Side 130 av 131 FørsteFørste ... 3080120128129130131 SisteSiste
Resultater 2,581 til 2,600 av 2620
Abonnér på denne tråden
  1. #2581
    Hifi Freak Eirik84's Avatar
    Jun 2011
    Tagget i
    0 Innlegg
    Sitat Sitat fra Hedde Se Innlegg
    Kan dette faktisk skje, eller?
    " ..the room gets bigger, more atmospheric, you start to see images of musicians"
    "...which brings the musicians closer to you: drier but more intimate, more apparent detail"
    Nice, da trengs ingen målinger heller
    Bowers&Wilkins | Denon | Hegel | Van den Hul | Furutech | Neotech
  2. #2582
    Moderator bambadoo's Avatar
    Oct 2002
    Tagget i
    2 Innlegg
    Litt mer om UEF.
    In fact, UEF Tech is so powerful even an electrical chain several miles long is fundimentally improved with nothing more than a single fuse engineered with our patented UEF Technology.
    Siste redigert av bambadoo; 11.10.2019 kl. 10:21.
    I don't believe in system matching. If something is good, it's good. If it only sounds good under certain conditions, it is not good - it is incorrect. - Charles Hansen
  3. #2583
    Hifi Freak michell's Avatar
    Sep 2005
    Tagget i
    0 Innlegg
    Frequently asked questions.
    Q: Are fuses directional?
    A: Yes, fuses are directional. Electricity should flow from the left to the right when you view the fuse. If you do not know the direction of flow you should listen to the fuse inserted in both directions. One direction will sound more detailed. This is the correct way.
    Q: Do fuses have a burn in period?
    A: Yes, most products have a settling in period. The first 200-300 hours of use are the most crucial.
    Og så bare USD 159,95 pr. stk. da
    Quad 33+FM3 /Elekit TU-8600VK / Reference Hydraulic Transcription Turntable by J.A. Michell Eng. Ltd. / SME Series IIIS / Ortofon SME 30 / Lowther EX3 / Hedlund / Ferrograph S 7 / Matrix Mini-i Pro (2015) / Miglia HarmonyAudio / Mac Mini / Rythmikaudio DS12TC-A370 Servosub
  4. #2584
    Hifi Freak WayAhead's Avatar
    Dec 2017
    Tagget i
    0 Innlegg
    Bruker 2 kalibrerte Clearup Fuses i parallell i hver fase montert hver sin vei slik at de er dobbeltvirkende. Kun kr. 5000 pr stk. Only 18k 4 4.
    Edit: $
    FULL SCI-FI
    [MAC ]-->>-------------------------------------------------[ NO, THERE AIN`T NO SHIT HERE ] ------------------------------------------>>--[ POWER AMP]
    "We are the only Hi-Fi, everything Hi-Fi maker, and the gigantic new SP-X speaker system backs up that proud claim with real earthshaking authority."
  5. #2585
    Dec 2017
    Tagget i
    0 Innlegg
    Hereka, endelig den hele og fulle sannhet om kanellyd, forsterkerly lyd ltd ig annrn magi
    FULL SCI-FI
  6. #2586
    Bransjeaktør Snickers-is's Avatar
    Feb 2004
    Tagget i
    10 Innlegg
    Nå ble jeg litt usikker på om du helt forstod hva det der handlet om?
    Jeg driver Midgard Audio
    If you do not se the problem, you will not look for a solution.
  7. #2587
    Hifi Freak
    Jun 2011
    Tagget i
    0 Innlegg
    Sitat Sitat fra michell Se Innlegg
    Må være laget for de med mye DC på strømnettet disse sikringene. Kanskje de har innebygget diodefunksjon?
  8. #2588
    Hifi Freak DagT's Avatar
    May 2013
    Tagget i
    0 Innlegg
    Sitat Sitat fra Snickers-is Se Innlegg
    Samme her. Det er i grunnen ikke noe nytt at ultralyd kan brukes til å riste i stykker ting (og celler) hvis man finner resonansfrekvensen.
    Electromagnetic and acoustic imagery
  9. #2589
    Æresmedlem Pink_Panther's Avatar
    Mar 2006
    Tagget i
    0 Innlegg
    Sitat Sitat fra DagT Se Innlegg
    Litt mumbo-jumboprat, et par doser cryo og quantum toppet med referanse til N. Tesla så er det en verdensnyhet. Og folk biter på...
    Er det fremskritt om en kannibal bruker kniv og gaffel?
    Stanislaw Jerzy Lec
  10. #2590
    Hifi Freak Aurora's Avatar
    Jun 2004
    Ytterst i havgapet...
    Tagget i
    2 Innlegg
    - og gjerne en påstått referanse til NASA....
    Mens Løgnen løp fra Bagdad til Konstantinopel, lette Sannheten fortsatt etter sine sandaler
  11. #2591
    Mar 2006
    Tagget i
    0 Innlegg
    ^Forskere. Vi glemte forskere.
    Stanislaw Jerzy Lec
  12. #2592
    Hifi-entusiast 4-string's Avatar
    Jan 2011
    Tagget i
    0 Innlegg
    Det har sikkert blitt påpekt flere ganger allerede, men svaret er nei.
