Audiocom upgrade på en Transporter nettverkspiller, noe erfaringer?
toca
Er det noen av dere som kjenner til Audiocom International og hvilket resultat modifireringen de utfører gjør lyden med Logitech Transporter nettverkspiller?
Selskapert utfører modifisering av digitalveien ut av Transporteren,se mail fra Audiocom som beskriver hva man kan gjøre:
Hi Tom
Thank you for your enquiry.
With the Squeezebox Transporter we have always focused on upgrades to use it
as a digital source via the S/PDIF output.
We have two levels of modification listed at the website, but we also offer
a 'Signature' upgrade which uses the Bybee Super Effect AC Bullets (SEIB).
The SEIB singled out make the biggest improvement to sound, but they are
also the most expensive of components costing GBP 950.00 per pair inclusive.
The Signature upgrade also includes resonance control treatments from
SteinMusic.
The Signature modified Transporter can go head-to-head with high-end optical
CD transports, we have compared it to Esoteric.
The price of the Signature upgrade inclusive of tax is GBP 1959.53, and is a
serious investment with great sonic rewards
Transporter Digital Only Level-2 Upgrade
? Cryogenically treated IEC inlet socket.
? Bybee Large Quantum purifiers for AC input.
? Low noise, wide band shunt regulator for 5V supply.
? Low noise, wide band shunt regulator for 3.3V supply.
? OSCON SVP regulation bypass capacitors.
? Panasonic FK digital PSU & decoupling capacitors.
? Superclock 4 ultra-low jitter master clock.
? Superclock 4 clock PSU.
? WBT NextGen cu RCA phono for digital out.
? 1x Bybee Slipstream purifier for digital out.
? 6N OCC wire for digital out.
http://www.audiocominternational.com/squeezebox-transporter-p-180.html
http://www.audiocominternational.com/squeezebox-transporter-mods-p-55.html
Noen som har gjort dette eller har hørt om selskapet tidligere?
Kjenner til Modwright modifiseringen, men denne var ukjent for meg.
