El-retur
noen som kan anbefale delefrekvens mellom fulltone og diskant,hvor bør fultonen kuttes?
er denne https://www.intertechnik.de/Shop/Loudspeakers/Gradient-Axis/_AX-08_1768,en,6800,96790
[h=3]Features[/h]
[h=3]Features[/h]
Type | Fullrange |
inch | 8 |
13 | 8 |
15 | 92,00 |
VC (d) | 25 |
Re (Ohm) | 6,30 |
EXW (ex works) | 5,67 |
fs | 41,63 |
22 | 11,6 |
24 | 1,52 |
21 | 211 |
VAS | 91,70 |
QMS | 5,69 |
QES | ,54 |
QTS | ,49 |
Membran material | Kevlar-Papier |
surround Material | Tissue |
basket material | Aluminium |
magnet material | Ferrite |
ouside diameter (mm) | 223,00 |
build in hole diameter (mm) | 186,00 |
build in depth (mm) | 90,00 |
Brand/manufacture her står det litt mer om elementet Gradient Axis 8 in GHP simulieren - DIY-HIFI-Forum | Gradient |
