgaver. Med bipolare eller Mosfet utgangstransistorer avhengig hva kunden ønsker. I 2021 så ble det lansert en utgave med andre utgangsmoduler (Vallhalla) som har bedre oppløsning mm. Odin yter 2x400W i 8 Ohm (uavhengige målinger 2x500W i 8 Ohm) og 2x800W i 4 Ohm og er stabil ned til 1 Ohms last hvor den yter over 2Kw. Som de fleste modellene til bladelius. Så er også Oden fullbalansert ifra inn til utgang (les beskrivelsen under)
Vi vil fremover selge Bladelius med direkte ifra produsent til sluttbruker priser. Priser finner dere her: http://norskaudioteknikk.no/project/bladelius-oden/
Utdrag ifra test High Fidelity:
"ODEN is one of three integrated amplifiers, next to Vitus Audio SIA-30 and Accuphase E-800 http://highfidelity.pl/@main-3670&lang= < / a>, which can be the basis of even a very expensive system. This does not mean that they are equal in every respect, because their prices are well calculated and correspond to what we get, but only that it is one of the proposals that may be the THE ONE.
Bladelius successfully replaces separate amplifiers, even more expensive ones. What's more, it has a great phono preamplifier already on board. It is not as versatile as external devices of this type, but its sound simply captivates with its colors, saturation and melody. It features a solid mechanical design, very good electronic components - these are also strong advantages of the amplifier. It’s a classic, but in a great and modern edition. And there is a bonus: it is an attractively priced amplifier. We would have to pay much more for this type of product from one of the major manufacturers."
Teknisk beskrivelse:
In Northern mythology Oden was the king of gods, the wisest, most powerful and creator of mankind by giving the gift of life to Ask and Embla. This Swedish made integrated amplifier represents all the experiences that we at Bladelius have accumulated throughout the years, with it´s twin gigantic toridol power transformers, it generates a whopping 400 Watts at 8 ohm. Although very powerful, it´s main objective is musicality and not power. And it truly lives up to the name of Oden by providing flawless speaker-driving capacity, symbolizing the uncompromised design and quality that only Bladelius can provide.
The path of positive and negative current flowing through the voice coil must be completely symmetrical to accurately drive the loudspeaker diaphragm. So naturally the symmetry was of a particular concern for this product, pursuing complete balance in amplifier circuit, power source circuit and structural aspects.
With the design philosophy simpler is better we reduced the voltage amplifier stage to one, for the shortest signal path possible. Oden provides, a truly balanced design without ground as reference for highest possible performance, a high-performance dc servo that works outside the signal path, the input stage is a pair of current loaded hand matched Jfet in a foldback cascade arrangement which gives a very linear performance regardless of the music level. This combined with current feedback gives you an extremely fast and stable performance.
To increase the purity of the power supply and achieve a more responsive and consistent audio reproduction, a large capacitor bank of over 200 000uF effortlessly help delivering dynamic and smooth sound with excellent transient response for which Oden was designed. True to Bladelius long-held design philosophy of “Simple is best”, the Oden reduce the number of components needed for the first stage down to a minimum so as to allow music signals to be amplified in their purest form and go through the circuit without losing even the subtlest information.
A pair of Jfet devices carefully hand selected by our specialist in the production line was incorporated into the amplifier’s input circuit, which improves the operational stability of amplification. As a result, every production unit of the Oden has identical performance characteristics, and the Oden delivers identical performance between the left and right channels. In addition, the new DC servo circuit stabilizes amplification, is resistant to changes in the operating temperature and magnitude of input signals and eliminates fluctuations in sound intensity. All this attention to detail ensures that these amplifiers produce a powerful, condensed sound with deep, rich bass, allowing the listener to have a truly immersive stereophonic experience.
The chassis is made out of milled non-magnetic materials for the lowest possible electromagnetic field for improved sound quality. Odens clean design represent both Bladelius philosophy of “simple is best” and the classic Scandinavian design.
Spec:
Power Output
800 W @ 4 Ohm
400 W @ 8 Ohm
Rated Distortion
Less than 0.01 %
Signal-To-Noise Ratio
More than 125 dB
Frequency Response
1 Hz to 100 kHz, +0/-3 dB
Input Terminal
2 Pair of Balanced
5 Pair of Unbalanced
1 Pair of Loop Out
1 Pair of Pre Out
1 Pair Phono MM/MC* optional
1 slot Module option
Dimensions
450mm (W) x 210 mm (H) x 550 mm (D)
Weight 60Kg. Shipping weight 75Kg.
Norsk AudioTeknikk AS
Ullevålsveien 13
0165 Oslo
Tlf: 22200095
Web: www.norskaudioteknikk.no
Mail: morten@norskaudioteknikk.no
Facebook: https://www.facebook.com/NorskAudioTeknikk/
Facebook PMC: https://www.facebook.com/groups/384770248991790/
Auditor
Finnes det en vakrere intern layout? Jeg tviler….😊❤ Dette oser raffinert monster. Bygd som nec-Plus-Ultra skal være. Godt å se hele fire trafoer👍 Det vitner om logisk bruk av strøm. Og en konstruktør som skjønner tegninga. Som om vi ikke allerede visste. Spørs om gulvet mitt tåler tidenes tøffeste sekstikilos integrerte..😈 Livstidsvalg, if there ever was one..Vel..jeg har etpar andre her.