    Det finnes ikke tweaks som er så drøye at de blir gjennomskuet av alle, det vil alltid finnes noen som hører forskjell og forsvarer det med nebb og klør.
    En kompis av meg hadde en periode hvor han brettet hjørnet på den ene gardina i lytterommet (noen som husker den? ) og var strålende fornøyd med det lysmessige løftet.
    Dette var etter at han brukte tomme doruller som kabelløftere, noe som forøvrig også løftet lyden veldig visstnok.
    LM Audio 805ia
    Audio Physic Virgo II
    Audiolab 6000CDT
    RME ADI-2 DAC
  13. #2593
    Æresmedlem motoren's Avatar
    Jan 2007
    Flekkefjord
    Tagget i
    14 Innlegg
    Torget
    Sitat Sitat fra 4-string Se Innlegg
    JMLab Electra 920.1<br />Audio Research LS 3 pre<br />Monarchy Audio NM 24 tube DAC<br />Denon DCD 1650AR<br />biamper med Pass F5 Power amp/Hypex UCD 180<br //Clearaudio Concept/Mcru power supply/LM Audio LP33 Tube riaa/ Audio Technica 33EV <br /Tributaries serie 8 speaker cables>/Audioquest K2 Ht cables<br />In.Akustik Reference digital<br />In-Akustik Reference ic<br />Marantz DV 8003 Multispiller/ Nos Mullard
  14. #2594
    Æresmedlem Asbjørn's Avatar
    Mar 2006
    Tagget i
    24 Innlegg
    Sitat Sitat fra Pink_Panther Se Innlegg
    Ja. En eks-rakettforsker fra NASA tilfører stor troverdighet, spesielt hvis vedkommende ikke vil si et skvatt om hvordan dingsen fungerer, bare at det er hemmelig. (Looking at you, Jack Bybee.) Noen har tydeligvis stor tillit til denslags hemmelighetsfull faglig autoritet.
    Det er bare litt snodig at jeg, som faktisk har en lang liste av helt ekte slike kvalifikasjoner, stadig blir bedt om å ikke forsøple kabeltråder med innvendinger. Nei, her vil man ha illusjonene for seg selv, uberørt av fakta om hvordan fysikken i dette universet egentlig virker.
    Jeg antar at rakettforskere fra NASA bare er troverdige hvis de bekrefter at tweakeriet fungerer, fysikk og univers be damned. I det øyeblikket de antyder at lytteinntrykkene kanskje snarere har noe med psykologi å gjøre er de ikke troverdige lenger. Rart, det der.
  15. #2595
    Hifi-entusiast
    Apr 2019
    Tagget i
    0 Innlegg
    Tomme tørkeruller gir ENDA bredere lydbilde, naturligvis. :-D
  16. #2596
    Hifi Freak el_mariachi's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    Sitat Sitat fra Eirik84 Se Innlegg
    Han er i alle fall raus nok til å gi 30 dagers returrett da
    Men det er vel minimum 800 timers innspillingstid.
    Former hellraiser & messageboard pyromaniac.............................
  17. #2597
    Overivrig entusiast Figge's Avatar
    Nov 2004
    Stockholm
    Tagget i
    0 Innlegg
    Samma som med vaskepulver nu 50% effektivare. Hur dåligt var det innan då?
    Meridian G08, NAS Ace Spacedeck med Ace arm och Roksan Shiraz modifierad av MrT, Trilogy 907, Kimber KCTG, Music First Baby Reference, Pure Audio Reference 2, Vertere Pulse R Line Out XLR, Vertere Pulse R Pre Out Rca, Chord Sarum T högtalarkablar och Sarum T jumpers.Verity Audio Rienzi. Nordost Vishnu. GigaWatt PF 1e och LC 2 MK III. Musical Fidelity X-Can och Hifiman HE-400i. Luxman T-12.
  18. #2598
    Hifi Freak vidarje's Avatar
    Oct 2009
    Rasta
    Tagget i
    0 Innlegg
    Sitat Sitat fra Figge Se Innlegg
    Kom til å tenke på Phillips sine reklame videoer for en del år siden hvor de brukte Beatles sin Getting Better og stoppet akkurat før de synger "it can't get no worse"
    Squeezebox Touch, Dynaudio AIR20, Dayton 12" med miniDSP PWR-ICE 125 og Audiolense XO
    http://www.hifisentralen.no/forumet/...ktsrommet.html
  19. #2599
    Jan 2011
    Tagget i
    0 Innlegg
    Sitat Sitat fra AOC Se Innlegg
    Naturligvis!
    LM Audio 805ia
    Audiolab 6000CDT
    RME ADI-2 DAC
  20. #2600
    Mar 2006
    Tagget i
    0 Innlegg
    Dumme meg. Jeg hadde hørt at Torky tørkeruller var meget gode og regnet da med at kjernen fra disse ville være et suverent valg. Kjøpte 20 ruller.....
    Stanislaw Jerzy Lec
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
