[h=4]PathAudio[/h]Fresh in from Poland are the supreme PathAudio resistors. Rated at 10W with 1% tolerance, features in copper case, earth lead to protect against RF and the resistive element is embedded in anti-vibration compound.
[h=1]Christmas is coming!!![/h]
With the holidays just around the corner we would like to take this opportunity to thank you all for you support over the last 12 months and wish you a very Merry Christmas and a Happy New Year.
We have been very busy extending our range of audio grade parts for your enjoyment. We are excited about new lines arriving in January such as Musicap capacitors all the way from the USA and plans to further our nuts, bolts and fixings range.
Look out for our Boxing day newsletter that will include a 10% voucher code for you to use over the Christmas / New Year period.
Best wishes from all the HiFi Collective team.
[h=4]TKD Metals[/h]From TKD, well known for their superb potentiometer, we have the full E12 range of their CM2 2 watt metal film resistors.
[h=4]Khozmo Pre[/h]To accommodate the popular Khozmo stepped attenuators we now have their finished pre-amps.
[h=4]TC 4 terminal[/h]New from ClarityCap are these 4 terminal power supply compact polypropylene capacitors.
[h=4]Cardas IEC plug[/h]Excellent 3455R IEC plug - Copper blades and clips, plated with Rhodium over silver.
[h=4]Silver RCA[/h]Low cost RCA sockets, brass with silver plate.
[h=4]Khozmo Remote[/h]Don`t get up! Remote control stepped pre-amp, excellent value.
[h=4]Polystyrene +[/h]We have added lots of new values to this classic signal capacitor.
[h=4]Schuko plug[/h]Cardas put their hands to the Schuko plug with amazing results.
[h=4]New values of AG[/h]Mundorf have launched a new value of their famous AGs, the 10000uF 80V version.
[h=4]Glasshouse Pre[/h]New from Glasshouse is our budget passive pre-amplifier kit.
