Skal snart dra frem mine Tang Band W8-1808 fulltoner. Har også Tang Bands bånddiskant som skal ta seg av toppen.
Så har jeg bestilt et par Eminence Alpha15" basser med høy Q. Bassene skal drives at et par Hypex subforsterkere.
Fotoet viser Zilla Audio sin H-Frame. En slik skal jeg lage.
MJK sin oppskrift og måling: http://www.quarter-wave.com/OBs/U_and_H_Frames.pdf
+ En kommentar fra Zilla audio på DIYAUDIO.COM:
An observation i can offer is that crossing the H-frames lower sounds better. I use a typical sub amp (anything 100+ watts should be great) with variable crossover and volume. I did not want to figure the passive crossover and the sub amp does the trick for me. You will get an immense sound with these H-frames that has to be heard/felt to be appreciated. There may be better bass systems available but these really satisfy me. The 1808 will sound best with minimal interference from the H-frames... i really think the 1808 is a great driver regardless of how others feel about it. It's an ambitious attempt at a great sounding full range driver. It's a total pleasure to listen to.
62.5 KB Visninger: 1.343
