MattiasBGD
- Ble medlem
- 06.06.2014
- Innlegg
- 21
- Antall liker
- 41
Greetings from Sweden,
After being very satisfied with the SDX12 subs I decided to also try a speaker kit from CSS.
I love ribbons since before when I have owned a bunch of different XTZ speakers so this kit suited my taste and wallet.
First of when receiving the kit I liked how well packaged it was and shipping was less than 2 weeks from ordering until it reached my door in Sweden. Just as good as the SDX12 drivers.
Unpacking revealed a heavy ribbon tweeter (much heavier than the one I replaced in my XTZ speaker which had failed). The ribbon had protective film attached which is very good since ribbons can get damaged easily you should never vaccume clean or blow into them I was told.
The 7" woofers looks really nice to with a sturdy cast frame and paper composite cone which should sound very natural in the midrange. The surrounding looks like it should have good Xmax.
I should have started building this kit long ago but many things has happened one of them was daughter number two added to the family. So mean time some things happened the kit was redesigned with a new Team revision crossover and the MLTL design was added and now I have crossover design from both the early RAW crossover and new Team edition and I will try them both and listen which one I like the most.
//Mattias Vendel with help from Albin Lyckestam”
