Side 1 av 4 123 ... SisteSiste
Resultater 1 til 20 av 73
Abonnér på denne tråden
  1. #1
    Apr 2005
    Tagget i
    6 Innlegg
    DAC kort fra ebay og bygging av kabinett
    Jeg har tatt sjansen og kjøpt et ferdig montert DAC kort på eaby.
    Det kom på ca kr 900,-
    Har tenkt å bygge et kabinett som matcher MAE SET1 og montere kildevelger og en passiv attenuator. Helt enkelt :-)
    Så får vi se om det er plug&play eller plug&pray
    http://cgi.ebay.com/ws/eBayISAPI.dll...K%3AMEWNX%3AIT
    Her er litt speccer i tilfelle web linken skulle forsvinne:
    Upsampling 24bit/192 DAC KIT,TOROID TRAN,with USB input, HI END COMPONENTS CS4398, CS8416
    Up to this auction is a Upsampling 24bit/192 DAC KIT,TOROID TRAN,with USB input
    It has been fully tested and you only need to connect few wire and will enjoy a high End 24/192 DAC.
    It use famous Crystal chips : CS8416 as digital receiver and Burr Brown PCM1793 as DAC which perform 24/192 digital to analog translation .
    This new version can provide interchangeablity to other Hi End dac chips such as PCM1793, CS43122 , CS4397.....etc and other Hi End digital receiver other than CS8416.
    Upsampling chip CS8421 .
    Ideal for use with DVD, DVD Audio, CD, D-VHS, game console, and professional audio applications.
    Comes with a a IEC AC socket .
    Toroidal power transformer, worldwide AC voltage , 110V and 220V, complete separate digital and analog AC supply.
    5 separated individual precision voltage regulators to supply each individual need, good quality ELNA and WIMA capacitors from Germany to provide power source to the DAC. It can improve 3-D , stage , punch , and upper , lower frequency response
    United DAC PCB , high precision 1% DALE metal film resistors from USA ,
    CS8416 as digital receiver and as CS4398 which perform 24/192 digital to analog translation.
    Output stage use a DUAL-FET op-amp NE5532 for amplification . User can simply plug and upgrade to Hi End op-amp according to their musical preference but be careful with the direction of the op-amp location
    gold plated RCA sockets for analog ( right and left ) outputs and coaxial input.
    There is a jumper on the right corner of the DAC PCB for the selection of the input ( coaxial , optical). SA connected to DG is coaxial input and SA connected to 5V is the optical input.
    LED indicators on each individual power supply .
    PCB size: 132 x 175 x 50mm
    DC specification of the 24/192 DAC kit :
    INPUT DESCRIPTIONS
    DC voltage + 5V DC , +/-12V DC
    min.4.6V optimal 5V max.5.3V ; min.11.6V optimal 12V max.12.3V
    Temp. 20’C
    DC current normal 25ma max.35ma
    Temp. 20’C
    Electrical specification of the 24/192 DAC kit :
    FIGURE DESCRIPTIONS
    Input voltage Coaxial:
    min.0.3Vp-p normal 0.5Vp-p max.2Vp-p
    Signal/Noise Ratio normal 88dB max.90Db
    40kHz Lpf ON
    Separation Normal 90 dB
    1kHz 1Vp-p
    Dynamic range 96dB
    Analog output min.1Vp-p normal 1.5Vp-p max.2Vp-p
    Ro=600 ohm
  2. #2
    Apr 2005
    Tagget i
    6 Innlegg
    Det følger med skikkelig trafo
  3. #3
    Apr 2005
    Tagget i
    6 Innlegg
    Det lille kortet kan/skal?? stikkes ned på høykant men da må noen jumpere fjernes
  4. #4
    Hifi Freak Cobra2's Avatar
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Gratulerer med ny DAC, verd akkurat hva du betalte (- frakt)
    Har testet & moddet noen tilsvarende selv...
    Arne K
    Of all the things I've lost, I miss my mind the most.
    For sale:
    http://www.hifisentralen.no/forumet/...ser&userid=701
  5. #5
    Hifi Freak Nikko03's Avatar
    Nov 2008
    Tagget i
    0 Innlegg
    ligner veldig på den gigaworks dac'en jeg kjøpte i fjor
    Jeg er veldig fornøyd med min dac her har det iallefall vært plug&play
    Musikere pensjonerer seg ikke, de slutter når det ikke er mer musikk igjen i dem."Louis Armstrong "
  6. #6
    Hifi Freak
    Jan 2005
    Bæææærgen
    Tagget i
    2 Innlegg
    Likner på min gigaworks også, og de funker som bare juling.
    Kan være litt å hente på å oppgradere op-ampene her....
