HELP Power amp died
hpm-1100
Askøy
My aragon 8008st just died...
I had a rca cable badly connected to the preamp.. i heard a click and then no more sound!
The amp still has the power light on but there is no sound, absolute silence.
This amp when i turn it on allways makes a little click a couple of seconds after, this is the same click i heard when the sound dissapear now...
When i turn it on now, there is light but no click or any sound...
i know the amp has good protection systems so i wonder , could this be a easy thing to fix?
thank you
EHED
Nordby
Have you tried unplugging the power cable and wait for 15-20 minutes?
It could be a protection curcuit that will latch off when all power has been drained.
Or, hopefully, the amp will have some fuses inside that has blown?
The best of luck, and hope it can be fixed!
hpm-1100
Askøy
thanks, trying that now...
the fuses in the back with the power plug are fine.
any other fuses i should look for?
