Superbillig GRS (Pioneer B20 erstatnings) 8" fulltone
Hornlyd
Musikkglad
Fikk et par slike i posten. Koster kun 13,25 USD pr stk!
Uploaded with ImageShack.us
GRS 8FR-8 Full-Range 8" Speaker Pioneer Type B20FU20-51FW
The GRS 8FR-8 full-range 8" speaker features a paper cone with poly foam surround. A whizzer cone extends high frequency response and dispersion. Engineered to withstand rigorous commercial use, this driver will also deliver great results when used in point-source hi-fi applications. Affordable pricing makes it perfect for DIY applications. Ideal replacement for the Pioneer B20FU20-51FW (also known in DIY communities as the BOFU)
Specifications: • Power handling: 60 watts RMS/85 watts max • VCdia: 1-1/2" • Le: 1.28 mH • Impedance: 8 ohms • Re: 7.02 ohms • Frequency response: 39-16,000 Hz • Fs: 39 Hz • SPL: 91 dB 1W/1m • Vas: 2.26 cu. ft. • Qms: 2.94 • Qes: 0.46 • Qts: 0.40 • Xmax: 3 mm • Dimensions: Overall diameter: 8", Outside diameter: 7-1/4", Depth: 3-7/8".
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-430
Noen forslag til kabinett. Skal brukes til fjortis-høyttaler :)
Hornlyd
Musikkglad
Kjøpte også denne tweetern (USD 3,75 stk) som jeg tenkte å dele høyt (8-12K) med en enkel kondensator.
Nuance TW5-073LR 1/2" Mylar Tweeter
Clean and efficient Mylar diaphragm tweeter. Flush mounts into 7/16" depth recess. Buyout, limited quantities. Specifications: *Power handling: 30 watts RMS/60 watts max *VCdia: 1/2" *Impedance: 8 ohms *Re: 6.4 ohms *Frequency response: 3,000-20,000 Hz *Fs: 3,000 Hz *SPL: 90 dB 1W/1m *Dimensions: A: 2-7/8", B: 2-1/8", C: 1-1/8".
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=279-060
Eradnort
Hva slags kabinett skal de få?
Sikle...
Nei.. jeg kan ikke kjøpe flere høytalere nå...
Sonny
Kvartbølge selvfølgelig. Fjortisen må ha noe som skiller seg fra ruklet.
sonny
Hornlyd
Musikkglad
Kvartbølge er en god idee. Har bygget en håndfull av dem siste året. Jeg behersker imidlertid ikke M J Kings Mathcad.
Her er et innspil på PE om speccene:
This is a pretty good replacement for the famous Pioneer "BOFU" speaker, although the specs are waaaay off from reality. Below are my measurements from WT3:
* This data was exported from the Dayton Audio WT3 Woofer Tester
* Manufacturer: GRS
* Model: 8FR-8
* Piston Diameter = 165.1 mm
* f(s)= 63.25 Hz
* R(e)= 7.43 Ohms
* Z(max)= 49.80 Ohms
* Q(ms)= 5.702
* Q(es)= 1.000
* Q(ts)= 0.851
* V(as)= 32.170 liters (1.136 cubic feet)
* L(e)= 1.14 mH
* n(0)= 0.78 %
* SPL= 91.00 1W/1m
* M(ms)= 12.67 grams
* C(ms)= 0.50 mm/N
* BL= 6.12
Nikko03
Så ikke ille ut den kassa der hel. Men hvis det elementet du har er drop in replacment for gamle pioneer B20 finns det
endel prosjekter der ute. Sniker du litt rundt på diy audio dukker det opp noen prosjekter. Tror det er ett frugel horn som er beregnet for B20 bla :)
N
nysjerrigper
kjøpte du bare de + diskanter?
jeg får beskjed under checkout at minimum ordre er $50, da kommer de ikke under 200kr grensen og prisen blir en helt annen.. bare fortollingsgebyr er omtrent det samme som 2 slike woofere
Hornlyd
Musikkglad
Jeg kjøpte 4 ruller finer, fresejigger, en større mengde kabel og terminalkontakter, Aurum Cantus bånddiskanter som skal til et fremtidig Fostex FE208eZ prosjekt. Da var det plass til å slenge på litt morosaker også ;D
Hornlyd
Musikkglad
Skal prøve å huske å legge ut en melding her på DIY neste gang jeg skal handle på PE om noen vil slenge seg på ;)
Nikko03
Denne har blitt brukt med pioneer b20 elementet
Curvey Chang
Hornlyd
Musikkglad
Den er diger. Hvor høy og brei er den?
the_eye
ser ikke noe feil jeg? ::)
har selv motatt elementer i 2k klassen full av kraftige riper og annet på rammen som åpenbart ikke har skyldes frakt.. vistnok ikke så uvanlig når det kommer til hurtigproduksjonen av noen PA elementer....hmm