    Proffen
    1: Magnepan 1.7, Rythmik Audio F12SE, Coda CS, Musical Innovation MI11, No name Philips cdm12-basert cd-transport, Audio gd NFB 1.38, Denon dvd3910, Sense høyttalerkabler + DNM & Blue Jeans signalkabler, Sonos zp90, RN Duo
    2: Canton dm75, Sonos zp90, Essence hdacc, Philips bdp9500, Philips tv, div kabler
    3: Sony UBPX800, Canton dm75, Sony tv, div kabler
  7. #7
    Hifi Freak
    Jan 2005
    Bæææærgen
    Tagget i
    2 Innlegg
    PS: Kunne igrunnen vært interessant å høre HVOR bra folket mener disse dacene er, sammenliknet med dac`er en kan kjøpe ferdig sammenskrudd og med kjente merkenavn på...
    Noen som tar utfordringen?
    Proffen
  8. #8
    Hifi-entusiast ee's Avatar
    Nov 2004
    Tagget i
    0 Innlegg
    Album
    Spennende å følge med, jeg skal selv forsøke meg på en gigawork. vurderte du disse opp mot hverandre de ser jo veldig like ut?
    mvh ee
  9. #9
    Apr 2005
    Tagget i
    6 Innlegg
    Joa Gigaworks sin er besynderlig lik
    Fant en link om den så jeg kommer nok ikke til å stå fast. Nok av ressurspersoner i Norge på denne:
    http://avforum.no/forum/diy-do-yours...ikasjoner.html
  10. #10
    Apr 2005
    Tagget i
    6 Innlegg
    Her var jammen en link til: http://okasin.net/dac.htm
  11. #11
    Nov 2008
    Tagget i
    0 Innlegg
  12. #12
    Hifi-entusiast
    Aug 2008
    Tagget i
    0 Innlegg
    Jeg har en Gigawork DAC, men med DIR-9001 chip.
    Kjører nå med diskrete opamper fra Audio GD.
    Vesentlig løft å bytte ut NE5532 opampene med LM4562 eller diskrete opamper.
    Er godt fornøyd, og jeg synes Gigawork spiller veldig bra til prisen.
    Mixture
    En skal høre mye før øra detter av.
  13. #13
    Nov 2004
    Tagget i
    0 Innlegg
    Album
    Her er en med tube stage
    http://www.diyhifisupply.com/node/768
  14. #14
    Feb 2003
    Tagget i
    0 Innlegg
    Album
    Ja, en rør/analog-utgang som koster dobbelt så mye som selve dac-kortet...+ trafo...
    Arne K
    For sale:
  15. #15
    Apr 2007
    Tagget i
    0 Innlegg
    åssen har dere løst bytting mellom coax, optisk og usb på gigawork dac'en? Synes det er en dårlig løsning med den jumperen. Er ute etter et nytt kort, da jeg klarte knekke det andre ved å lodde på en bryter på pinnene. Klarte ved et uhell og koble sammen noen feil pinner. Det tålte den ikke, og sluttet å funke. Den slår seg på. Men får ingen lyd på utg. Uansett hva jeg velger av inng kilde. Jævli irriterende. Hadde bare en av de funket så kunne jeg jo ihvertfall brukt den. Har noen et kort til overs så si ifra.
  16. #16
    Hifi Freak
    Jan 2005
    Bæææærgen
    Tagget i
    2 Innlegg
    Sitat Sitat fra FAB
    Enkelt!
    Skippet alt unntatt coax, fordi en vel strengt tatt må inn på printet og switche på en "bryter" der for å kunne veksle mellom ulik tilkoblinger.
    Foretar i stedet switchingen via en Monarchy DIP....
    Proffen
  17. #17
    Nov 2008
    Tagget i
    0 Innlegg
    Jeg har koblet på en on off on bryter og fjernet jumper'ene på kortet lodda ledningene rett på pinnene på kortet.
    fungerer helt greit her hos meg
  18. #18
    Hifi Freak
    Jan 2005
    Bæææærgen
    Tagget i
    2 Innlegg
    Sitat Sitat fra Nikko03
    smart!
    men så er det ikke meg som har mekket sammen min heller, da......
    hvor mange av inngangene har du da tilgang til, med bryteren påkoblet slik du har?
    Proffen
  19. #19
    Apr 2007
    Tagget i
    0 Innlegg
    Kan du med en lettfattet forklaring fortelle hvem av pinnene som er koblet til?
    Og hvor på bryteren. Prøvde meg nemlig på det samme med lik bryter fra clas.
    Jeg sier bare, ikke koble feil pinner sammen. Da tar dacen kvelden/kortslutter?
    når den slås på/bryter feil pinner sammen.
    Nov 2008
    Tagget i
    0 Innlegg
    Ved å ta vekk jumper'a på kortet å koble den slik. Fikk jeg usb coax og optisk til å virke. Håper tegningen er forståelig
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