Reaksjoner: nat
MusicBear
Man skal ikke inneha mange minutters lytteerfaring med Bladelius, opp gjennom. Lest mye om denne nye integrerte svensken. Eller for den saks skyld la øynene måtte hvile særlig mange sekunder på det bilder bevitner om. Før man erklærer at Oden målt opp mot å mye annet - er billig! Mener det!
Well, venner av merket vil hevde alle Bladelius gir mye for pengene, men denne ville jeg gjettet koste mer.
Reaksjoner: nat
M.B.S
Spennende sak. Håper det kommer noen tester av den snart.
Reaksjoner: nat
Final
Flott sak dette. Svært godt S/N og en overflod av krefter gjør den anvendelig for et stort spekter av høyttalere.
Reaksjoner: nat
nat
Oden er ikke bare full av krefter. Er også meget «sofistikert» og som alltid med Bladelius forsterkere meget presis. kun topp komponenter og strømforsyningen er det heller ikke spart på noe. To custom 1.600Va Noratel trafoer til effektdelen og to mindre til pre og kontroller delen.
Selvfølgelig fullbalansert helt frem til høyttalerene.
Oden har vi priset meget gunstig (et raskt Google søk så ser du hva den koster andre steder) fastpris. Tatt pris, ytelse og Made in Sweden så tror jeg ikke det finnes noen konkurrenter der ute?
Auditor
NAT: Så hvis jeg regner strømkapasitet på 4kVA totalt..fordelt på 3200 i effektdelen, samt 2x400VA til småsignalene..det holder til de oppgitte tall, det..❤ Da tror jeg du har rett om manglende konkurranse fra andre, gitt! Får man denne i hus, betyr strømpris null og nix. De mindre trafoene..kan det være tilsvarende den Embla har en enkelt av? Sofistikasjon tipper jeg det er mer enn mest av her. Mike har en tendens til å bygge sleepers. Og da gjemmer han gjerne en svær hestesko i silkehanskene. Det er nettopp den kombinasjonen av utrolig raffinement og usjenert brutalitet som gjør at jeg og mine elsker disse forsterkerne😊 Rolls Royce oppgir heller ikke hestekrefter, de sier bare det er adekvat..Det er det her og! Adekvat til å være uanstrengt. Uansett last. Og Mike unnskylder seg ikke for det heller..😈 Hvordan kan man da la være?? Frua forbereder Asks inntog i stua, forresten. Så regn med litt å gjøre om noen måneder..
MusicBear
En ting er at de store modellene fra denne svensken ser ut til å være i klasse med noe av det beste som kan kjøpes. Men de mindre modellene - om også innhugget i lommeboka skal få lov til å påvirke - er vel noe kun selve eierne av disse kan fortelle om. Bladelius hadde sagt under en messe i Sverige at den virkelige konkurransen lå i å få topplyd ut av rimeligere modeller, sa også under demoen at det ville vært enda mer kult å være produsent dersom folk lyttet før de leste produsenters «PR-data» om hva man lyttet til.
nat
nat sine annonser
Enda en glimrende test av Bladelius Ask integrert med DAC/Streamer. Nå i Norske Stereo+
  • 1
Etter en liten stund på markedet. Så har Bladelius Ask gjort seg sterkt bemerket hvor bra man kan få en alt-i-et forsteker med samme egenskapene som separate løsninger (bokser) Les hele testen på...
Lørdagen 6 april stenger vi kl 13.30 grunnet kundebesøk.
  • 8
Vi må dessverre stenge kl 13.30 i morgen grunnet kundebesøk. Skal kjøre halvveis opp til Trondheim og tilbake igjen i morgen. Er tilgjengelig på telefon. . Norsk AudioTeknikk AS Sofiemyrveien...
Da var det siste farvel til Ullevålsveien i dag.
  • 30
Sofaen er på plass i demorom Nr.1. Fortsatt mye jobb som gjenstår. Men dette blir bra🍾
Norsk Audio Teknikk flytter!
  • 117
Sofiemyr blir Mekka for troende audiofile:cool: Trommevirvel! Etter nesten tre tiår med å utvikle en mild avhengighet til bylufta i Oslo, har vi bestemt oss for å pakke sammen sirkuset og...
Norsk Audio Teknikk på Oslo HiFi Show.
I forbindelse med våres 30-års jubileum i år og at vi flytter butikken til større og finere lokaler på Sofiemyrveien 12. 1412 Sofiemyr rett over påsken. Så vil vi under messen kjøre noe virkelig...
PMC lanserte en nyhet under helgens Bristol Hi-Fi Show. Twenty5-active.
  • 15
Det var storlansering av PMC sin Twenty5- aktive modul under helgens Bristol Hi-Fi Show. Denne modulen kan etter monteres på alle 2-veis Twenty5 modeller. Både den gamle utgaven og på nåværende...
